SMALL AUDIO STORM TROOPER 2015 CREWMAX BUILD
Discussion in 'Audio & Video' started by Vector W8, Jan 27, 2018.
  1. Jul 24, 2020 at 10:15 AM
    #121
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    how did you determine that that is the sound curve (on the rta) you wanted?
    As far as i know, i'm running a completely flat curve (the fix86 does it automagically). I heard that thats what you want, but no idea the backing behind it.
  2. Jul 24, 2020 at 10:26 AM
    #122
    Vector W8
    Vector W8 [OP] Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    Most systems need a slight bump in the bottom end to maintain a natural sound and a slight roll off at the top end to keep the system from sounding harsh.
    I sent the curve to ARC audio and they wanted to use the photo, stating it was the perfect curve.
  3. Jul 24, 2020 at 11:27 AM
    #123
    Vector W8
    Do you have a photo of your RTA Curve?
  4. Jul 24, 2020 at 12:42 PM
    #124
    Vector W8
    A couple of shots of the rear of the front door panels after putting Dynamat on them to kill the resonance.
  5. Jul 24, 2020 at 5:02 PM
    #125
    Danimal86
    Daniel
    Sacramento, CA
    I think I'm going to start to mess with the software for the fix86 and see if I can mess with it. I definitely feel like I need to take the really highs and give lows a little bit extra
    Vector W8[QUOTED][OP] likes this.
  6. Jul 24, 2020 at 7:18 PM
    #126
    Vector W8
    I would love to see your system. I also am curious to see on an RTA how your systems looks. I would like to see just what the FIX86 from JL is doing when you let it set the system automatically. Do you have access to an RTA?
  7. Jul 24, 2020 at 9:03 PM
    #127
    Danimal86
    Daniel
    Sacramento, CA
    Don't really have access to an rta, I've looked into getting one before.
    There's a link to my build in my signature.
  8. Feb 4, 2021 at 11:35 AM
    #128
    Vector W8
    Please keep in mind that in SQ competition you tune on the 3db per octave scale. This is as tight as the rules test at. With my system I am using the 2db per octave scale to achieve this curve. That is MUCH tighter than competition judging is done at. So this curve would be hard to achieve with some of the best SQ systems in the world.
  9. Feb 8, 2021 at 9:35 AM
    #129
    Tactical_TRD_Pro
    Tactical_TRD_Pro New Member
    Scott
    2016 Toyota Tundra TRD Pro
    @Vector W8 , when cutting the filler to the size of the XTC baffle, how many layers of filler do you lay in the baffle...1 layer or more?
  10. Feb 8, 2021 at 5:35 PM
    #130
    Vector W8
    I pack as many layers in there as I can. It should be pretty stiff if you press on the back of the baffle.
  11. Feb 15, 2021 at 7:12 AM
    #131
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    if you need any help with the fix software, give a shout. i wouldn't say i'm an expert but i've put some time into learning it.
    i use the audio tools app. it has an RTA curve along with a number of other goodies.
    Tactical_TRD_Pro likes this.
  12. Feb 15, 2021 at 7:25 AM
    #132
    Danimal86
    Daniel
    Sacramento, CA
    Thx @smslavin ! I have been working hard on the tune with the help of VectorW8. I ended up getting a mini dsp umik-1 and using REW on my laptop to tune the helix. I'll be posting an in-depth process on the tune in my build log. But I was getting a little frustrated the the Fix86, so kenwood head unit will be delivered today.
  13. Feb 15, 2021 at 7:59 AM
    #133
    Tactical_TRD_Pro
    Scott
  14. Feb 15, 2021 at 9:17 AM
    #134
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    i don't want to derail vector's thread too much but, the fix software doesn't have any measurement capabilities. you have to use an external device like what vector has done. with the audio tools app on my phone, i can get a rough RTA curve from the mic on my phone. if the truck is on and the phone is connected, the app also lets me run pink noise through the stereo which i can read on the RTA curve. is it as good as a calibrated measurement mic? no but, it gets me in the ball park.
    i'm eventually going to pick up a measurement mic as i need one to calibrate the reference monitors in my office space for my studio work. once i have that done, i'll put it in the truck and dial things a bit more.
  15. Feb 15, 2021 at 9:19 AM
    #135
    Tactical_TRD_Pro
    Scott
    Thank you!
    smslavin[QUOTED] likes this.
  16. Feb 15, 2021 at 9:20 AM
    #136
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    :hattip: :cheers:
