Should I buy this Tundra?
Discussion in '1st Gen Tundras (2000-2006)' started by Luv2_4x4, Feb 13, 2021.
  1. Feb 15, 2021 at 6:17 PM
    #61
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Congrats on the new truck!
    Luv2_4x4[OP] likes this.
  2. Feb 16, 2021 at 9:00 AM
    #62
    Luv2_4x4
    Luv2_4x4 [OP] From Tacoma to Tundra 02/14/21
    2006 DC 4WD V8
    Any suggestions?
    Can you give me some more information on the 5100 in regards on how high i should set them for best towing capability. Should I set them higher in the front or back or have all 4 set the same? I'll probably get these installed soon..
    Do they come with the coil over? Looks like these are sold separately. Thanks
    Captain Tenneal likes this.
  3. Feb 16, 2021 at 10:27 AM
    #63
    Captain Tenneal
    Captain Tenneal New Member
    NNV
    2005 SR5 Double Cab Off-Road Package, Sunroof
    Bilstein 5100 - 1 groove up
    5100s are struts only. I personally would not raise the front more than one notch from the bottom (3/4 inch up) if you're towing anywhere near capacity. That's where I have mine right now. In the picture I'm towing about 5,500 lbs.
  4. Feb 16, 2021 at 10:28 AM
    #64
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Well if we’re still talking about the truck...or did I miss something here in translation? :confused:
    My recommendation to get the undercarriage looking much better is to put on a bunny suit and goggles and go to town with a wire wheel and POR-15.
  5. Feb 16, 2021 at 10:30 AM
    #65
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    The Bilstein 5100 shocks are only adjustable for ride height in the front. The rear 5100's are not adjustable but can accommodate up to a 1" lift. Page 2 of this PDF shows typical lift height with regard to circlip position. The 5100's are replacement shocks and you'd have to use or replace your existing coil springs in the front.
    While new shocks all around will improve towing performance, I think you'll see a greater benefit from either upgrading the front sway bar, adding a rear sway bar, or both.
    Luv2_4x4[QUOTED][OP] likes this.
  6. Feb 16, 2021 at 10:54 AM
    #66
    Rocko9999
    Rocko9999 New Member
    Listing is gone. Did you get it?
  7. Feb 16, 2021 at 11:23 AM
    #67
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
  8. Feb 16, 2021 at 12:27 PM
    #68
    Rocko9999
    Bissell Machine is in your future...
  9. Feb 17, 2021 at 9:00 AM
    #69
    Luv2_4x4
    2006 DC 4WD V8
    Any suggestions?
    I have one!!! I'm pulling the seats out today and getting started.. can't wait for my truck to smell/look good.
  10. Feb 17, 2021 at 9:16 AM
    #70
    Luv2_4x4
    2006 DC 4WD V8
    Any suggestions?
    Here's the diagnostic from my mechanic.
    It gonna be a long road but hey, guess I'm not in a hurry.. (kinda)
    I could replace the coils when they do the timing belt but this would be most of my money(until I can save more). Not sure if I should hold off on these or do them asap..
    I need to look into what he meant when he said the transmission is collapsing. It always seems to make sense when he explains it but then I get home and forget what he said.. it's hard for me to visualize things when I don't know the names of parts.. it didn't sound like that big of a deal but when u put in on paper, sounds like it needs to be addressed!!
    Also found out my mechanic is retiring and not taking anymore work.. I've been with him 5 years and he PXL_20210217_170106630.jpg was very trustworthy and reasonably priced!!! So I'm ISO and new mechanic if anyone has a recommendation for the Santa Cruz/San Jose area in California.
  11. Feb 17, 2021 at 9:20 AM
    #71
    ezdog
    ezdog New Member
    Gateway To The West
    Reads to me like he is suggesting a Mechanic too?
  12. Feb 17, 2021 at 9:20 AM
    #72
    Luv2_4x4
    2006 DC 4WD V8
    Any suggestions?
    Only plan on towing around 3,000 dry.. how much should I raise in back? Same as front or a little higher to help with trailer weight.. I want my truck to look level when I'm not towing.
  13. Feb 17, 2021 at 9:21 AM
    #73
    speedtre
    speedtre New Member
    Inland Northwest
    He's talking about the center support/carrier bearing for the driveshaft...his "transmission collapsing" comment is VERY poorly worded...it's not expensive or hard to replace...just FYI go with Spicer they are a legit alternative to a Toyota carrier bearing.
    https://www.youtube.com/watch?v=L9HpbRhaA6I
  14. Feb 17, 2021 at 9:21 AM
    #74
    Luv2_4x4
    2006 DC 4WD V8
    Any suggestions?
    Yes sadly he is retiring been with him for a while.
  15. Feb 17, 2021 at 9:27 AM
    #75
    ezdog
    ezdog New Member
    Gateway To The West
    Yes I read that but on his report he suggests another mechanic too.
