SNOW WHITE
Discussion in '2.5 Gen Builds (2014-2021)' started by Jsena, Jul 11, 2017.
  1. Jul 22, 2017 at 11:31 AM
    #151
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Same as me. It's obnoxious when people are around :rolleyes: It makes your truck sound like a POS to others when OBVIOUSLY it's not
    GNTundra and Jsena[QUOTED][OP] like this.
  2. Jul 22, 2017 at 11:36 AM
    #152
    Jsena
    Jsena [OP] Trend setter, not a follower!!
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Well, my truck does fit in my garage. About 1/4 inch from hitting but I'll still Park it out front.. gives me anxiety when pulling in.. IMG_1651.jpgIMG_1654.jpg
    Hits the rubber on the garage lol.. if I went 35's I would have been cool. Even with the 7 inch lift..
    GNTundra likes this.
  3. Jul 22, 2017 at 11:46 AM
    #153
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    SHE'S TIGHT!
  4. Jul 22, 2017 at 11:48 AM
    #154
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
  5. Jul 22, 2017 at 11:48 AM
    #155
    rons23
    Ron
    Kill Devil Hills
  6. Jul 22, 2017 at 12:17 PM
    #156
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Oh damn that's close. I'd probably remove that one row of wood and add a little something to the top of the garage door.
  7. Jul 22, 2017 at 12:26 PM
    #157
    Eclipsed & Floating
    Voluptuous Whitey
    All about them mods!!
    Jsena[OP] likes this.
  8. Jul 22, 2017 at 1:09 PM
    #158
    Eclipsed & Floating
    Voluptuous Whitey
    Jsena[QUOTED][OP] likes this.
  9. Jul 22, 2017 at 1:24 PM
    #159
    Eclipsed & Floating
    Voluptuous Whitey
    Painted tip and pipes
  10. Jul 22, 2017 at 1:35 PM
    #160
    Eclipsed & Floating
    Voluptuous Whitey
    I painted them while they were on the truck using cardboard as over spray protectant
  11. Jul 22, 2017 at 1:47 PM
    #161
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    I bet the rub you have is on your body mounts. Next time you reverse it with the tire fully cranked go look at where it hits. I bet if you do the body mount trim and weld plate it will eliminate the rub completely.
    Jsena[QUOTED][OP] and ColoradoTJ like this.
  12. Jul 22, 2017 at 1:48 PM
    #162
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Is that a dent?
  13. Jul 22, 2017 at 1:49 PM
    #163
    1UPPER
    TEXAS
    Flux capacitor!
    Your truck is looking great bro! How's the ride feel?
  14. Jul 22, 2017 at 1:51 PM
    #164
    1UPPER
    TEXAS
    Flux capacitor!
    Here's my body mount after it was trimmed. I had the exact same rub you have when in reverse with tires cranked. This fixed it completely. IMG_6027.jpg
  15. Jul 22, 2017 at 1:55 PM
    #165
    1UPPER
    TEXAS
    Flux capacitor!
    If your suspension starts to squeak at some point look this stuff up. It a dry lubricant that you can use to help eliminate squeaks. It's very import you don't spray Wd40 or anything like that because dirt will stick to it and scratch your components. Great stuff!! IMG_7096.jpg
  16. Jul 22, 2017 at 1:55 PM
    #166
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
  17. Jul 22, 2017 at 1:55 PM
    #167
    1UPPER
    TEXAS
    Flux capacitor!
    Rear close to your door. That the body mount that was trimmed. Usually that the area you will hit.
  18. Jul 22, 2017 at 1:58 PM
    #168
    1UPPER
    TEXAS
    Flux capacitor!
    So they did trim your body mount but they did a very gradual cut. Also the inner fender lining usually can be pushed back further. My fender liner was pushed back further and my cut angle is more aggressive. If your is still rubbing they may need to trim more off.
  19. Jul 22, 2017 at 2:00 PM
    #169
    1UPPER
    TEXAS
    Flux capacitor!
    He did cut back far enough but his angle could be a little more. Look at my cut angle versus yours. Does your tire hit on the end of the body mount?
  20. Jul 22, 2017 at 2:02 PM
    #170
    1UPPER
    TEXAS
    Flux capacitor!
    Check and see where it's rubbing first. If it's rubbing on the edge closest to the outside then yes they need to trim more.
  21. Jul 22, 2017 at 2:07 PM
    #171
    1UPPER
    TEXAS
    Flux capacitor!
    Here are a few more angles to show you how mine looks. I don't have any rubbing. I'm running 37s on a 12" wide rim with a -51 offset. IMG_8663.jpg IMG_8662.jpg
  22. Jul 22, 2017 at 2:41 PM
    #172
    Eclipsed & Floating
    Voluptuous Whitey
    Maybe
    MOAB IS MEAN TO TUNDRAS
    Jsena[OP] and joonbug[QUOTED] like this.
  23. Jul 25, 2017 at 2:07 PM
    #173
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    This bitch looks mean now. big, wide, aggressive. bisshhhIMG_1756.jpgIMG_1754.jpg IMG_1755.jpgIMG_1751.jpg
    Who needs sons when you have Daughters ¯\_(ツ)_/¯ I needed them to hold it up for a second while I put the first bolt in :rofl::muscleflexing: :burnrubber::mudding:
    WILLINH, SuaveRC, DalTee and 13 others like this.
  24. Jul 25, 2017 at 2:18 PM
    #174
    payyourtoll
    payyourtoll New Member
    Tampa, FL
    sweet truck! and the last pic is great :)
    GNTundra, ColoradoTJ and Jsena[OP] like this.
  25. Jul 25, 2017 at 2:25 PM
    #175
    Eclipsed & Floating
    Voluptuous Whitey
    :thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup:
  26. Jul 25, 2017 at 2:33 PM
    #176
    Eclipsed & Floating
    Voluptuous Whitey
    Me too
  27. Jul 25, 2017 at 3:10 PM
    #177
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    That is too cute. Steps look awesome. Now all you need are some color matched handles and remove the Tundra badge. :devil:
  28. Jul 25, 2017 at 3:20 PM
    #178
    SW72
    SW72 New Member
    Shane
    Kansas City
    2013 Tundra RW
    Biltsein 5100 shocks, BFG 315/70/17, tinted windows, TRex billet grille insert, more to come.
    Those look great. Did you go with the N Fab ones? Really nice!
  29. Jul 25, 2017 at 3:24 PM
    #179
    rons23
    Ron
    Kill Devil Hills
    Very nice. Looks good. I guess cause they look like mine, hahaha.
  30. Jul 25, 2017 at 3:38 PM
    #180
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Fit in your garage?
