Should I wash my engine?
Discussion in 'Detailing' started by Mex450, May 28, 2017.
  1. May 28, 2017 at 1:49 AM
    Mex450
    Mex450 [OP] New Member
    Las Vegas
    2019 Toyota Tundra TRD PRO ..
    Is there a safe way to wash my engine?? Or don't bother ?...
  2. May 28, 2017 at 1:54 AM
    I do...dont get right on it.. maybe bout a foot away
    Mex450[OP] and Y0TA PR0 like this.
  3. May 28, 2017 at 3:45 AM
    HWU
    HWU We like white!
    N.W. Ohio
    2003 White Tundra SR5
    Living in the North, "Ohio" we are constantly washing our trucks, underside, engine compartment, ect. The "shit" they put on the roads for "deicer" called a "brine" will eat steel away in a matter of months, not years.
  4. May 28, 2017 at 3:52 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I used to do it with my avalanche every 3 months.. kept it sparkling... nice look
    Mex450[OP] likes this.
  5. May 28, 2017 at 4:18 AM
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    Definitely. I use GUNK foamy and shine. Just spray the foamy, rinse with a hose nozzle on the mist setting (cover what's appropriate) then use the shine.
  6. May 28, 2017 at 4:55 AM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    Definitely do it. Don't use pressure washer. But you. Can get everything set it will be fine
  7. May 28, 2017 at 5:31 AM
    Exactly what i use
    NewImprovedRon likes this.
  8. May 28, 2017 at 7:38 AM
    Blah blah blah
  9. May 28, 2017 at 7:42 AM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Ok. Now your banned from the stormtroopers thread. @WarEagleSteve has my back on this decision
    SouthBoundSteve likes this.
  10. May 28, 2017 at 7:45 AM
    Peace out
  11. May 28, 2017 at 7:47 AM
    Eclipsed & Floating
    Voluptuous Whitey
    Upgrade your color and you'll be recruited back
  12. May 28, 2017 at 8:30 AM
    Never!!! :quickdraw:
  13. May 28, 2017 at 8:31 AM
    Eclipsed & Floating
    Voluptuous Whitey
    Hahahahah
    I love mgm. Don't tell anyone
    JC303, PaulROahu and SouthBoundSteve like this.
  14. May 28, 2017 at 8:41 AM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    Can you use this on everything under the hood?
  15. May 28, 2017 at 6:07 PM
    Tundraplatinum
    2016 Platinum CM
    Yes
    Dustydirt19[QUOTED] likes this.
  16. May 28, 2017 at 7:18 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    I keep engine running while washing it down
    Afterwards I go for a short drive to get any settled water away for cavities....
  17. May 28, 2017 at 7:46 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    What exactly do you cover with plastic when washing the engine bay? Just the fuse box?
  18. May 28, 2017 at 8:19 PM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    :popcorn:
  19. May 28, 2017 at 8:38 PM
    [​IMG] Seriously my local self car wash has an engine wash/spray setting that I use from time to time and works quite well. I can ask the owner what the "engine wash" chemical he is using. Doesn't help you much now though.
  20. May 28, 2017 at 10:11 PM
    Red Freighter
    Red Freighter Red Freighter
    Oregon City
    2013 double cab sr5 trd red
    2014 TRD wheels and TRd pro center caps. Stock 2014 running boards. Stereo gps dvd deck two 12" subs w/amp. Dvd Headrests. Rear air bags with compressor and air tank.
    Please help keep Gunk engine cleaner a legal product and use it at a coin opp car wash where the chemicals go thru waste treatment.
  21. May 29, 2017 at 8:45 AM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    So is there anything in your engine that you should cover when using these products and spraying it out?
  22. May 29, 2017 at 8:55 AM
    I dont...i spray all over let it set in a few minutes then rinse off..then use electric leaf blower has more power than my gas leaf blower blow all water out sparkling clean!!! Never had any issues
    Dustydirt19 likes this.
  23. May 30, 2017 at 4:37 PM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    So no need to cover the fuse box or any other electrical? I've never used this stuff before
  24. May 30, 2017 at 4:46 PM
    Well your fuse box already has a cover on it...but yeah i spray engine cleaner over all and let sit few minutes then hose off i have that water hose attachment that has a shutoff valve to create pressure to wash off dust buildup I haven't used my pressure washer as my engine is new and has no serious buildup then i use a electric blower it has more air than my gas leaf blower to blow off excess water
  25. Oct 4, 2018 at 7:17 PM
    Aggie2002
    Aggie2002 New Member
    Arlington, VA
    2017 Tundra Limited TRD Offroad
    Can you get the engine foam wet? I plan to take the plastic engine cover off prior to spraying everything down with Gunk. Thanks for the help.
  26. Oct 4, 2018 at 7:25 PM
    I believe the directions for foam is engine is warm or cold, not sure, read can label
  27. Oct 4, 2018 at 7:29 PM
    Redbeard321
    Redbeard321 ballin' on a budget
    2016 Tundra SR5 Double Cab
    Or just use simple green, safer alternative environmentally speaking.
    OR18TRD likes this.
  28. Oct 4, 2018 at 7:34 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Just a few more trips and I’ll be due for a wash.
    :crapstorm:
  29. Oct 4, 2018 at 7:41 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Anyone use fluid film under the hood at all? I wanna treat as many areas as I can before the snow flies and the salt mix feasts on metal for a other year
  30. Oct 4, 2018 at 7:42 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    This was done using the @driverdog method. At this point only the CAI cover was sprayed with wax addict and buffed.
    352AAA04-8D32-43E5-950C-9A61010E18AC.jpg 6CA6AC85-F94B-4DDD-8726-CCF3C3691A37.jpg
