smelly trees
Discussion in '2nd Gen Tundras (2007-2013)' started by tundratrav82, Apr 8, 2015.
  1. Apr 8, 2015 at 10:47 AM
    tundratrav82
    tundratrav82 [OP] Nevada Tundras
    travis
    winnemucca, NV
    2011 tundra limited TRD crewmax
    Limmo tint on all 3 rear windows, 20% in front two. 18" black ballistic rims with nitto tires Bike bar in the bed for my dirt bikes..
    IMG_20150408_104133116.jpg hi guys and gals, I guess reading the warnings on the packages first would have been smart. for anyone that uses the smelly tree car fresheners.. I use to hang one off my ac/heater fan switch and it covered my button cluster that housed my tow/haul button on my 2011 ltd CM. well just the other day I pulled it off and to find it lifted my paint on the dash..
    does anyone know where to get another oem part with same color match or would I be better off just painting it black?
  2. Apr 8, 2015 at 11:04 AM
    Mike Tread lightly.
    south carolina
    You can one of two things..
    One sand it and paint it black for a cool look. flat black i think would be best IMO.
    Two take the part off and look at the back of it. Most parts like that have toyotas sku number stamped on it.. With the sku you could shop online toyota dealers and get the best price on the part and have it shipped to you.
  3. Apr 8, 2015 at 11:11 AM
    tundratrav82
    travis
    winnemucca, NV
    Didn't think of looking for a part# or SKU # thanks
  4. Apr 8, 2015 at 1:49 PM
    JC303
    JC303 Same same but different
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    Same thing happened to me but I used to hang mine from the shift knob so it messed up the paint on the side the slightest bit. Hard to see because it's on the side of the console near the seat.
  5. Apr 8, 2015 at 2:09 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I didn't know they could do that! Crazy. I usually put the band around the seat belt buckle and let the tree lay between the seat and console.
  6. Apr 8, 2015 at 3:18 PM
    chphilo
    chphilo Tundra addict
    Western PA
    I got the one with clip on . The part that clips on is plastic and smelly part sticks out without touching anything, so I am safe.
  7. Apr 9, 2015 at 9:14 AM
    Good info. I will never get these tree freshener again!
  8. Apr 9, 2015 at 9:56 AM
    FunkinTundra
    FunkinTundra New Member
    Cody
    2012 Tundra 5.7 CM
    OME614 full suspension\ Ekstrom design 3" shackles and poly bushing kit\ 295/70r18 Toyo MTs/ +20 offset Fuel Anzas\ 8" BAmuffler....etc...
    Wow!! I knew those were strong but good lord!!
  9. Apr 9, 2015 at 12:58 PM
    Mike Tread lightly.
    south carolina
    I want to say those are dipped in a acid..
  10. Apr 9, 2015 at 1:16 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Agreed. Crazy it does damage like that. I'll stick to the gel ones that stay in the can that go under the seat or cup holder.
  11. Apr 9, 2015 at 4:24 PM
    tundratrav82
    travis
    winnemucca, NV
    Quick update.. After sanding down the factory paint of the dash insert, I threw a few coats of semi gloss black on it and installed it back into the dash.. Its not bad looking.. I'll post a few pics later.
  12. Apr 9, 2015 at 4:25 PM
    tundratrav82
    travis
    winnemucca, NV
    I would believe it.
