Slow crank and low oil pressure
Discussion in '1st Gen Tundras (2000-2006)' started by cammiller, May 13, 2020.
  1. May 15, 2020 at 2:31 PM
    ATCinfantry
    ATCinfantry Pot Stirrer
    Trey
    Memphis, TN
    2017 Toyota Tundra MGM SR5 TSS Off Road Package
    Running Boards. AJT YEET Chrome interior kit. Tonneau cover. More Mods Coming SOON!
    Just call a reputable tuner. I don't particularly care for the "Canned" tunes such as bully dog etc. I'd prefer a tuner put hands on the truck and tune it in person.
    You probably wont pick up any real gas mileage by just leaning it out. If you're willing to run 93 in it, you'd see a little bit of gas mileage but not enough to offset the cost of the more expensive fuel but you'd see a pretty damn good performance gain.
  2. May 24, 2020 at 4:07 PM
    cammiller
    cammiller [OP] IG: cameron.a.mi
    Cameron
    Sulphur, Louisiana
    2004 Toyota Tundra Limited Phantom Grey Pearl
    Kicker speakers, Pioneer AVH-2550NEX Head Unit, DynaMat, LED Dash Conversion
    Hey guys, sorry for my absence. I appreciate all the advice. The issue was a simple knock sensor causing all hell to break loose. That’s what the slight knock upon start up was. I was told I have rod knock, and that I’d have to replace the engine. All I needed to do was replace a $180 sensor. While I was at it I replaced the O2 sensor and one of my u joints as well as the oil pressure sending unit. When the knock sensor goes bad, it retards timing, causing the noises I was hearing. Im still having issues with ridiculously low oil pressure, but I was told that I should be fine. I sent my oil off to test it, but it appears to have no visible metal shavings in it. Thank you for all the help. I’m now back and rolling in my Tundy!
  3. May 24, 2020 at 4:27 PM
    ATCinfantry
    Trey
    Memphis, TN
    I've never heard of a knock sensor causing that. But I'll sure remember that.
    Did the oil pressure increase at all with the new sensor?
    Thanks for checking back in with us and be sure to let us know what the oil results say!
    Tundra2 likes this.
  4. May 25, 2020 at 8:15 AM
    Professional Hand Model
    Hand Protectors
    I believe our Tundras have 2 Knock Sensors. The Intake Manifold needs to be removed to access. Might as well replace the Starter while ‘in there’. Glad you got it fixed!
  5. May 25, 2020 at 8:34 AM
    Hand Protectors
    Found the direct OEM Toy source by Masushita for less $.
    TX-TRD1stGEN likes this.
  6. Jun 9, 2020 at 6:17 PM
    cammiller
    Cameron
    Sulphur, Louisiana
    Got the oil results back, and apparently I really tore my engine up. Otherwise, she’s still trucking along. I took a 700 mile trip yesterday to Georgia and had no issues whatsoever. I leave Friday to make another 700 miles back home and I am confident I’ll have no issues. Oil analysis results below.2112A677-348B-475B-BFB9-98E99F27E61A.jpg675F9F4E-6DAE-45F2-B071-0330528405A9.jpg
    Tundra2 likes this.
