short block replacement @ 2200 miles
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bradleybb, Nov 18, 2020.
  1. Nov 18, 2020 at 2:31 PM
    Bradleybb
    Bradleybb [OP] New Member
    Georgia
    2021 CM TRD OR
    Transmission cooler TRD REAR SWAY RCI front skid
    Just got bad news from dealer my truck needs a short block
    Assembly, bummer 2200 miles on it, got it in yesterday figured it
    Was dreaded cam tower leak since it had same bell housing drip
    , no a dam oil pipe on back of block
    Drivers side below head , that Toyota use some kind of press fit rivet to hold
    Pipe to block leaking from there , on the other end it’s bolted on, non serviceable part ,
    Anyone had this problem where dealer was able to fix , instead of major repair
    Couple pics pipe is at 11 o’clock
    Rex Kramer likes this.
  2. Nov 18, 2020 at 8:32 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I haven't heard of this problem yet. Sucks thats its non serviceable. Can you circle that oil pipe and where its leaking? I believe I know which one you're talking about but just wanted to be 100% sure.
  3. Nov 19, 2020 at 8:06 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    If the service techs are talking about the Oil Drain Pipe Sub-assembly (Diagram label), you can't see it in that photo. The oil drain pipe sub-assembly is under the rear seal retaining plate, which is under the flex plate as shown in the photo. (See below.)
    I can see the drain pipe being a non-critical simple push-in fit because it's behind the rear seal retaining plate; it's intended to keep a river of oil directed toward the oil pan. If it leaks a little at the push-in fit, it's not a big deal, the oil leaked simply runs down the back of the engine,
    Sounds like a BS reason to change a short block to me, and I can't imagine Toyota approving the exchange, or even designing anything that would require that, press fit or not. @Ruggybuggy
    Hbjeff likes this.
  4. Nov 19, 2020 at 10:04 AM
    Bradleybb
    Georgia
    2021 CM TRD OR
    No it’s not what your description is, it’s right above flywheel driver side head 11 clock, see in schematic parts picture .
    Can’t draw circle around it from my pad ,was @ dealer this am to pick up loaner , my new engine was
    In but couldn’t get a picture of it was still crated , engine hasn’t been taken out yet , friend of mine is parts manager there will call me when engine comes out so I can look at , will post pictures , surely there’s been others with issue , hell who knows there could be some techs at Toyo or independent shops
    That have repaired without replacement
  5. Nov 19, 2020 at 10:37 AM
    JohnLakeman
    Then I guess the only other possibility is the pipe between the arrows (below). Which of the arrows is pointing to the "press fit rivet"? The green arrow is pointing at what appears to be a small flange head bolt (8mm?).
    Is that your actual engine? What are those gold markings all over the back mean? Did the techs apply them, are were they already there?
  6. Nov 19, 2020 at 10:46 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I am also intrigued by this..
  7. Nov 19, 2020 at 12:51 PM
    Bradleybb
    Georgia
    2021 CM TRD OR
    Sorry should stated not my engine this one is just for reference , your
    Yellow arrow pointed to to correct end, hard to get good visual of it
    Laying on your back, looks like press in rivet , slightly dripping out of fitting
    I suspect when pressed in it cut the o ring . costly design , close to 10k repair
  8. Nov 19, 2020 at 7:52 PM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    so, are you paying anything for it?
  9. Nov 20, 2020 at 4:39 AM
    Bradleybb
    Georgia
    2021 CM TRD OR
    No all warranty
  10. Nov 20, 2020 at 8:57 AM
    speckmon
    Thornton, CO
    gotcha. that sucks, but at least it's "free"
    try and haggle for a bed lining or something :devil:
  11. Nov 20, 2020 at 9:51 AM
    Trogdog
    Trogdog New Member
    Trog
    North West GA
    2020 Crewmax SR5
    If this wasn't a warranty fix I think I'd try tapping and adding fastener customized to fit. Or just JB Weld.
    I hate engineering like this, if the casting isn't broken then it shouldn't be a non-serviceable part.
  12. Nov 24, 2020 at 5:52 PM
    Bradleybb
    Georgia
    2021 CM TRD OR
    Got my tundra back today , short block replaced, looks like a jam up job , runs great
    Time will tell .... picture of pipe fitting on a blown 5.7 engine in the shop, tech said was seeping out were it’s pressed in looks to be tight tolerance
    Not mine , my old engine was in the shipping cart it came in couldn’t get a picture of it ,
    Expensive warranty claim 10,770$
