Small propane tanks
Discussion in 'Recovery & Gear' started by TheBeast, Mar 6, 2022.
  1. Mar 6, 2022 at 8:27 PM
    TheBeast [OP] The Beach
    GODZILLA, FrenchToasty and 831Tun like this.
  2. Mar 8, 2022 at 11:07 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    FrenchToasty likes this.
  3. Mar 8, 2022 at 11:20 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    These are great, I have a couple of these.
  4. Mar 8, 2022 at 4:45 PM
    16MagSR5
    16MagSR5 New Member
    Buffalo
    2016 Magnetic SR5, leveled and capped
    Boost tow Mirrors, TRD rear sway, Rough Country Duals, Bilstein 5100's, diff breather mod, more that I'm forgetting...
    I have 4 20 lbers and can't believe how much they want for a 5! They have a niche, but wow!!
    TheBeast[OP] likes this.
  5. Aug 22, 2022 at 4:55 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    @des2mtn @MadMaxCanon howre you guys running these on your trucks? Strapped to the bedside or what?
  6. Aug 22, 2022 at 5:18 PM
    MadMaxCanon
    I have the giant quick fists on the side molle panels in the bed
    Mater[QUOTED] likes this.
  7. Aug 22, 2022 at 5:30 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    I have a quick fist ratcheting web clamp and it holds mine perfectly in the bed.
    Mater likes this.
  8. Aug 22, 2022 at 5:51 PM
    des2mtn
    SW
    Tonto cover
    Strapped to the back corner in the bed with a chair usually wedged in front. I've keep one in the cab too.
  9. Aug 22, 2022 at 6:24 PM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    Damn you can get 2 of the one pound green camping tanks for like 10 bucks at Walmart. Why is this thing so special? Same price as a new 20lb tank?
  10. Aug 22, 2022 at 6:31 PM
    des2mtn
    SW
    Tonto cover
    20lb is a pain to carry around, and managing partial green tanks gets old after awhile. I'll use these for many years to come.
    AZBoatHauler, TheBeast[OP] and Mater like this.
  11. Aug 22, 2022 at 6:33 PM
    eick
    eick New Member
    Well to be fair to these tank makers they probably make 5000 twenty pound tanks to every one of these five pounders so pricing makes sense I guess
    I will just refill my little green tanks
  12. Aug 22, 2022 at 6:46 PM
    just one tank to carry around with enough propane to last a week. Also used with propane fire pits for those fire ban areas.
    grave, SAGE63, des2mtn and 1 other person like this.
  13. Aug 22, 2022 at 7:16 PM
    Turtle
    Turtle New Member
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    Aries Side Bars, DeeZee low profile tool box, weathertech mats, TRD RSB
    Ok, I can't resist it, have had the 5 lb and it needs to be tied to something to run a lantern, however the 20 lbs will fit quite nicely in a milk crate that is marked "possession is considered theft'", it can be strapped in the back of trucks and doesn't move. Already has the cushion on the sides and doesn't slide. Can be disconnected in the morning and used to power a camp stove for drip coffee and eggs in skillet. plenty left.
  14. Aug 22, 2022 at 7:21 PM
    Turtle
    Turtle New Member
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    just realized that it was post #13. Yes, I am superstitious, call it the religion of the feeble minded, I don't care. But I had to post number 14.
  15. Aug 24, 2022 at 7:37 AM
    des2mtn
    SW
    Tonto cover
    One thing I've found that is nice about these specific ones versus other brands, is they have a built-in gauge.
  16. Aug 24, 2022 at 7:47 AM
    eick
    eick New Member
    Gauges on these little propane tanks are all but useless. Just gonna read full until it’s empty. Better to use the temp strips and some hot water or just weigh the tank.
  17. Aug 24, 2022 at 7:50 AM
    des2mtn
    SW
    Tonto cover
    What's with the vitriol towards these tanks? My gauge works fine...
    831Tun likes this.
  18. Aug 24, 2022 at 7:53 AM
    eick
    eick New Member
    No vitriol intended. It’s just the way propane works. Liquid converts to gas and tank maintains same pressure until there’s no liquid left to convert. It’s like having a fuel gauge on your car that says ‘there’s gasoline in there’ but it doesn’t tell you how much
    des2mtn likes this.
  19. Aug 24, 2022 at 10:26 AM
    MadMaxCanon
    I use a separate gage adapter that goes onto the valve, its essentially an extension with a gage on it thats pretty accurate. With the relatively low weight, its harder to tell when its low compared to a 20 lb tank. Like 10 bucks on Amazon.
    des2mtn likes this.
  20. Sep 1, 2022 at 6:59 AM
    des2mtn
    SW
    Tonto cover
    Filled mine up today from a leaking 20lber.
  21. Sep 1, 2022 at 8:20 AM
    MadMaxCanon
    Did you condition the tank by freezing it or anything first? Were you able to fully fill it?
    des2mtn[QUOTED] and AZBoatHauler like this.
  22. Sep 1, 2022 at 8:31 AM
    des2mtn
    SW
    Tonto cover
    I followed the instructions on this video: https://www.youtube.com/watch?v=jC5sVhxMmno
    I didn't freeze the tank. I used the bleeder valve and closed it once visible gas started coming out. Pretty sure I got them all the way full, tanks weighed at 14.3lb once full and they're somewhere in between 9 and 10 when empty.
    MadMaxCanon[QUOTED] likes this.
  23. Sep 1, 2022 at 8:41 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    And he drives a tundra!
    Mater and des2mtn like this.
  24. Sep 1, 2022 at 9:33 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Serious question, why not carry the regular sized one?
  25. Sep 1, 2022 at 9:59 AM
    MadMaxCanon
    Its big, its heavy, it doesnt fit under my bed cover.
    des2mtn likes this.
  26. Sep 1, 2022 at 10:36 AM
    SAGE63
    San Diego County
  27. Sep 1, 2022 at 10:53 AM
    Brettstation37
    Brettstation37 New Member
    Brett
    Catskills NY
    2020 Tundra CrewMax TRD Sport
    ahhh the old drift hose method…must have worked for a propane company to know that one
  28. Sep 1, 2022 at 10:59 AM
    SAGE63
    San Diego County
    I like the use of the 1lb filler adapter on the 5lb tank and the 1lb hose converter on the 20lb. I actually have both so dont have to buy more hoses or couplers...
    Mater likes this.
  29. Sep 1, 2022 at 11:27 AM
    Brettstation37
    Brett
    Catskills NY
    All that’s happening is equalizing the pressure, used to work for a LP company for 8 years and I’d use this method late at night so I didn’t have to bring tank truck out…works better with full small tank into a larger tanks but will at least equalize pressures
  30. Sep 5, 2022 at 1:36 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    this right here. i'm over juggling around partially empty bottles and writing "use this one first" on the most empty one, then throwing them away. i'd rather just keep a dedicated 5lb-er for camping trips. fifty bucks tho, sheesh
