Show your Tonneau cover
Discussion in 'Tonneau Covers, Caps and Shells' started by G-manCO, Nov 13, 2017.
  1. Sep 21, 2018 at 3:39 AM
    #61
    Cajuntex
    Cajuntex New Member
    2018 Tundra Limited CrewMax 2wd
    Added Digital Processor,amp,speakers and sub; ESP storage tray, Driver Handle, husky mats, Diamondback se, TSS rims and BFG KO 2s
    1 month with diamondback se. Had a rollnlock on previous truck. Both have pros and cons. My rollnlock leaked a little, took up space in small bed with canister, sheared drain tubes loading plywood, but easy to have access to entire bed. The diamondback has had no leaks so far, looks better, but if you want to access the entire bed you need to remove the middle support. It’s only 4 clamps but will require basically a reinstall. Not the easiest for one person and will take some time. Not as simple as a retractable top. Fortunately I really don’t need access to the whole bed often so I still vote for the diamondback.
  2. Sep 21, 2018 at 4:59 AM
    #62
    War Machine
    War Machine SSEM # 5 3MW
    Bakflip MX4. Very happy with it so far.
    tundra403 likes this.
  3. Sep 21, 2018 at 6:20 AM
    #63
    dugfur
    dugfur New Member
    doug
    2016 limited DC
    Hey Meltz, what kind of steps are those?
  4. Sep 23, 2018 at 9:04 AM
    #64
    SAG_TX
    SAG_TX New Member
    Steven
    2019 Tundra TRD Pro White/2016 4Runner TRD Pro White
    Does anyone have a cover that folds up to the back window and still allows motorcycles to be loaded? Without removing the rail system or cover.
  5. Sep 25, 2018 at 8:28 AM
    #65
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
    Rugged 2 cover. Looks good tiny bit of water after a very heavy storm.
    Wish it folded all the way up though. Got it used for 280 so I couldn’t pass it up.
  6. Oct 6, 2018 at 8:27 PM
    #66
    fatalkhaos
    fatalkhaos New Member
    2019 Tundra TRD PRO CM
    Sway Bar 20x10 Fuel Assault 295/55r20 Toyo AT
    The undercover flex ultra flex or armorflex allow for flip up and still can load motorcycle. Buddy has the ultraflex and still can load his bike but usually takes the 10 min to pull it off if going distance. I like the carpeted bottom of ultraflex but the armorflex is sick looking with the LINEX top
  7. Oct 6, 2018 at 10:09 PM
    #67
    SAG_TX
    SAG_TX New Member
    Steven
    Thank you!
  8. Oct 7, 2018 at 6:16 AM
    #68
    Iceman09
    Iceman09 New Member
    2018 Platinum in Blazing Blue
    Undercover Ridgelander Tonneau cover
    I have an undercover ridgelander. At first, this cover was a pain. It leaked, one of the latches didn’t work right, and it didn’t come with the rubber strips for the vortex bars. However, the company sent me new latches. Rhino rack sent me new rubber strips. To fix the leakage, I got a can of flexseal and sprayed under the mounting rails where they meet the bed. The leaking has significantly improved. Now I’m starting to like this cover. It took a couple of months though. Haha
  9. Oct 7, 2018 at 6:20 AM
    #69
    UnderCover, it came already with the Tundra, does the job, when loading it up, it's like video game Tetris
    Hoff likes this.
  10. Oct 14, 2018 at 11:12 AM
    #70
    Tony v
    Tony v Member
    2017 SR5 CrewMax
    Took a trip to Phoenix this weekend. Have an Extang 2.0. Drove through some rain, and everything inside was pretty wet. This cover is not even close to water tight.
    Not good!!
    DalTee and fatalkhaos like this.
  11. Oct 14, 2018 at 11:26 AM
    #71
    fatalkhaos
    Damn. Well I will check that off of my list of possibilities. Leaning hard on the Undercover Armor Flex
  12. Oct 14, 2018 at 11:28 AM
    #72
    Tony v
    Tony v Member
    2017 SR5 CrewMax
    It was a heavy storm, but I had higher expectations. Even a carwash lets some water in.
  13. Oct 16, 2018 at 10:43 AM
    #73
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    Hey I’m getting the same thing. It has a three year warranty so I’m gonna try to take it back
  14. Oct 16, 2018 at 10:47 AM
    #74
    DalTee
    DalTee New Member
    Dal
    I just called my installer Killam out of East Windsor, CT - I explained my situation and she said to bring it right over.
    The MOMENT I have a chance I’m headed over.
  15. Oct 21, 2018 at 12:08 PM
    #75
    Jgarcia6820
    Jgarcia6820 New Member
    Jhonny
    2013 tundra rock warrior
    Its just a matter of the two bolts with nuts on either side and the cover comes out?
