Snowblower Won't Start
Discussion in 'Outdoors' started by Outbound, Dec 18, 2022.
  1. Dec 21, 2022 at 7:09 PM
    Outbound
    Outbound [OP] SSEM #2.5, AmeriCanadian, OG 1st Gen Rabble Member
    Aaron
    Northern Alberta
    I'll give it a shot in the morning before I load it up to take to the dealer.
  2. Dec 21, 2022 at 7:10 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    :thumbsup:
    Outbound[QUOTED][OP] likes this.
  3. Dec 21, 2022 at 7:13 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    You are getting fuel to the carb? If not check inside the gas tank and see if there is any gunk restricting the fuel to the carb.
  4. Dec 22, 2022 at 4:06 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    Hmm, with spark this should have given some result. Basically the same as another poster had suggested to put fuel into the cylinder. I have to do this to my moms snowblower at the start of every season and then it runs fine for the season.
    At least it is under warranty, but my guess is like others have said the jet needs to be cleaned.
    I was having some issues with mine last season, was going to rebuild the carb and do a bunch of other maintenance over the summer but of course I didn't so I just did all that yesterday in prep for snow that we are finally supposed to get tomorrow, better late than never lol.
  5. Dec 22, 2022 at 6:38 AM
    Warreng
    Warreng New Member
    You need a narrow flat blade screw driver to get that jet out, soak it windshield washer fluid or carb cleaner and blow it out w compressed air.
  6. Dec 22, 2022 at 8:14 AM
    Warreng
    Warreng New Member
    Also watch that pin holding your float on, they can slide out with the bowl off. Looks like yours is on its way…
    NewImprovedRon likes this.
  7. Dec 22, 2022 at 8:32 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Good eye!
  8. Dec 22, 2022 at 9:58 AM
    DaBoro54
    DaBoro54 Beach Fisher
    Leveling kit, 285/70R18 EXOs
    Jet is clogged for sure. If it were me, I would buy a spare carb and keep it on the bench. They are so cheap it’s easier to swap out than mess with trying to keep cleaning it. The. You can have spare parts and have one all clean and ready to go at all times.
    hopefully you get her fired up and ready to work
  9. Dec 23, 2022 at 4:41 PM
    Outbound
    Aaron
    Northern Alberta
    So I ended up taking it in to Honda. Sounds like it was a combination of bad gas and the timing being off.
  10. Dec 23, 2022 at 4:52 PM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    You let that ethanol gas sit all summer, didn’t ya?
  11. Dec 23, 2022 at 4:54 PM
    Outbound
    Aaron
    Northern Alberta
    Nope. That gas was less than a month old and ethanol free. Supposedly anyways. I run nothing but Shell Premium in my small engines.
  12. Dec 23, 2022 at 4:56 PM
    On a positive note.......
    Blower is getting fixed, you are helping a local business. Once fixed...have the tech bring out the blower to clear your snow to be sure it's working properly. Tip is negotiable ......
  13. Dec 23, 2022 at 5:03 PM
    Outbound
    Aaron
    Northern Alberta
    The Honda dealer is a good outfit. They wouldn't come clear the driveway for me though. LOL
  14. Dec 23, 2022 at 5:12 PM
    Hightide
    Abalama
    Magic School Bus
    I mean, your summer is only a month.
  15. Dec 23, 2022 at 6:23 PM
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    Glad you got it fixed. In general, if an engine was running fine the previous season, it wouldn’t have lost compression during proper storage. So that leaves fuel and spark. To try and start if you suspect fuel or fuel delivery problem, it’s safer to use a shot of carb cleaner than ether. Checking for spark is pretty simple. If you have spark, and it fires and dies on carb cleaner, then you check fuel, lines, clogged filter, carb. If you store an engine with ethanol fuel and you don’t use an ethanol specific fuel stabilizer, you have a good chance of finding crud in the carb. The ethanol will start to gel and eventually become almost like fine sand.
    Outbound[OP] likes this.
