Show us your latest detailing purchase
Discussion in 'Detailing' started by Pudge, Oct 8, 2019.
  1. Jan 27, 2021 at 8:35 AM
    #721
    CowboyTaco
    CowboyTaco New Member
    Michael
    2011 Tacoma DCSB
    Gas. 3000 psi @ 2.4 GPM.
    Of course, what came out of the foam cannon was much lower than 3k psi :D
  2. Jan 27, 2021 at 9:03 AM
    #722
    briarpatch
    briarpatch New Member
    The GPM is the more important number.....anything near or above 2.0 GPM is very good. Lots of things affect foam.....the soap itself, the amount of soap, hardness of the water and the air temp all can make a difference. Make sure that you mix the soap with warm water to improve the dilution. I typically only drag the pressure washer out when I'm feeling energetic, until I get my wall mounted setup done.
    War Machine and ToyoMafia like this.
  3. Feb 18, 2021 at 7:49 AM
    #723
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    FE6C8C65-9626-4F90-8DD8-A346A6A40BB2.jpg Simple restock and to try something new.
    War Machine, drobb, Pudge[OP] and 2 others like this.
  4. Feb 18, 2021 at 9:15 AM
    #724
    robz
    robz New Member
    Rob
    2015 Platinum 2WD
    Full interior LED lights. Bed cover. OEM LED Headlights and Fog lights
    How do you like the ceramic speed shine?
    I've tried the ceramic 3-1 wax and I find it tricky to apply correctly.
    War Machine likes this.
  5. Feb 18, 2021 at 9:28 AM
    #725
    briarpatch
    To me, the trick is not to over-apply it, and try to avoid using it in high humidity. Weather seems to really impact it's ease of use. Like any SIO2 spray product, you need to be mindful of overspray.
  6. Feb 18, 2021 at 9:33 AM
    #726
    ToyoMafia
    Magic carpet.
    Ceramic speed is new to me. I’ll post when I start using it. I need to do my annual decon clay and correction soon when I get some room in my garage. But I wanted to try this as an after wash product.
    issues with 3-1 are usually caused by any of these three things
    1. to hot! Or in the sun when applying.
    2. to much. Lights coats like glass cleaner make it much easier. Just mist the panels.
    3. to long. Waiting to long to give it a wipe down and you’ll have trouble. It’s basically mist on wipe off use a two towel method for removal.
  7. Feb 18, 2021 at 10:35 AM
    #727
    robz
    robz New Member
    Rob
    2015 Platinum 2WD
    Agree with both of you @Swfltoyomafia and @briarpatch.
    I'm aware of those issues and your observations line up with my experience so far with it. I guess what I was trying to say is that in the 10+ years I've been doing detailing and paint correction and protection, I have not had a product be so unforgiving if any of the bad conditions you mentioned are met.
  8. Feb 18, 2021 at 10:52 AM
    #728
    ToyoMafia
    Magic carpet.
    I’m not sure how much experience you have with ceramic based products but I get what your saying. Cerakote trim is also the same way if you screw it up it will let you know you did. I think the spray on wipe off is a little misleading to some. They assume it’s easy because it is in a spray format. Idk. I love this stuff on top of my coated truck and I have never had issues with it and I’m in one of the hottest/humid parts of the country.
  9. Feb 18, 2021 at 10:57 AM
    #729
    War Machine
    War Machine SSEM # 5 3MW
    Seems that the longer lasting ones are less forgiving to heat. Most likely the SiO2 content that’s the issue. Punch It and Reload are both pretty tough in the heat.
    Beadmaker doesn’t seem to care what the temperature is, but it doesn’t plan on staying long anyway.
    robz[QUOTED] and ToyoMafia like this.
  10. Feb 18, 2021 at 11:20 AM
    #730
    robz
    robz New Member
    Rob
    2015 Platinum 2WD
    Good point. I am familiar with reload, been using it to top the carpro ceramic coatings during maintenance washes. Yes, reload can be very unforgiving but I still feel the 3 in 1 still is less forgiving than reload. The carrier agent on 3 in 1 I think is the "culprit" here, it may be flashing or reacting too quick to the conditions of the panel and environment. Just a thought. Any who that doesn't take from the fact that it is a good product.
  11. Feb 18, 2021 at 11:30 AM
    #731
    War Machine
    I agree.
    ToyoMafia likes this.
  12. Feb 18, 2021 at 1:51 PM
    #732
    briarpatch
    I don't have your years of experience, but I was late in the game trying 3 in 1, so I kind of got lucky in avoiding the pitfalls......I read lots of reviews and had some pretty good intel going into the process. What's funny is...I have a friend who uses it on his wife's vehicle, (which is pearl white) and he insisted he'd never had any streaking at all. We took a good look at his paint, and the streaks were there, he just did not see them on the lighter color.
    It is pretty unforgiving, but it is also top shelf once you get used to it's quirks.
  13. Feb 18, 2021 at 1:54 PM
    #733
    ToyoMafia
    Magic carpet.
