Show us your latest detailing purchase
Discussion in 'Detailing' started by Pudge, Oct 8, 2019.
  1. Mar 18, 2024 at 11:18 AM
    #1321
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'm a water spot remover experimenter - if I see one I haven't used, I buy it and try it. So far the only one I've seen that works, albeit with elbow grease, is some stuff made in HI. They say you don't need tools or machinery to apply it, and you don't, but I bet a small buffer would make it a whole lot easier because this stuff only does the trick if you really work it into the glass with a circular motion.
  2. Mar 18, 2024 at 12:38 PM
    #1322
    War Machine
    War Machine SSEM # 5 3MW
    For glass, and glass only, Barkeeper’s Friend in liquid form takes them right off. It’s cheap and you can get it at Walmart. It’s a great household cleaner also. Do not let it get on your paint though.
    Short of using a polisher, I think the best thing I’ve tried for water spots on paint is Optimum MDR.
  3. Mar 18, 2024 at 12:47 PM
    #1323
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    This?
  4. Mar 18, 2024 at 12:57 PM
    #1324
    War Machine
    Yes sir. Someone recommended that to me for some shower doors with major hard water deposits years ago. That stuff is amazing. It’s got abrasives in it, but I haven’t seen any negative effects on glass. I just let it sit a minute and wipe gently.
    There’s a spray version also but it doesn’t seem as effective to me.
  5. Mar 18, 2024 at 1:01 PM
    #1325
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
  6. Mar 18, 2024 at 1:16 PM
    #1326
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Sweet. Another one I'm buying. Thanks!
  7. Mar 18, 2024 at 1:50 PM
    #1327
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    You can save yourself $5 and get an Uberflex instead of the flexzilla (flexzilla pressure washer hose is made by uberflex).
  8. Mar 18, 2024 at 2:10 PM
    #1328
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Too late lol
  9. Mar 18, 2024 at 2:50 PM
    #1329
    Danimal86
    Daniel
    Sacramento, CA
    Ehh, the green will match the sun joe better anyways :)
  10. Mar 18, 2024 at 3:50 PM
    #1330
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The Sun Joe is blue :facepalm:
  11. Mar 18, 2024 at 4:04 PM
    #1331
    Danimal86
    Daniel
    Sacramento, CA
    damn....i thought they were yellow/green.
  12. Mar 18, 2024 at 4:30 PM
    #1332
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The first ones were blue I guess
  13. Mar 29, 2024 at 5:44 AM
    #1333
    Damie Street
    Edsel
    South Carolina
  14. Apr 3, 2024 at 1:48 PM
    #1334
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    Hyperwash is on sale at Woot for $18.59 delivered. I'm having a hard time not picking one up, as I'd like to try it, but still have 3/4 gallon each of Gold Class and 3D Pink soap.
  15. Apr 3, 2024 at 2:37 PM
    #1335
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    Forum has tons of guides/stickies all about. Generally you'll want two buckets, a pH neutral soap, a quality microfiber wash mitt and drying towel, and a sealant of your choice for protection.
    Nonacid cleaner for wheels along with a couple wheel brushes, 3D glass concentrate is good for glass and a gallon jug will last you a lifetime and relatively cheap (use it around the house too).
    YouTube the two bucket wash method and you'll be well on your way.
    ToyoMafia, jmladdy[QUOTED] and Fotnot like this.
  16. Apr 3, 2024 at 11:17 PM
    #1336
    PKFan
    @Ckatz53 - how do you tell if a wheel cleaner is acid vs non-acid?
  17. Apr 4, 2024 at 1:30 PM
    #1337
    Ckatz53
    Ckatz53 Newish
    MD
    It'll be advertised as such. Meguiar's Non-acid is what I use. Gallon, dilutable.
    ToyoMafia likes this.
  18. Apr 4, 2024 at 2:01 PM
    #1338
    PKFan
    That's what I figured, thanks. It's the acid ones that don't seem to call it out. I have some stinky Turtle Wax Hyper Foam that does a good job, but isn't so kind to my van's 20+ year old aluminum wheels that seem to have lost their coating, so I guess it's an acid product. I think I'll try the Nanoskin non-acid cleaner which will dilute 4:1 so I'll be good for a while.
  19. Apr 4, 2024 at 3:58 PM
    #1339
    briarpatch
    briarpatch New Member
    Unless you are really in need of a wheel cleaner....why not just use a diluted APC to clean wheels? I have wheel cleaners on the shelf, but rarely go to them....would rather use my Bilt Hamber Surfex HD at 10:1. It's great for tires and wheel wells too....and it's never damaged a wheel yet.
  20. Apr 4, 2024 at 5:04 PM
    #1340
    I just use this and this depending what vehicle I’m cleaning (more of a sports veh vs typical vehicle)
  21. Apr 5, 2024 at 10:04 AM
    #1341
    Ckatz53
    Ckatz53 Newish
    MD
    Some APC if not diluted properly can damage stuff like some powder coating finishes. So depending on what wheels you have, you could cause damage that you can't clean away and they'd need to be refinished.
  22. Apr 5, 2024 at 10:09 AM
    #1342
    briarpatch
    On the up side.....have used this on powder coated wheels without an issue. I'd hesitate to go any stronger, however
  23. Apr 5, 2024 at 1:35 PM
    #1343
    Ckatz53
    Ckatz53 Newish
    MD
    Yeah it's just some, and honestly my experience is no telling if/when it's going to do it. I've just seen problems with folks chemically burning cheaply powder coated stuff with APC. Obviously, brand of APC and whatever dilution they used could cause it too. I'm just hesitant to do so on stuff I'm not sure how it's going to react (new to me cars). On my own stuff, I've used APC diluted 10:1 no issues...but I knew it wasn't going to be damaged because Simple Green is rather weak, especially when diluted, I know the dilution ratio is proper, and I've tested it before ya know? Spraying APC on a new-to-you wheel may work out just fine 9 out of 10 times. But I don't want to stumble upon that 1 in 10 time with a new client lol.
  24. Apr 10, 2024 at 4:00 PM
    #1344
    Damie Street
    Edsel
    South Carolina
  25. Apr 13, 2024 at 3:51 PM
    #1345
    Adams has a sale going on now, 25% pretty much everything. (Code: refund) I picked up my new pressure washer, ($100 off!) and some refills for cleaning materials.
  26. Apr 15, 2024 at 5:55 AM
    #1346
    Side note: this pressure washer is fantastic!
    Black Wolf and ToyoMafia like this.
  27. Apr 16, 2024 at 8:35 AM
    #1347
    briarpatch
    That's a lot of money for a 1.4 GPM unit. How is the warranty that comes with it?
  28. Apr 16, 2024 at 8:45 AM
    #1348
    I think one year. Their customer service is fantastic so I’m not really concerned. My buddy (who does ceramic coatings) has had his for a couple of years with zero issues.
    I still have my gas one, but will sell it as it’s too damn noisy.
    Black Wolf likes this.
  29. Apr 16, 2024 at 8:45 AM
    #1349
    Danimal86
    Daniel
    Sacramento, CA
  30. Apr 16, 2024 at 8:57 AM
    #1350
