Shudder at Low Speed, Low RPM, Old Tranmission questions
Discussion in '1st Gen Tundras (2000-2006)' started by 1Cor1031, Aug 9, 2023.
  1. Oct 7, 2023 at 12:58 PM
    EmergencyMaximum
    EmergencyMaximum Synthetic member
    That's a little bizarre. Driving harder pushes clutches closer together eliminating shudder? From what I've heard, if they're slipping, driving harder isn't going to keep them from slipping. Quite the opposite on fact.
    But I am not a mechanic and I hope he's right:hattip:
    shifty` likes this.
  2. Nov 2, 2024 at 10:35 PM
    gomaric12
    gomaric12 New Member
    David
    Hey, did you endup fixing the issues please. I'm having the same issues. Thanks
  3. Nov 3, 2024 at 6:01 AM
    It looks like @1Cor1031 hasn’t logged into the forum since late 2023, so you may be talking to a ghost.
    Note ABS sensors will cause shudder at low speeds also. Nothing do do with transmission. Likewise using the wrong fluid in an LSD rear end in our 1st gen Tundras will also cause shudder at low speeds while turning, especially in revers while turning, almost like a skipping sensation. Describe your symptoms more elaborately, when it happens, what it feels like.
    FrenchToasty likes this.
