Simple Remote Start
Discussion in '2nd Gen Tundras (2007-2013)' started by 13CrewMax, Nov 14, 2020.
  1. Nov 14, 2020 at 11:38 AM
    13CrewMax
    13CrewMax [OP] Oops
    Southern Oregon
    2013 CrewMax
    Not enough.
    Not sure how many people are interested, but I found a super simple remote start that works great. I found it on Amazon for like 188 I think from Start-X for my 2013. It was all plug and play, NO splicing, and uses my factory fob. Simply click lock three times, it fires up. Click three times again and it shuts off. Auto shut off after 15 minutes. Keep truck locked. Perfect for those cold mornings!
    I'm sure someone has posted it before, but I still wanted to put it out there for anyone who didn't see it. 10/10 would recommend!!IMG_20201107_193652_437.jpg
    Wallygator, diavel, TheBeast and 2 others like this.
  2. Nov 14, 2020 at 12:37 PM
    Cortez11
    Cortez11 New Member
    2013 DblCab 5.7 4x4
    Awesome, thanks man. How long have you been using it for?
  3. Nov 14, 2020 at 1:31 PM
    13CrewMax
    13CrewMax [OP] Oops
    Southern Oregon
    2013 CrewMax
    Not enough.
    I think it's been about a month now.
    Wallygator and Mountun Goat like this.
  4. Nov 22, 2020 at 11:02 AM
    Donkeypuncher
    Donkeypuncher New Member
    ARIZONA
    2008 semi built up girl named Rhonda
    Fuel Zypher 18 inch wheels, 305/70/18 Dick Cepek trail country EXP, Demello sliders, Demello front bumper with shittybuilt 12k winch with factory 55 thimble, Shittybuilt rear bumper with reverse cubes, modified front skid, DRL delete module, debadged, front skid plate, Aires headache rack, rear diff breather relocation, Carhartt seat covers, Body mount chop .... blah blah blah
    No 2008???????? The kits I am seeing is only 2010-2017... WTF?
  5. Nov 22, 2020 at 11:17 AM
    TheBeast The Beach
    I got the Fortin from tech12V group buy here. super easy install. plug and play and use oem fob. You can also add extra module for smartphone access. was about the same price.
    nice truck too.
    13CrewMax[OP] and Tundyfundy like this.
  6. Nov 22, 2020 at 11:26 AM
    Rube207
    Rube207 New Member
    Rob
    Atlanta
    2010 Pyrite Mica Limited CM
    In late 2010 they switched from the “dot” key that 2007-early 2010 had to the “g” key. This kit (like Tech12volt) is only plug and play for trucks with a “g” key. I used the tech12volt kit on my early 2010 “dot” key and had to splice a couple wires.
  7. Nov 22, 2020 at 12:12 PM
    biebs96
    PA
    Good post... and for anyone on the fence I had this on my 10 tundra for 5 years and I’ve had it on my 17 for 2 years now without any issues whatsoever.
    Great price and very easy install.
    13CrewMax[OP] and diavel like this.
  8. Nov 22, 2020 at 2:18 PM
    Donkeypuncher
    ARIZONA
    Thanks so I guess Im S.O.l unless i want to splice it up?
  9. Nov 22, 2020 at 2:19 PM
    Hartsy8
    Hartsy8 Resident Hockey Guy
    Max
    2020 MGM 1794
    Does this one keep the engine running when you open the door?
  10. Nov 22, 2020 at 2:31 PM
    TheBeast The Beach
    same as yours. 3 press unlock to start, then start running for 15 min, locks door after 5s, jump into truck and insert key and hop you go :)
  11. Nov 22, 2020 at 3:46 PM
    Hartsy8
    Max
    2020 MGM 1794
    The factory one shuts off when the door is open!
  12. Nov 22, 2020 at 4:28 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I used a Fortin Evo kit from ebay seller warmcarnow for my 08. You do have to tap a few wires. Easy to do with the posi taps he gives you.
    TheBeast likes this.
  13. Nov 22, 2020 at 5:29 PM
    TheBeast The Beach
    yep, the FORTIN and the one from OP (probably use similar fortin module) do not shut off when opening the door.
  14. Nov 23, 2020 at 5:24 PM
    13CrewMax
    13CrewMax [OP] Oops
    Southern Oregon
    2013 CrewMax
    Not enough.
    Thank you! I didn't even know about the Fortin one when I ordered this one. Oh well lol.
  15. Jan 29, 2022 at 12:39 PM
    Longtimecoming07
    Longtimecoming07 New Member
    Rick
    2012 Toyota Tundra
  16. Jan 29, 2022 at 1:52 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    2008 Salsa Red Tundra DC SR5 4x4
    Chrome delete, Sequioa grill, bed lights, LED + head, fog & tail lights, Dynamat throughout, front & rear cameras, Pheonix PX6 13" head unit, 8" subwoofer, JBL speaker upgrades, tonneau cover, custom shifter, steering wheel cover
    For those considering this, don't underestimate the usefulness of the smartphone/smartwatch app. I like that I can start the car from anywhere, unlock it if I lock my keys inside, and find it on a map if it gets stolen (or more likely, I forget where I parked). The install from 12volt.solutions was plug-and-play. You pay $39/yr for service but it's been 100% reliable and it's probably cheaper than the gas I burn while it's warming up lol.
  17. Jan 29, 2022 at 1:53 PM
    Longtimecoming07
    Rick
    2012 Toyota Tundra
    I was looking at this too
    I just don’t want the Toyota 2 start step when it kills it
  18. Jan 29, 2022 at 1:54 PM
    andnyleswillriot
    andnyleswillriot Not Remote Working
    Breckenridge, CO
    2016 DC w/ Black Topo Topper
    Toytec 3" w/2.5 Coilovers. SPC UCA's. Method Roost Bronze Wheels. 35" BFG KO2's. SPC Upper Control Arms. 2019+ TRD Pro Grill. LED headlight bulbs. 2020 OEM LED Fog lights. Tech12volts Remote Start. MobArmor Magnetic Phone Mount. Topo Topper.
    I'd recommend people go for the tech12volt kit as it supports a dude's business and not Amazon
  19. Jan 29, 2022 at 2:17 PM
    Longtimecoming07
    Rick
    2012 Toyota Tundra
    I got you I feel the same way
  20. Jan 29, 2022 at 3:10 PM
    Longtimecoming07
    Rick
    2012 Toyota Tundra
    How long has anybody used this
  21. Jan 29, 2022 at 3:23 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    Start-X is the one I put in my 2012. Very easy install and works pretty good.
