Simple question about strut shims.
Discussion in 'Suspension' started by Booney, Jul 1, 2021.
  1. Jul 2, 2021 at 9:27 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    if your shock is maxed out, it is maxed out. Sorry but the quest for vanity of adding extra lift to even the truck side to side is incorrect. Adjustable shocks don’t need spacer plates
    Darkness and Kelvin like this.
  2. Jul 2, 2021 at 9:29 AM
    Booney
    Booney [OP] New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
    Yep. We are using these UCAs:
  3. Jul 2, 2021 at 9:29 AM
    2mchfun
    I can tell you with about 3.5" of lift I am basically out of adjustment space with SPC UCA's.
  4. Jul 2, 2021 at 9:31 AM
    Booney
    It's not vanity. The shock isn't maxed out if it is at 2.5 inches. It still has another half inch to go. It's about trying to fit tires and minimizing the amount that needs to be cut or modified.
    2mchfun likes this.
  5. Jul 2, 2021 at 9:31 AM
    2mchfun
    I guess it depends on wheel offset and tires too though, because of tire to UCA clearance
    Booney[OP] likes this.
  6. Jul 2, 2021 at 9:31 AM
    Booney
    That means I am good then, even with spacers.
  7. Jul 2, 2021 at 9:34 AM
    Booney
    Offset is +1. Tire is bigger than 35X12.50.
  8. Jul 2, 2021 at 9:35 AM
    Badknees
    Badknees New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    With your application using an adjustable coil-over, you should be able to adjust the hubs to change the spring compression and offset for additional weight. If after the lift we assume that the pass. side is at 3" and the driver's at 2.5", then adjust the driver's side coil-over hub to compress the spring more and compensate for the extra weight, bringing it up to match the pass. side.
    Hbjeff likes this.
  9. Jul 2, 2021 at 9:38 AM
    2mchfun
    Not sure but it seems you might have tires that will hit your fenders because the offset will have them pushed out beyond the well space, not a problem when parked, but when the suspension cylces watch out.
  10. Jul 2, 2021 at 9:42 AM
    2mchfun
    I think OP is just trying to get all he can and reserve adjustment for when the springs become tired and any settling occurs. Not going to hurt adding a shim, but I would do both sides equally and fine tune with coilover adjustment.
  11. Jul 2, 2021 at 9:44 AM
    Badknees
    Badknees New Member
    South Carolina
    :thumbsup:
  12. Jul 2, 2021 at 11:31 AM
    Booney
    Exactly.
    2mchfun[QUOTED] likes this.
  13. Jul 2, 2021 at 11:33 AM
    Booney
    Yeah, that is my biggest concern. If that happens I will be forced to change tire size back to what I originally wanted. The only reason I picked that size is because they said the size I wanted isn't available which was LT285/75R17.
  14. Jul 2, 2021 at 11:36 AM
    2mchfun
    And or the wheel offset, either way, good luck. The mods game is like most everything, one thing leads to fifteen others!
    Booney[QUOTED][OP] likes this.
  15. Jul 2, 2021 at 12:38 PM
    Booney
    You got that right. Next is headers and the bumper/winch, maybe not in that order. I am thinking about regearing it but I want to try it out some with the new tires and get that all settled in before I do that. The topper is scheduled to ship on the 9th of July so I will have it on the truck week after next.
  16. Jul 2, 2021 at 1:43 PM
    DUKFVR
    DUKFVR New Member
    Houston & Young County TX
    2020 Cement Tundra DC SR5, Stage 1 Icon kit, LT75/60/20 Toyo AT III, Ranch Hand Midnight Bumper Replacement
    I would go to another shop. They evidently don't know what they are talking about.
  17. Jul 2, 2021 at 2:43 PM
    2mchfun
    Hmm I got a quote for $1308 for five Yokohama GO15 285 75 18 two weeks ago, went to put a down payment so they would order, guy calls supplier, two months out. Asked about Toyo AT3, nope, I forget why, Falken wildpeak yes in two weeks $1695. Nitto RG, loud when worn down, nope, guess two months it is. :fingerscrossed: Will be getting a great highway tire though for a good price.:burnrubber:
  18. Jul 2, 2021 at 3:31 PM
    Kelvin
    Kelvin New Member
    If he bottoms out the shock with a spacer on it then it can get damaged badly.
  19. Jul 2, 2021 at 3:42 PM
    #49
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    Do yourself a favor and give Coachbuilder a quick call. From my understanding he recommends keeping adjustable coilovers at the same height and making up the difference for any driverside lean with a shim. And think you're gonna need the bolt kit he sells for the top hat when adding a shim.
  20. Jul 2, 2021 at 3:49 PM
    #50
    Booney
    Good luck. I hope they come in when they say they will.
    1695 for the Fallkens sounds high. I got the Wildpeaks for $1248 (LT315/70R17) and some warranty thing for $207 more. I am going to see if I can ditch the warranty thing. They said they already have them waiting for me. I hope they aren't blowing smoke up my skirt. They should have a pile of parts waiting for me. The only thing they need is the shackles which I ordered and are due in about three weeks.
  21. Jul 2, 2021 at 3:50 PM
    #51
    Booney
    Way ahead of you but thanks. I already have the shim and bolts from Coachbuilder.
    Casper3[QUOTED] likes this.
  22. Jul 2, 2021 at 4:01 PM
    #52
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    :thumbsup: Just wasn't sure if you were second guessing yourself by using a shim to correct for the lean. Sounds like the service manager could use a talk with him.
  23. Jul 2, 2021 at 4:05 PM
    #53
    Booney
    I am already trying to figure out the best way to get things done without a fight but not totally adverse to pulling the parts and finding someone else to do it.
  24. Jul 2, 2021 at 4:13 PM
    #54
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    I didn't deal with all that bs and just did it myself, good luck with the install and post some pics when it's all said and done.
  25. Jul 2, 2021 at 4:17 PM
    #55
    2mchfun
    Is that not what bump stop extensions are for?
  26. Jul 2, 2021 at 4:17 PM
    #56
    Booney
    I wish I could do that. I would if I was a little younger or had a lift.
  27. Jul 2, 2021 at 4:21 PM
    #57
    Booney
    Coachbuilder says that no further action (extended bump stop) is required for one shim.
  28. Jul 2, 2021 at 4:25 PM
    #58
    2mchfun
    Are you not gaining lift with the coilovers? Or are you installing a bump stop extension kit? I gather you are lifting 3", so I hope you have bump stop extensions in your parts.
  29. Jul 2, 2021 at 5:02 PM
    #59
    Kelvin
    Kelvin New Member
    So…limit travel on those nice new high dollar shocks? Got it.
    They also claim they aren’t spacers. But guess what? They’re spacers.
    OP do what you want. Ain’t my truck. IMO the right course of action here is more spring rate.
    Darkness and Hbjeff like this.
  30. Jul 2, 2021 at 5:11 PM
    #60
    2mchfun
    Yep, limit travel to keep the shocks in working condition, they are not cheap and a few inches of travel is sufficient for just about any bumps in the normal roads. If going off road, go slow and expect to hit the limit and bottom out sometimes anyway.
