Should I easily be able to spin the tires in the rain?
Discussion in '2.5 Gen Tundras (2014-2021)' started by daylorb, Mar 13, 2019.
  1. Mar 14, 2019 at 7:11 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Great traction, wet & dry.
  2. Mar 14, 2019 at 7:25 AM
    15whtrd
    15whtrd Mr. Blonde
    The VSC is always on. So do you typically turn it off and lately you’ve been just leaving it on?
  3. Mar 14, 2019 at 7:29 AM
    wmchaseb
    wmchaseb New Member
    Chase
    Louisiana
    2018 Plat MGM
    I have this problem when leaving my road that is on a steep incline.
  4. Dec 6, 2020 at 12:46 PM
    superbond
    superbond New Member
    I too have this issue with my 2010 crewmax platinum. I’ve had this truck for 10 years and had no issues. But within a few months I noticed I’m spinning my tires! It is not tire issues. There is a feature the stops tundras from spinning or fishtailing. This feature seems to have stopped. I’ve noticed a few other issues also. Don’t know if it is related to my tire spin. With all these features if one thing goes wrong it could be related to a bigger issue. My telescopic steer wheels is not working as should and my auto tint for my rear view mirror. Maybe more those are what it be noticed so far.
    All I know is my truck could not spin a tire unless I turned off traction control the other feature vsc. But now I have been having these issues and can’t find anyone with the same problem until you. This is a problem and it’s not your tires
  5. Dec 6, 2020 at 7:06 PM
    CTPlatinum
    CTPlatinum New Member
    2020 Tundra Platinum 4x4
    None Yet
    Same, my 295/70-18 Ridge Grappler "bro tires" will shit all over whatever rubber bands this dummy has on his truck, on-road and off!
    Mnorris1206[QUOTED] likes this.
  6. Dec 6, 2020 at 7:11 PM
    CTPlatinum
    None Yet
    Imagine being such a douche that you label anybody that actually uses their truck off road a "bro"?
    War Machine likes this.
  7. Dec 6, 2020 at 7:24 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    Interesting topic for me. Prior to my 19 Pro I had a 15 SR5 double cab that I lifted, and put some Toyo tires on. I was constantly spinning my tires, even on modest acceleration. Now that I have my Crew Max Pro, I have to really stomp on it to spin the tires. I know there's a bit more weight in the back with a Crew Max, but I think it's the tires. Are you running stock tires?
  8. Dec 6, 2020 at 8:37 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I'd start checking fuses and also wiring harness connections to see if they may have some corrosion, or just dirty and not making good connection after 10 yrs. Anything I own that is old needs the plugs, connectors, etc cleaned every now and then to get a good connection and work correctly.
  9. Dec 7, 2020 at 12:44 AM
    MGM2020
    MGM2020 New Member
    Sacramento CA
    2020 MGM Tundra SR5
    6" Rough Country Lift 37" on 22" V2 Monotube Rear L3 Lifted Struts Front
    Their is alot torque so you should be able too. If you can't then turn on tow haul and it should work
