Show us your latest detailing purchase
Discussion in 'Detailing' started by Pudge, Oct 8, 2019.
  1. Mar 25, 2025 at 12:16 PM
    #1471
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    I use Chem-X Stars and Stripes when I need a quick wash. Can wash and dry the truck, completely touchless in 20 minutes. Chem-x also has Old Glory Touchless available.
  2. Mar 25, 2025 at 12:40 PM
    #1472
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    perfect time to do a conversion...I ditched those cartridges right from the get go.
    https://rv-mods.com/store/
  3. Mar 26, 2025 at 9:29 AM
    #1473
    kirkb
    kirkb Tired New Member
    DFW
    2024 Tundra Limited 4x4 WCP Nightshade
    Forgive the stupid question. Is it possible to use my regular old air compressor to power a foam cannon instead of buying a dedicated pressure washer?
  4. Mar 26, 2025 at 9:31 AM
    #1474
    eddiefromcali
    Eddie
    100% Stock
    it doesnt work that way.
    T-Rex266 likes this.
  5. Mar 26, 2025 at 11:03 AM
    #1475
    SilveradoSwap
    You could buy a foam cannon for a garden hose, do some research first. You could also opt for an iK foam sprayer.
    https://www.iksprayers.com/en/ik-foam-pro-12-82676.html
    For $150, if it fits the budget, you can get a Ryobi PW that is great for a backyard detailer.
    https://youtu.be/zwtjpCMLcls?si=ojjcxvBfUZt5lZMN
    kirkb[QUOTED] likes this.
  6. Mar 26, 2025 at 11:30 AM
    #1476
    eddiefromcali
    Eddie
    100% Stock
    lets not confuse the poor guy...those are not foam cannons...those are foam guns and will not give the same results as a cannon, not even close.
    They are a good solution if you want some suds on your paint though...just got to use the right wash.
  7. Mar 26, 2025 at 12:27 PM
    #1477
    SilveradoSwap
    Agreed. I will say you still need to pick your wash regardless of using a dedicated foam cannon. Foam cannons can vastly vary as well.
    eddiefromcali likes this.
  8. Mar 26, 2025 at 12:27 PM
    #1478
    kirkb
    DFW
  9. Mar 26, 2025 at 12:29 PM
    #1479
    eddiefromcali
    Eddie
    100% Stock
  10. Mar 26, 2025 at 12:30 PM
    #1480
    SilveradoSwap
  11. Mar 26, 2025 at 12:31 PM
    #1481
    eddiefromcali
    Eddie
    100% Stock
    he doesnt have a pw....comparing the tornador to a foam gun...Id go gun. Cannon if you want to get a lil pw. I love my Karcher cube
    kirkb likes this.
  12. Mar 26, 2025 at 12:44 PM
    #1482
    SilveradoSwap
    You are not getting any better results with a foam gun compared to the Tornador. The iK will outperform both.
    You dont always need a 1” thick layer of foam anyways, people get caught up in the amount of foam, it can be comical really. If you are using a soap that actually starts to break down dirt and debris then it makes way more sense. A ph neutral soap isn’t the best choice for doing that.
    kirkb likes this.
  13. Apr 8, 2025 at 8:40 AM
    #1483
    briarpatch
    briarpatch New Member
    The only foam cannon that I know of that works that way is one by Griots Garage....and they call it their 'Air Foamer sudsing gun"......I've never used one, but from the video clips I've seen....it's some pretty thick foam.
    https://www.griotsgarage.com/air-foamer-sudsing-gun/
    SilveradoSwap and kirkb[QUOTED] like this.
  14. Apr 8, 2025 at 9:11 AM
    #1484
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Dang 4-8 cfm @ 90psi....das a lotta air!
    Never saw one of those air powered foam guns. I'd still stick with a pressure washer and a foam cannon. Aim for 2gal/min @1000psi in your pressure washing choice.
    kirkb and eddiefromcali like this.
  15. Apr 13, 2025 at 11:16 AM
    #1485
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
  16. May 1, 2025 at 11:18 AM
    #1486
    SilveradoSwap
    Tested it and got 1.65gpm. Will test pressure if my gauge goes that high.
  17. May 1, 2025 at 11:28 AM
    #1487
    eddiefromcali
    Eddie
    100% Stock
    uses standard QD tips? Looks like a nice lil unit
  18. May 1, 2025 at 11:30 AM
    #1488
    SilveradoSwap
    Yes, for $150, seems like a good buy. Hose is 40’, and the gun is pretty nice
  19. May 1, 2025 at 11:45 AM
    #1489
    eddiefromcali
    Eddie
    100% Stock
    Do like that it doesn't use cheapo plastic connection points. Just watched a review...900ish psi and 1.6gpm real world numbers right out of the box. Respectable for $150.
  20. May 1, 2025 at 1:16 PM
    #1490
    SilveradoSwap
    I tossed around buying an Active unit or the newer Adams machine, but then watched vids on this and figured I would save a few bucks.
  21. May 2, 2025 at 8:01 PM
    #1491
    yosh2000
    yosh2000 New Member
    Denver
    '17 MGM CM Tundra
    Same. Now go get a Uber flex or flexizilla hose and get 0.15 more gpm! Cars with keav on yoitibe got 1.8 w Uber flex, 4.0 nozzle and his new fav Amazon handle. I got mine this week, stoked to get it going! RO filter comes Sunday for the final piece of the puzzle (already have the DI and dog food bucket to store my 0 TDS water!)
    keeping w thread title, decided to start with this line of products. Should work out.
  22. May 2, 2025 at 8:32 PM
    #1492
    SilveradoSwap
    The uberflex is not reinforced and I heard causes surging issues, not interested in that. Be curious to see how it works out for you.
  23. May 2, 2025 at 9:24 PM
    #1493
    The flexzilla one I had got a hole in it quickly from a rose thorn…it also sucked to wind up and/or stretch out.
  24. May 2, 2025 at 10:55 PM
    #1494
    yosh2000
    yosh2000 New Member
    Denver
    '17 MGM CM Tundra
    From videos, only machine that has issues w Uber flex is the actives. All the other $100 machines it works just fine supposedly
  25. May 3, 2025 at 9:27 AM
    #1495
    SilveradoSwap
    Tbh, 40ft seems fine for now
  26. May 3, 2025 at 9:31 AM
    #1496
    yosh2000
    yosh2000 New Member
    Denver
    '17 MGM CM Tundra
    Right, but the 0.15 gpm gain is worth it alone, as well as not having the hose memory of the stock one
  27. May 3, 2025 at 10:11 AM
    #1497
    SilveradoSwap
    Sorry, I am not sweating a .15 gallon loss, I’m a guy who washes his family vehicles on the back driveway, lol.
  28. Jun 5, 2025 at 10:45 AM
    #1498
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    No pic, but just ordered The Rag Company Eagle Edgeless 450 Amazon exclusive. I'm ordering now, cuz TRC is upping their prices on their microfiber by at least 25% on some of their offerings. For instance, the Creature Edgeless just went from $24.95 to $31.95 (qty 10). Similar on the Edgeless 365 (just went up $5). These are Amazon prices, but closely match the TRC site. So if you're looking to get some TRC microfiber, some of them haven't gone up yet (like the 450 I just ordered).
    eddiefromcali and oddhours like this.
  29. Jun 5, 2025 at 7:38 PM
    #1499
    eddiefromcali
    Eddie
    100% Stock
    Love TRC stuff
  30. Jun 6, 2025 at 2:48 AM
    #1500
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    I am not Familiar with the TRC products but am interested. Could you please post additional links of the products you like that are available on Amazon at the old prices?
    Thanks
