Slight catch or bump feeling when turning sharp 4wd not engaged
Discussion in '2.5 Gen Tundras (2014-2021)' started by IowaGuy, Oct 21, 2021.
  1. Oct 21, 2021 at 9:01 AM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    On my 2019 4wd I am getting a slight catching or bump type feeling when straightening the wheels out from a sharp turn. I don't know how else to describe it but it is like how it would feel if 4wd drive was engaged, but it isn't.
    I have sat and engaged and then disengaged 4wd a couple times with no difference. Maybe this is just the front hubs on the Tundra and how they feel. Is this normal or any ideas of what I can check. Maybe it is the steering or power steering pump? Thx.
  2. Oct 21, 2021 at 11:07 AM
    IowaGuy
    In Process
    Someone mentioned on another forum that it might be the ABS self check.
  3. Oct 21, 2021 at 11:16 AM
    2mchfun
    2mchfun Yeah it'll pull it, just don't expect to stop!
    Check the steering rack mounts and tie rod ends.
  4. Oct 21, 2021 at 1:36 PM
    IowaGuy
    In Process
    After a little more testing I believe it is the ABS adjusting.
    1. I can only get it to do it when I back out of a spot and turn the wheel and then proceed fwd
    2. after restarting the truck
    If I back out of somewhere after the truck is running and it has already bumped then it wont do it?
    2mchfun likes this.
  5. Oct 21, 2021 at 6:08 PM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Mystery solved…again. ;)
    TTund16 likes this.
  6. Oct 22, 2021 at 7:31 AM
    IowaGuy
    In Process
    No one warned me about this on the Tundra LOL. I tested it and it only happens when I reach 6mph so it is the ABS check.
    Jaypown and 2mchfun like this.