  16. Feb 17, 2021 at 9:30 AM
    #76
    speedtre
    speedtre New Member
    Inland Northwest
  17. Feb 17, 2021 at 9:34 AM
    #77
    Luv2_4x4
    2006 DC 4WD V8
    Any suggestions?
    Thanks! Helpful video! So it doesn't have much to do with the transmission but more of vibration while driving? Now that I know what it looks like I'll go check it out on my truck! The mechanic said he could feel a slightly vibration but I don't feel it!
    So it's not like my transmission is going to fall off or anything lol . I would like to run this truck for a long time so really want to make sure the tranni is happy!!!
  18. Feb 17, 2021 at 9:38 AM
    #78
    Luv2_4x4
    2006 DC 4WD V8
    Any suggestions?
    Got it sorry!! Yes I will go to him unless a member here recommends a mechanic..
    He quoted me 850 for belt, pump, seals.
    Said replacing all the coils would be an additional 1,000!!
  19. Feb 17, 2021 at 9:41 AM
    #79
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Have we talked her into 35s yet? I'm still catching up.
  20. Feb 17, 2021 at 9:49 AM
    #80
    speedtre
    speedtre New Member
    Inland Northwest
    Price for the belt/pump/seals is not bad depending on the parts used...just ask him to use the Aisin TK021 kit...also use an Aisin thermostat and I would replace the radiator with Denso while he is there...should not add much if any cost to labor.
    Denso Coils are about $50 each....anyone with a basic took kit can replace them and all 8 spark plugs in about an hour.
  21. Feb 17, 2021 at 9:50 AM
    #81
    Luv2_4x4
    2006 DC 4WD V8
    Any suggestions?
    I need to learn more about towing gear ratio first!! But bigger tires and black rims are definitely in the future along with custom grill/bumper!
    Darkness[QUOTED] likes this.
  22. Feb 17, 2021 at 9:50 AM
    #82
    tvpierce
    tvpierce Formerly New Member
    Maine
    Back to your interior: Tuff Stuff foaming stain cleaner works wonders on interior and carpet. Spray on, wipe off with a damp cloth. Available at any auto parts store or discount store.
    For really tough stains, maybe apply this and use your drill brush to help lift it.
  23. Feb 17, 2021 at 9:55 AM
    #83
    Luv2_4x4
    2006 DC 4WD V8
    Any suggestions?
    Thanks. What website is this?
  24. Feb 17, 2021 at 9:58 AM
    #84
    speedtre
    speedtre New Member
    Inland Northwest
    Rockauto.com
  25. Feb 17, 2021 at 11:00 AM
    #85
    Rocko9999
    It's a great feeling. I recently bought my 2014 and it was formerly a concrete construction foreman's truck. Needless to say I spent 3 weekends detailing the inside. It's a great sense of accomplishment. I suggest taking after pics.
    This was just with bissell, drill brush and hand brush. Could stand to be done again as 6 years of construction use really was rough on interior. Yours will come out even better I bet.
  26. Feb 17, 2021 at 12:02 PM
    #86
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    He mentions the carrier bearing as well as the trans collapsing so I’m assuming he means the trans mount is collapsing/failed
    FirstGenVol likes this.
  27. Feb 17, 2021 at 12:03 PM
    #87
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    It's hard to tell what he meant but that's not what I got out of it. I assumed he meant that the transmission support/bushing thingamajig needs to be replaced. The same part that was being discussed in another thread maybe a month or so ago. Someone had to replace theirs. I would call this mechanic back and ask.
    But either way, both would be easy to replace.
    speedtre[QUOTED] and CodyP like this.
  28. Feb 17, 2021 at 12:24 PM
    #88
    speedtre
    speedtre New Member
    Inland Northwest
    Yea, you could be right...I concur on your advice to call him and clarify. :thumbsup:
  29. Feb 17, 2021 at 12:40 PM
    #89
    Captain Tenneal
    NNV
    I think it depends upon your use for the truck. For me, I'm not a fan of "levelling" where they raise the front an 1.5-2 inches more in the front compared to the back. I can see why people do it for off-roading. When I purchased the truck, the Bilsteins were raised over 2 inches in front, can't remember if it was the top notch or one below that. I lowered it 2 notches, now sits one up from the bottom. I only plan to do moderate dirt/gravel roads, no mud or sand (not intentionally, anyways). Levelling generally is not good for street handling or towing and certainly not good for gas mileage. My truck as it sits now has a mild front to rear rake and I still have good clearance in front (2wd). Stock in the rear.
    She'll tow 3,000 lbs with no problem.
  30. Feb 17, 2021 at 1:20 PM
    #90
    ezdog
    ezdog New Member
    Gateway To The West
    Just under 4000 lbs stock suspension no problems.
    What exactly are you pulling at 3000 lbs and what kind of trailer?
    Just curious.
