Slight squeak sound coming from front susepnsion area
Discussion in 'General Tundra Discussion' started by REV51, Jul 5, 2018.
  1. Apr 15, 2021 at 7:51 PM
    TeRDra
    TeRDra New Member
    2018 Tundra Crewmax 4x4 SR5
    Lift( 2/4) 35” Fuel rims and tires
    Finally fixed the squeak today, pretty stoked about it. I never could figure out where mine was, I sprayed lube on all the suspension and checked that horn bracket to no avail. Finally I hit the skid plate and there it was all this time (months). Could’ve taken it off and put some silicone in there, but I was lazy and shot some lube in there. Anyways, it’s finally gone!
  2. Apr 16, 2021 at 4:20 AM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    When you guys say you sprayed silicone. Could you post a pic and name, please?
  3. Apr 16, 2021 at 6:53 AM
    SouthWestGA
    SouthWestGA New Member
    Subbing for later
  4. Jun 12, 2021 at 4:16 PM
    goodmorningdear
    goodmorningdear New Member
    THANK YOU SIR
  5. Nov 11, 2022 at 1:17 PM
    Tortuga83
    Tortuga83 New Member
    Tortuga
    I know this is an old post, but I had a slight squeak coming from the front end of my 2018 Tundra. Greased the UCAs not it, lithium grease on the transmission cooler mounts not it, lithium greased the spare tire mount under the truck not it…..culprit was the hood latch!!! The part that you push to open, after it is already popped, if you move it side to side it squeaks. Put some lithium grease on it and all good!
    Retired Blue and georgiey22 like this.
