smoothest ride at lower setting-5100, 6112, Pro
Discussion in 'Suspension' started by Berettafan, May 30, 2017.
  1. May 30, 2017 at 3:53 AM
    Berettafan
    Berettafan [OP] New Member
    2017 CM
    Getting 305/65R18 for my CM. Considering leaving suspension stock for a while to absorb the $$ hit. At some point though I will want to lift the front just enough to look good and give clearance for the tires. I'm an old man when it comes to how I like my vehicles to ride, nice and cushy. What's my best choice for long term happiness? I realize pricing is ranging from $200 to $2,500 but I put a premium on using factory parts wherever possible as I believe the engineering is important and I want the factory standing behind their product particularly on a $45k vehicle.
    Would appreciate hearing from people who have actually owned/ridden in trucks equipped with each. Regarding the Pro my understanding is the ONLY difference is the shock/coil itself and not arms or any other part of the suspension.
    Thanks,
  2. May 30, 2017 at 4:00 AM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    Two coachbuilder shims will give you an additional 1" up front and won't change ride.
    Remember tire width will almost always govern "clearance" before height...assuming stock +60 offset.
  3. May 30, 2017 at 5:19 AM
    chphilo
    chphilo Tundra addict
    Western PA
    If you want cushy ride, why are you getting 305/65/18 (I assume is an e-rated tire)? Non-TRD factory shocks and p-rated tires will give you more comfortable ride.
  4. May 30, 2017 at 5:24 AM
    Berettafan
    2017 CM
    can't get p rated on anything bigger than stock unfortunately.
  5. May 30, 2017 at 5:25 AM
    Berettafan
    2017 CM
    So the shims are a spacer lift. Seems I've read here many times to avoid spacers. Does this not apply because it's a very short lift or for some other reason?
  6. May 30, 2017 at 5:29 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    not enough height for any significant change in ride.
  7. May 30, 2017 at 5:45 AM
    chphilo
    Western PA
    Why 305/65/18 though if you are not getting your truck lifted/leveled?
    If you are determined to get something larger than stock, look into GoodYear DuraTrac. I have Trail Grappler on Tundra and my wife's Nissan van has DuraTrac. Her van (1-ton van) rides definitely smoother than my Tundra. (Have you considered 275/70/18 or even 295/65/18?)
  8. May 30, 2017 at 5:52 AM
    Berettafan
    2017 CM
    Going with Method NV in 18x9 which I'm told is too wide for 275/70. 295/65 looks great but have read the Duratracs get noisy with miles on them and really are a near mud tire which I have no need for. found this guy on that other forum who put 305/65 on a stock suspension and it's pretty close to just right. could use about 1" in the front. Sounding like $75 in shims would get it done with no impact on ride quality.
    http://www.tundratalk.net/forums/tundra-wheels-tires/127050-all-wheel-tire-pics-here-95.html
  9. May 30, 2017 at 6:01 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    9 inch rims aren't too wide for 275/70's.
  10. May 30, 2017 at 8:52 AM
    R0CKETMAN
    NGAMTNS
    each shim is .25" so .5 isn't going to make any noticeable difference in geometry.
  11. May 30, 2017 at 4:42 PM
    CPsTundra
    CPsTundra 915
    Super White CM TRD Pro
    Yes, Shims are different from spacers. I'm curious to know why people say to avoid spacers?
  12. May 30, 2017 at 5:00 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Changes geometry of suspension parts making it easier for them to fail/break and puts too much preload on stock shocks where you will top out and bottom out much easier
  13. May 30, 2017 at 5:05 PM
    CPsTundra
    CPsTundra 915
    That makes sense. Thanks
    Law323[QUOTED] likes this.
  14. May 30, 2017 at 5:24 PM
    Berettafan
    2017 CM
    As do 5100s
  15. May 30, 2017 at 6:03 PM
    AKJ78
    AKJ78 New Member
    Aaron
    San Diego
    2016 Silver Platinum 4X4
    3/1.5 lift. TRD sway bar. Bakflip V1 cover. Fuel wheels w/BFG A/T.
    Concur. I'm running 275's on a 20x9 fuel wheel. No issues and looks great! Went 275 to avoid any possibility of rubbing and keep cost down.
  16. May 30, 2017 at 6:09 PM
    AKJ78
    AKJ78 New Member
    Aaron
    San Diego
    If you want 1/2" spacer up front, try these. $25 shipped. High quality, look great, and not overpriced.
    Toyota Tundra 1" Front Leveling Lift Kit 4WD 2WD Billet aluminum Tundra 1.0T
    https://www.ebay.com/itm/121514406540
  17. Jun 30, 2017 at 5:25 PM
    Berettafan
    2017 CM
    just to follow up I went with two CB shims on each side. ended up taking the 305s off but do like the look with the 1" of lift it supposedly gave me even on stock wheels/tires. have not noticed a change in ride.
    imo 305 + 9" wheels looks great but is too much weight for stock suspension on these trucks.
  18. Jun 30, 2017 at 6:31 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    I run 305/65R18s on 18x9 +25 methods. I have 6112s on the front. Did rub a tiny bit on the little flaps between the tire and front bumper. Took em off and pushed the liner forward. No issues now
    phonyteachr likes this.
