Side view mirrors
Discussion in '2.5 Gen Tundras (2014-2021)' started by PaulO, Dec 27, 2016.
  1. Dec 27, 2016 at 4:38 PM
    PaulO
    PaulO [OP] New Member
    2014 Tundra double cab
    Hi I Just bought a 2014 Double cab and I want to replace the stock mirrors with the ones that manually pull out when you are trailering. The dealer tells me the ones that he ordered have blinkers on them and the ones that I have now do not have blinkers. I will have the dealer install them....My question is can they easily make it so the blinkers will work??? The parts guy was not sure.....thanks for your help....
  2. Dec 27, 2016 at 4:59 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    It seems that most wiring harnesses going to the side view mirrors come with the wiring for the blinker. At least this is the case I have seen on install instructions on the SR5 trim level. The installs I have watched have gone from the black normal side view mirrors to the trailer ones with the built-in blinker and all works as it should.
  3. Jan 13, 2017 at 6:18 PM
    balou
    balou Texas Tundra
    2016 tundra cewmax 4x4 tss option
    bilstein 5100 adj front shocks led lights for bed
    I have a 2016 sr5 tss. I had regular power and heated mirrors. I installed oem towing mirrors and the blinkers and running lights work. Very happy with product and would recommend. Give @Roman a call he can hook you up.
  4. Jan 13, 2017 at 10:00 PM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    Lights on the OEM tow mirrors will work...the mirrors are plug and play. I put them on my 2015 SR5 with no issues.
  5. Jan 27, 2017 at 5:07 PM
    Tony'sToy
    Tony'sToy New Member
    Tony
    Savannah, MO
    2015 Toyota Tundra SR5 TRD OFF ROAD
    6" Rough Country lift kit 20" BMF Novakane Wheels 35"X12.50R20 Nitto Trail Grappler MT AIRAID Cold Air Intake Flowmaster Outlaw Exhaust System Bushwacker Pocket Style Fender Flares Recon Projector Headlights (Smoked) Recon 35 Watt Hid Headlights Recon 35 Watt Hid Foglights Recon LED Brake Lights (Smoked) Recon LED 3rd Brake Brake Light (Smoked) Recon LED Tailgate Light Bar(Smoked) Recon LED Big Rig Light Bar (Smoked) Recon LED Bulbs Every Bulb Location Rough Country 30" Bumper Mount Single Row Light Bar. Headlight Revolution LED Interior Light Kit Replaced Every Bulb Blue LED Bulbs Toyota TRD PRO Grille (Black) TRD Shift Knob All Windows Tinted 20% WeatherTech In Channel Window Deflectors WeatherTech Floor Liners Extant Encore Tonneau Cover
    I'm glad I found this thread. I have a 2015 Toyota Tundra SR5 TRD OFF ROAD. I was wondering the same thing, if I got the Tow mirrors if the led turn signal lights would work because my factory side mirrors do not have that option. I called auto anything and asked them and also realtruck.com about the tow mirrors with the LED turn signals and they told me if your truck was not equipped with that option that function would not work? So they will work?????
  6. Jan 28, 2017 at 3:55 PM
    balou
    balou Texas Tundra
    They worked on mine and I didn't have the running or blinkers on original mirrors when I bought truck
