Shop says 5.29 gears are supposed to be noisy
Discussion in 'Performance and Tuning' started by Cosmo10, Nov 4, 2021.
  1. Apr 13, 2022 at 8:39 PM
    #61
    Cosmo10
    Cosmo10 [OP] New Member
    2010 Tundra Rock Warrior
    So far, I’m holding on strong getting used to it a few thousand miles later……… I LIED! I sometimes breakdown and cry. I have phantom whining in my ears when sleeping! :crazy:
  2. Apr 13, 2022 at 9:20 PM
    #62
    pandapro
    pandapro New Member
    Go back to them and have them take a look. My sierras have zero whine.
  3. Apr 26, 2022 at 11:22 AM
    #63
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Quick question to those who have done the swap:
    My installer is having issues with setting backlash. The shims included in the kit are entirely too thick. He is looking for some .005-.015s or .020...the rear only came with .060-.080ish and none came for the front.
    Also, which shims would you say would be good to start pinion depth?
    TIA
  4. Apr 26, 2022 at 12:42 PM
    #64
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Ok so after speaking with Keith Carty, NW Drivetrain, West Coast Diffs, and the local Toyota parts guy, I've come to the conclusion that if I had a water jet and stainless stock I'd make millions making shim kits for Tundras.
    Maybe not millions but high thousands.
    I finally found an install kit by Yukon Gear sold by East Coast Gear Supply that has super thin shims (.003 up to .020ish). Link here for any who may need it.
    Downytide likes this.
  5. May 14, 2022 at 10:10 AM
    #65
    Tundra_Sam
    Tundra_Sam New Member
    Just had Revolution 5.29 With REM installed this week. It whines at deceleration and freeway speeds. The whine at freeway speeds is annoying even with 8” dirty deeds exhaust.
    texasrho83 likes this.
  6. May 14, 2022 at 10:16 AM
    #66
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Is it like a whistle? Like a turbo whistle?
  7. May 14, 2022 at 11:56 AM
    #67
    Tundra_Sam
    Yes it is.
  8. May 14, 2022 at 12:03 PM
    #68
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    My Nitros do it on deceleration only. Installer mentioned checking backlash, pinion depth, and pattern multiple times and all are good.
    I'm in the break-in period so running regular gear oil but on the drain and fill I'll be using quality 80W-140. Will see if the whistle is still there and to what degree. It actually doesn't bother me one bit but I don't get it on acceleration or cruising speed
  9. May 14, 2022 at 12:22 PM
    #69
    Tundra_Sam
    I went with Revolution because they were supposed to be quiet like stock gears. I’ll give the shop a call in a few days if it’s still there.
    Terndrerrr likes this.
  10. May 14, 2022 at 12:22 PM
    #70
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Same boat either the decel whistle. My installers claimed every toyota he has ever installed gears on has done this :rolleyes:. Also doesn’t bother me too much either, I’ve gotten used to it
  11. May 14, 2022 at 12:32 PM
    #71
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I like to think it's my turbo spoolin
    Sumo91 likes this.
  12. May 14, 2022 at 12:44 PM
    #72
    Wixo
    Wixo The Best Member
    Mawr
    RGV
    5.7L 4x4 CrewMax SB
    Tint
    So from my personal experience getting 4.88s on my TRD Off Road Tacoma.
    Yes, regearing will add some diff noise. My expert regearer told me that since the gears I bought werent perfectly smooth on the outside they would be making a little more noise than “higher end” smoother machined gears. Thats not to say that the pattern was bad, it was dead on, but the outside of the rings had little circles.
    I did hear a small whine, not enough to bother me.
  13. May 16, 2022 at 3:05 PM
    #73
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Mine made a slight noise at first but it went away after a few hundred miles. It was very subtle to start with though, had to be listening specifically for it to know.
  14. Jun 17, 2022 at 6:06 PM
    #74
    WinterWarlock21
    WinterWarlock21 New Member
    South Jersey
    2016 Quicksand TRD Pro CrewMax
    https://gearproject.co/profile/SandShark21
    Hey, did the sound go away with the 80W-140? I’m getting my Nitro re-gear to 5.29s at the end of June so was going to get the same oil you did if the sound stopped or was at least quieter. Thank you!
  15. Jun 17, 2022 at 6:09 PM
    #75
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'm about to get the first fluid change done. Will update.
  16. Jun 21, 2022 at 8:43 AM
    #76
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Not 5.29 related but nitro gear related. My old man has 4.88s in his supercharged tundra. Slight whine but after switching to Amsoil no noise at all.
