Side Mirror
Discussion in '2.5 Gen Tundras (2014-2021)' started by BTbt, Feb 21, 2021.
  1. Feb 21, 2021 at 3:28 AM
    BTbt
    BTbt [OP] New Member
    My driver side mirror cracked. Much of a job to replace ?
  2. Feb 21, 2021 at 4:33 AM
    RainMan_PNW
    RainMan_PNW SSEM #82 RGBA #4 “That Guy” Vendor
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Fairly easy... but you’ll need to get glad that matches the features in your truck (i.e. BSM, defrost, turn signal, auto-dim).
    Then, tilt the mirror fully up. Insert a plastic pry tool between the mirror and lower housing and lever the glass in a straight line up (straight line as in the plane of the glass). It will pop off the mount and then you can unplug the various connectors. Reconnect to the new glass and pop it back into the bracket.
  3. Feb 21, 2021 at 4:40 AM
    BTbt
    Thanks, sounds the same as my gm truck, replaced two on that one
  4. Nov 18, 2021 at 9:38 AM
    TSUalum05
    TSUalum05 New Member
    I'm having a very tough time connecting mine back in...When I search youtube, no one has the same type of mirror snaps. 2014 Toyota Tundra with power/defrost...Any help is much appreciated.