    I need access to my bed for motorcycle transport and just in case it doesn’t fit with it rolled I wanted to see how easy it is to remove, thanks in advance
  16. Oct 21, 2018 at 12:21 PM
    #76
    Jgarcia6820
    Jhonny
    Second this
  17. Oct 21, 2018 at 2:45 PM
    #77
    doggiecareman
    doggiecareman YOLO / Best to do it with a Toyota
    Eric
    North Central CT
    Tundra Army Green Limited Double Cab TRD Off Road 2021
    TRD dual exhaust/Factory running boards/center console safe/Truxedo X15 Tonneau/ceramic coated/ceramic window tint/BFG KO2's/swing cases/debadged
    I will be picking up a Truxedo Pro x15 tomorrow and installing it. Struggled back and forth a lot with whether to go trifold, retractable, roll top or soft top. The big thing for me is that if I want immediate full use of the cab, the retractables box takes up too much room for me. The trifolds when folded up against the cab totally block the view and the roll tops also take up too much room unless you also take them off. I am still getting used to the CM size bed as I had the DC prior to this and miss the extra bed space. I installed the swing box fender storage box on each side and those are lockable. I will post when I get it set up. I also like the lifetime warranty on the Truxedos and figure I could always switch out to another type of system later if need be.
    https://www.youtube.com/watch?time_continue=2&v=OHOXbrQE0XQ
  18. Oct 21, 2018 at 3:01 PM
    #78
    havasuTRD
    havasuTRD New Member
    Brett
    2017 Tundra crewmax TRD 4X4
    How much did this one run ya? Thinking of pulling the trigger on one very similar.its called the American roll cover by truck covers USA. My mechanic quoted me $1600
  19. Oct 21, 2018 at 3:16 PM
    #79
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
  20. Oct 21, 2018 at 6:00 PM
    #80
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Yes the two bolts on the back.
    Jgarcia6820[QUOTED] likes this.
  21. Oct 21, 2018 at 6:02 PM
    #81
    Jgarcia6820
    Jhonny
    I have the same concerns need full access to the bed please update your review about it. Looking forward to it
  22. Oct 23, 2018 at 7:16 PM
    #82
    doggiecareman
    Eric
    North Central CT
    Put it on yesterday and was a little aggravated with the install as the width of the rear folding bar is right at 1/16th too wide and you have to finagle getting it between the rails. It's the extra width from the factory spray in liners that create tightness as the rails have that extra material to displace them. The front part of the bed behind the cab was a challenge also for the same reason. Definitely won't pop off and on as easily as advertised as the snugness takes a bit to maneuver. Other than that it's working well and easy to adjust then tension setting. It's rigid for a soft cover and definitely does not take up muck space when rolled up and currently doubt I will see a need for complete removal anyway. Will post pics soon.
  23. Oct 25, 2018 at 9:27 AM
    #83
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    That seems to be a reasonable price; installed. I seem to recall about 1200. I installed it myself in about 3 hours.
    havasuTRD[QUOTED] likes this.
  24. Oct 25, 2018 at 9:37 AM
    #84
    Yotaman18
    Yotaman18 New Member
    Corey
    Houma, LA
    2018 Platinum 4x4 Bitching Blue
    15404852647033073485352566223580.jpg I went with the GatorTraxx retractable. The canister is huge but that is my only complaint thus far.
    Keeps my bed bone dry so far and the rain is never ending lately here lol 15404854372971159319674053403404.jpg
    And I love the look!
    equin and doggiecareman like this.
  25. Oct 30, 2018 at 5:15 PM
    #85
    TundraXPLover
    TundraXPLover New Member
    Clif
    NC
    2018 CM 4x4 XP
    Drove 4 hours to buy an UnderCover Flex. Get there and the seller brings out this Rugged Cover 2. He didn't know what he had and posted it wrong. Gave me the cover for my troubles and I have to say, I like it! Free!
    doggiecareman and Sharpienads like this.
  26. Oct 30, 2018 at 6:26 PM
    #86
    Tony v
    Tony v Member
    2017 SR5 CrewMax
    Well that doesn’t suck.
  27. Oct 30, 2018 at 6:35 PM
    #87
    JoeDenver
    JoeDenver New Member
    Joe
    Denver
    2018 Crewmax MGM
    Lomax Tonneau, Line-X Bedliner, Clear Mask, Chrome Tip Exhaust, Stubby Antenna
    I have a Lomax cover and it’s super sleek. Has scratched but that was when the dealer took it off to put on my new truck. I will try and pst a pc but if not here’s a link.
    https://www.agricover.com/lomax/
  28. Nov 3, 2018 at 7:14 AM
    #88
    Bob S
    Bob S New Member
    Bob
    2018 Vintage Brown Toyota Tundra
    Shorty Antenna; Weathertech Ventvisors, 12 Volt Solutions Remote Starter
    Question for the "UnderCover Flex" users ... did you remove the stock tie-down rail system to install the cover or did you leave it in place ... ? I see that I can get the cover either way and I don't know if one way is better than the other ... ! I have never used the tie-downs but, of course, I will probably need them the week after removing them ...
    Bob S
  29. Nov 3, 2018 at 1:13 PM
    #89
    Cement1
    Cement1 New Member
    2019 Tundra Limited
    Rail system didn’t have to be removed but you can no longer use your bed cleats for tie downs. Only down side about this cover.
  30. Nov 4, 2018 at 5:23 AM
    #90
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    Rugged Cover- works perfectly so far and easy on and off. It is about 15 pounds lighter than the factory tonneau that my 17 Tacoma had.
    TundraXPLover likes this.