  17. Jun 21, 2022 at 8:56 AM
    #77
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'm putting Amsoil in our Sequoia and HPL 85w-140 in my Tundra. First time ever using Amsoil. I joined the "club" as it was the same cost to ship.
  18. Jun 21, 2022 at 9:57 AM
    #78
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    We run it in all our rigs. Ill be adding this to my difs/trans etc when the time comes
  19. Jun 21, 2022 at 10:11 AM
    #79
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    HPL 75w goes in my transfer case.
    Sumo91 and reywcms[QUOTED] like this.
  20. Jun 21, 2022 at 11:39 AM
    #80
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Amsoil for everything except engine (Kirkland or other cheap stuff every 4-5k depending on use) and TC (Ravenol 75W).
    After watching The Car Care Nut, I decided he’s right—it’s less about how expensive your engine oil is and more about your OCI—he recommends never going more than 5k miles before swapping.
    If I do gears, which I kinda want to, I will stick with Amsoil. Watching a bunch of threads including this one before I decide. I would probably do a limited slip in the rear at the same time.
  21. Jun 21, 2022 at 11:41 AM
    #81
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I just so happen to have one for sale. BNIB. :monocle:
    Terndrerrr[QUOTED] likes this.
  22. Jun 21, 2022 at 3:20 PM
    #82
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Speak of the Amsoil Devil
  23. Jul 8, 2022 at 4:48 AM
    #83
    WinterWarlock21
    South Jersey
    Just to update but got my truck back early morning yesterday and i don’t have too much noise. Windows up and music off I hear it most at 50-55 mph cruising. Other than that nothing really. About 150 miles into break in. My shop did a few heat cycles for the first 50 miles before I got it back. Nitro 5.29 with Nitro gear oil as well. Not sure on what weight, will ask next week when I get it drained and refilled.
    Vr0ck likes this.
  24. Jul 8, 2022 at 6:14 AM
    #84
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I've done my 500 mile break-in. Actually went 650. Shop drained and filled with HPL 75w-140. Old stuff looked like what you'd expect. Front was very clean. Rear was murky with tiny specks. Post-fluid change I don't really hear much of a difference.
    When you hear your noise is it on acceleration or deceleration?
  25. Jul 8, 2022 at 6:45 AM
    #85
    WinterWarlock21
    South Jersey
    deceleration but I should’ve mention I do have a dirty deeds trd replacement system 5x12 (loudest version) on as well. So I’m sure that plays a little into why I don’t hear much on acceleration.
    After the first drain and fill at 500 miles, do you plan on getting it done again at 5,000 or 10,000 just to be safe?
  26. Jul 8, 2022 at 6:55 AM
    #86
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    My mechanic told me that he's fully confident that the noise on the "coast" side is benign and would be more concerned if it were on acceleration. I told him it's cool cause it kinda sounds (to me) like a turbo spoolin lol
    I plan on doing a regular interval change.
  27. Jul 8, 2022 at 6:58 AM
    #87
    WinterWarlock21
    South Jersey
    glad to hear that lol I was gonna ask the shop about it after a change if it was still there.
    And just for the rest of the thread I was not rem polished nor cyro treated neither.
  28. Jul 8, 2022 at 7:22 AM
    #88
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    On page 1 of this thread @Hightide posted some texts he had with a renowned installer:
    I feel like this totally applies to our situation.
    Pretty sure I had 90w in it on the initial break in.
    Hightide and WinterWarlock21 like this.
  29. Jul 8, 2022 at 7:35 AM
    #89
    WinterWarlock21
    South Jersey
    oh for sure! The whine/whistle to me doesn’t bother me too much since playing music on a low level drowns it out, same when I drive with my windows down.
    I think I might stay with the same oil they used originally and if that still makes a noise then I might consider a 10k change and go 75w-90. All depends on how annoying it gets. I’m just about at 30 hours with my truck post change so still new to me and not annoying yet. Next weekend I drive 4/5 hours to lake George so we’ll see how it is on that drive. That might be my deciding factor
  30. Jul 8, 2022 at 7:48 AM
    #90
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Well, if you think about it, road trips are rarely "coast" time. You'll be accelerating in cruise control and/or manually for the most part. Unless you're in mountain country the majority of the way. If I were you, I'd have saved the good fluid for the post break-in cause that's pricey stuff to drain after only 500 miles.
