Smoking on startup and smell of gas
Discussion in '1st Gen Tundras (2000-2006)' started by bobbyslay, Aug 23, 2021.
  1. Aug 23, 2021 at 12:20 PM
    Kfrog
    Kfrog New Member
    2016 Tundra SR-5
    Do a compression test with engine cold and while at it have plugs tested or just change them out depending on mileage.
    Dr Doobie likes this.
  2. Aug 23, 2021 at 12:20 PM
    bobbyslay
    bobbyslay [OP] New Member
    I'm not scared of using seafoam. I'll give this a shot first, thanks a bunch.
  3. Aug 23, 2021 at 12:22 PM
    bobbyslay
    right around 145k and I'd bet my life that the sparkplugs are original.
  4. Aug 23, 2021 at 12:24 PM
    bobbyslay
    Starts up easily, runs great.
  5. Aug 23, 2021 at 12:24 PM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    To stop the all the guessing just do a plug reading and that will answer the questions
    tvpierce and bobbyslay[OP] like this.
  6. Aug 23, 2021 at 12:30 PM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    Just look at your evidence:
    1) Gassy smell
    2) White smoke that disappears
    It's not oil.
    Verify the problem.
    I would get those plugs out too.
    bobbyslay[OP] and YardBird like this.
  7. Aug 23, 2021 at 12:54 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    One more little caveat to consider.
    If (and that's a Big If) the fuel injector(s) are leaking at shut down you could be subjecting yourself to a 'liquid/hydraulic lock' of at least one cylinder.
    Happened years ago on my compadre's Big Block Chevy where the carburetor was dumping raw fuel into the engine at shut down.
    He came back later and tried to restart the engine ~ no dice ~ the cylinder had enough raw fuel inside to stop the engine from turning any further.
    Remember, liquid does not compress.
    The result ? A severely bent connecting rod. He got lucky and R&R'ed the bad rod with a new one ~ problem solved.
    Just something to think about . . .
    https://youtu.be/YBrb23BQGIw
  8. Aug 23, 2021 at 12:58 PM
    Dr Doobie
    Talkeetna,Alaska
    That's a wall hanger there!
    YardBird[QUOTED] likes this.
  9. Aug 23, 2021 at 12:59 PM
    YardBird
    Jonesy
    2005 RCLB
    Amen to that !
    My compadre had something similar hanging in his garage ~ I asked him about it and he told me the story . . . :eek:
    Dr Doobie[QUOTED] likes this.
  10. Aug 23, 2021 at 12:59 PM
    shifty` Waving My Dick In The Wind
    Nah, it'll bang right out good as new. :rofl:
  11. Aug 23, 2021 at 1:04 PM
    Dr Doobie
    Talkeetna,Alaska
    Little heat and beat.lol
  12. Aug 23, 2021 at 1:06 PM
    Dr Doobie
    Talkeetna,Alaska
    Those can be some crazy stories sometimes! Lol
  13. Aug 23, 2021 at 1:14 PM
    YardBird
    Jonesy
    2005 RCLB
    He was one of the most mechanically oriented fellows I ever had the pleasure to meet.
    He worked for Consolidated Vultee during WW II getting aircraft ready to be sold to the military.
    He'd forgotten more than I'll ever know about being a mechanic of any sort.
    bmf4069 and Dr Doobie[QUOTED] like this.
  14. Aug 23, 2021 at 2:08 PM
    Wait, what were we talking about again? :dancingbacon:
  15. Aug 24, 2021 at 3:47 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    ^^^This.
    Simple and quick to DIY, and will tell you what's going on... or at least be a good first step. Keep track of which plug is from which cylinder to aid in the diagnoisis and post back with pics.
  16. Aug 24, 2021 at 8:36 AM
    tdrich7
    tdrich7 New Member
    2006 Tundra DC 4wd SR5
    This sounds very similar to what my truck has been doing. However if mine has been sitting multiple days it doesn't seem to smoke nearly as much or at all. I replaced my PCV valve recently and have only had it happen once since then. The PCV valve definitely was clogged full of gunk and needed replaced. But it usually does it the most when it has been sitting for just a couple hours, and I believe that was the case that time. Interested to hear what you find out.
  17. Aug 30, 2021 at 10:26 AM
    bobbyslay
    Oil looked perfect, coolant level is good. I have added a bottle of seafoam to a less than half-full gas tank. Going to see if that knocks anything loose. I'll replace PCV valve this weekend just for good measure, I'm pretty sure it hasn't been done before.
  18. Aug 30, 2021 at 10:28 AM
    bobbyslay
    I do plan on doing this too, maybe when I do the PCV. Thank you.
