Slip yoke greasing, center bearing play.
Discussion in '1st Gen Tundras (2000-2006)' started by Pucks18, Jun 12, 2020.
  1. Jun 12, 2020 at 6:24 PM
    Pucks18
    Pucks18 [OP] Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    1st question, is a little it of play normal for the center carrier bearing on the driveshaft? Ive got some.. 2nd question. Was trying to grease my slip yoke, and i kept pumping and pumping (about 15 pumps) and it never moved, or oozed any grease out at all. Am i missing something there?? Thanks. Edit: i tried uploading a video of it but couldnt.
  2. Jun 12, 2020 at 7:29 PM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    If the carrier bearing is bad, you will know. My whole truck is vibrating right now due to the that. Your other question I dunno
    Edit; I'm 2wd now so my driveshaft no have grease
  3. Jun 12, 2020 at 8:44 PM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    Keep pumping, it will move.
  4. Jun 12, 2020 at 8:47 PM
    Hooptytrix
    Dirty South
    That just doesn't sound right at all
    bmf4069 and Pucks18[OP] like this.
  5. Jun 12, 2020 at 9:29 PM
    Pucks18
    Yea i stopped. Read only it needs like 5 pumps max. I was like 20 pumps in
    Hooptytrix likes this.
  6. Jun 12, 2020 at 9:30 PM
    Hooptytrix
    Dirty South
    Marty McFly likes this.
  7. Jun 12, 2020 at 9:50 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Man, this thread went south quick.
  8. Jun 12, 2020 at 10:38 PM
    Hooptytrix
    Dirty South
    Hey bro, ^ they ^ left that door wide open, I just walked in :yes:
  9. Jun 12, 2020 at 10:38 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Here we go getting into trouble again. Lol
  10. Jun 12, 2020 at 10:40 PM
    Hooptytrix
    Dirty South
    Tundra2[QUOTED] likes this.
  11. Jun 13, 2020 at 6:45 AM
    Schcoman
    Schcoman From behind the Redwood Curtain
    Humboldt Co. CA
    2000 Access Cab 4.7L V8 4x4 SR5
    None
    I was told by some here that 1/8-1/4" is normal. I suspected mine was bad, vibrated like crazy but oddly the vibration has disappeared. I plan to replace it soon. And I can't top the other replies. :)
  12. Jun 13, 2020 at 6:49 AM
    Professional Hand Model
    Hand Protectors
    @FirstGenVol has a method where he pumps it 15 times and then runs to the back and jumps on the bumper until the zerk hole oozes out. When he sees that he screws the zerk back in place and wipes the shaft clean.
    Personally, the first time I pumped my slip yoke it took about 20 pumps (stopped at 20 because no ooze) where the other zerks were about 8 pumps before ooze.
    A month later I pumped the slip yoke again with about 10 pumps and the grease squeezed out the shaft finally. I did notice that prior to this second application that grease was on the shaft from the first time so presuming it finally worked its way out from a months worth of driving.
    Dracko and bmf4069 like this.
