Side mirror glass transfer possible
Discussion in 'General Tundra Discussion' started by Jcmf52, Oct 4, 2021.
  1. Oct 4, 2021 at 2:20 PM
    Jcmf52
    Jcmf52 [OP] New Member
    Rob
    2018-1794 S/C
    Shorty antenna Trifold hard top tonneau cover Center console safe Center console tray Rhino liner TRD air filter TRD rear sway bar TRD front sway bar Center console wireless charger kit Remote start Black 4x4 emblem swap
    So, while backing into single car garage, I hit the side and busted the side mirror housing (glass is still intact).
    Side mirror had all bells and whistles; power folding, heated, BSM, turn signal, and auto-dim.
    looking at the mirror replacement is ~$1100 from dealer (can get a couple hundred cheaper searching web)
    was wondering if it would be possible to get a “cheap” OEM power folding mirror replacement and swap out the glass with the existing glass with all the bells and whistles?
  2. Oct 5, 2021 at 8:26 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    The glass, unfortunately, is the cheapest part, and the "features" in it are just a couple of LEDs and the heater wires attached to the back. Everything else is in the actual frame, including the necessary wiring. You might be able to surf the classifieds here and on FB Marketplace and CL and get lucky with a set of factory take-offs from someone that upgraded to tow mirrors. Or consider getting a set of Boost Auto tow mirrors for yourself (a full set will run less than what you are looking at for a single factory mirror).
  3. Oct 5, 2021 at 8:43 AM
    Jcmf52
    Rob
    2018-1794 S/C
    After removing the glass, it looks like the turn signal, bsm, auto dim, and heat are all built into the glass and not the actual unit. These are all wired to the same connection type on all side mirrors.
    I am hoping to remove the broken mirror and see if the wiring can be pulled out and used on cheaper power folding mirror.
    dont want to buy tow mirrors, as I do not tow often enough to want to keep on.
  4. Oct 5, 2021 at 11:37 AM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Jcmf52[OP] likes this.
  5. Oct 5, 2021 at 11:56 AM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
  6. Oct 5, 2021 at 3:28 PM
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    Is this the piece you’re ultimately looking for?
  7. Oct 5, 2021 at 6:52 PM
    Jcmf52
    Rob
    2018-1794 S/C
    Yes, that is the piece needed!
    is there a part number just for that, or only disassembled models?
  8. Oct 5, 2021 at 6:58 PM
    thomasbus337
    2020 TRD Sport DC
    It’s not available separately, I had it left over after I did some retrofitting. I’ll PM you
  9. Oct 5, 2021 at 7:03 PM
    Jcmf52
    Rob
    2018-1794 S/C
    Did you have a write up or pictures/video of your mirror project?
  10. Oct 13, 2021 at 8:14 PM
    Jcmf52
    Rob
    2018-1794 S/C
    Alright, so project complete!
    Was able to replace the outer housing with a new donor from another power folding mirror with puddle lights (thanks thomasbus337!), while keeping the same internals and glass.
    Did the repair with the mirror attached to truck. Entire process took about 20 minutes, and saved $1,000+ versus replacing entire mirror assembly with OEM (could not find aftermarket that had all the same features).
    Starts with disconnecting the glass from the power mirror mounts (I’m sure there is a better way to remove the glass, but this was best and most effective method I tried)6783F633-78A5-44FA-B6E2-C295AA4FF884.jpg
    Disconnect the the auto-dim and bsm/turn signal connector from glass
    Remove the 4 screws holding the power mirror to the internal “arm”, then disconnect the wiring harness connected to it
    Remove the 2 screws connecting the internal arm to the outer housing, and disconnect the puddle light. Also removed the mirror cap
    Pull the outer housing away from truck and then up slightly, sliding the outer housing off the internal arm
    Tundra805 likes this.
  11. Oct 13, 2021 at 8:24 PM
    Jcmf52
    Rob
    2018-1794 S/C
    Cut off post, here is rest:
    video of pulling off outer housing
    https://youtu.be/Ue1EqtSM2_M
    Replaced double side tape on puddle light and installed on new outer housing.
    Install new outer housing in reverse order
    Picture of wiring through pivot hinge:
  12. Mar 29, 2024 at 8:50 PM
    Nick W
    Nick W New Member
    Nick
    @Jcmf52 years later but thanks for posting your findings. I bumped my gate and broke the same part of my mirror. Found some mirrors from a lesser trim level than my truck on craigslist but I swapped what I needed and left the guts and glass and it’s good as new. Piece of cake with your instructions. I absolutely would have broken the glass without.
  13. Mar 29, 2024 at 9:50 PM
    Jcmf52
    Rob
    2018-1794 S/C
    Glad you could use the post for your repair!
    looking back, still shocking how much the mirror assembly replacement is