    Yeah it’s real easy to use on white.
  14. Feb 18, 2021 at 7:23 PM
    #734
    Runway
    Runway New Member
    Kenneth
    Houston, Texas
    2016 White Tundra 1794
    Now this is what I like to hear!!
    CowboyTaco and ToyoMafia[QUOTED] like this.
  15. Mar 8, 2021 at 10:53 AM
    #735
    SandyTRD
    SandyTRD New Member
    ‘16 Pro
    Dented bumper
    Anyone try the Griots ceramic wash and coat yet?
  16. Mar 8, 2021 at 11:29 AM
    #736
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    I want to purchase a new electric power washer but mine won’t die. Greenworks 1500 still kicking ass!
  17. Mar 8, 2021 at 12:14 PM
    #737
    briarpatch
    ToyoMafia and Saltyhero13 like this.
  18. Mar 8, 2021 at 12:41 PM
    #738
    Saltyhero13
    Saltyhero13 Throbbing Member
    I haven't seen favorable reviews of it but nothing terrible. Lack of lubricity is the main issue common to the reviews. These "Wash and Wax/Coat" always seem to suffer in one department or the other. They either clean poorly or wax/coat poorly where the advantage would be saving time.
    McKee's just released a similar wash and coat that seems to have improved lubricity. Not sure these will get me on board the two in one products yet but I could see them used in some form of express maintenance wash.
  19. Mar 8, 2021 at 12:43 PM
    #739
    SandyTRD
    SandyTRD New Member
    ‘16 Pro
    Dented bumper
  20. Mar 9, 2021 at 3:07 PM
    #740
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
  21. Mar 9, 2021 at 4:27 PM
    #741
    briarpatch
    His voice can get on your nerves....but seems pretty knowledgeable....dude went out on a limb with his own product line
  22. Mar 15, 2021 at 5:47 AM
    #742
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
    No pic's yet. Just to say this site is a little costly. Picked up some Griots products at the parts store and have since placed two orders with Griots direct. Still getting snow here so I have time to read some more tips. Great place to learn.
    robz and War Machine like this.
  23. Mar 15, 2021 at 5:55 AM
    #743
    War Machine
    You guys have any good tips on applying products to white / Pearl vehicles? I find it’s tough to see how much you’re using since everything blends in. When I applied wax to my black truck, it stood out. When doing it on the Pearl one, I can’t see how much coverage I’m getting. I’ve just been doing it by “feel”.
    ToyoMafia[QUOTED] likes this.
  24. Mar 15, 2021 at 7:04 AM
    #744
    ToyoMafia
    Magic carpet.
    This is why I do the two coats on white. It’s very hard to see any missed spots. Feel does come into play. With correction I use lights and try my best to look at all the angles.
  25. Mar 15, 2021 at 8:23 AM
    #745
    robz
    robz New Member
    Rob
    2015 Platinum 2WD
    White vehicles are definitely tough to work on. Not because they get dirty quick (which is a wrong consensus) but because it is hard to see any progress you have made with the paint when correcting it. I call it the ungrateful color, because no matter how much you work on it, it will not show as much shine or pop as a darker color, but that's just the nature of the beast.
    Having worked on many white vehicles and as a current owner of three, I have found that light is your best ally when looking at the results when working on white paint. Not just any light though, it has to be a tungsten light hue. If you have a temperature adjustable light, try to get it somewhere in the 3000K and 4500K temperature range, this will reveal the true canvas you are working with. It is almost like UV light effect type thing....lol.
    For reference a typical LED light is between the 5000K and 6000k temperature range.
    The alternative is the one you have implemente thus far, working it by feel, also working with it under sunlight is also a good one, albeit a risky one if the product you are using flashes quickly or is temperature sensitive.
    Hope this helps.
  26. Mar 15, 2021 at 9:59 AM
    #746
    Saltyhero13
    Not picking nits and not sure the contrast was intended SIO2 vs BM. From what I recall BM is polymer based and has no SIO2, this may speak to its easy of application.
    jpod likes this.
  27. Mar 15, 2021 at 10:34 AM
    #747
    War Machine
    Yes sir, that was my meaning. I was speaking to Beadmaker’s lack of sio2 as making it easier to apply, with the trade off of being shorter lived.
  28. Mar 15, 2021 at 10:39 AM
    #748
    War Machine
    Definitely good and 100% accurate info. My issue is mainly with wax or a non-sprayable sealant, like Powerlock. It’s a pain trying to tell if I missed any spots. It’s tough to track my progress like I can on darker vehicles. That’s the point of having the Pearl though: it doesn’t show everything that’s on the paint immediately.
    Not a huge issue ultimately for waxing. I could definitely see needing a good lighting set up for correction. Doesn’t help that I’m getting blind anyway.
  29. Mar 15, 2021 at 11:57 AM
    #749
    Saltyhero13
    Tracking
    War Machine[QUOTED] likes this.
  30. Mar 15, 2021 at 12:09 PM
    #750
    ToyoMafia
    Magic carpet.
    :fistbump:
