Shop says 5.29 gears are supposed to be noisy
Discussion in 'Performance and Tuning' started by Cosmo10, Nov 4, 2021.
  1. Nov 5, 2021 at 7:44 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I changed over to BFG KM3 tires, very quiet on the road, which is when I noticed that my Nitro gears whine at 65-70mph. Changed over to louder tires - fixed :D
  2. Nov 5, 2021 at 8:49 PM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    I've never talked to someone who's so knowledgeable and want to explain, it was the best experience I've ever had when comes to a purchase/service.
  3. Nov 5, 2021 at 10:03 PM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    I wish I had the down time to send mine to him, but his help via text and call was priceless.
    I would send anyone his way.
    FrenchToasty, Cosmo10[OP] and 831Tun like this.
  4. Nov 6, 2021 at 5:21 AM
    Cosmo10
    Cosmo10 [OP] New Member
    2010 Tundra Rock Warrior
    Hahaha!! You have 5.29?
  5. Nov 6, 2021 at 5:25 AM
    Cosmo10
    Sunday I’m going to take it out to the dirt roads to get the front diff broken in. I did 50 more miles…. Still have half way to hit lol. What oil did you use for the rear after the 500 miles?
  6. Nov 6, 2021 at 8:20 AM
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    I had to use a non synthetic lucas because of the LSD. If you got an Eaton, they'll have a specific oil they'll recommend
  7. Nov 6, 2021 at 8:46 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
  8. Nov 7, 2021 at 7:05 AM
    Cosmo10
    75W-140?! Dang!
  9. Nov 7, 2021 at 1:23 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Warren is that good for lockers? I have the non-synthetic version in mine.
    831Tun[QUOTED] likes this.
  10. Nov 7, 2021 at 1:24 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Yup and ARB lockers front/rear
    Cosmo10[QUOTED][OP] likes this.
  11. Nov 7, 2021 at 6:24 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I'm pretty sure it is. There's an additive in synthetics that isn't compatible with the ARB seals, don't think this has it but I'll try to confirm that.
    GodlessPro and Cruzer[QUOTED] like this.
  12. Nov 7, 2021 at 7:12 PM
    woodlandFF
    woodlandFF New Member
    2019 SR5 Cement Tundra CrewMax 4x4
    Black Rhino 20s
    Where did you go? I hope it’s not who I was thinking of going to. Thanks!
  13. Nov 11, 2021 at 8:59 PM
    Cosmo10
    Who you planing on going with?
  14. Nov 11, 2021 at 9:00 PM
    Cosmo10
    Awesome you have the front locker in. I purposely chose the Eaton E-locker but sadly they haven’t made the front locker yet for the 2nd gen.
    Cruzer[QUOTED] likes this.
  15. Nov 18, 2021 at 7:19 PM
    woodlandFF
    Black Rhino 20s
    Premier west or pro gear in SD.
  16. Nov 21, 2021 at 7:29 AM
    Cosmo10
    Has anyone truly done a break in for the FRONT gears? Or just swapped out the oil when you did the rears after the 500 miles?
  17. Nov 25, 2021 at 9:21 PM
    Cosmo10
    So I added Lucas HD 85/140 oil to the front and rear diffs after the 500 mile break-in…… sadly to say, the rear still whines ONLY at coast still. Matter of fact, it may sound louder. I thought it would of made it a little more quieter due to the thicker oil.
  18. Nov 26, 2021 at 3:39 AM
    Hightide
    Abalama
    Magic School Bus
    Ace96 and Cosmo10[QUOTED][OP] like this.
  19. Nov 26, 2021 at 9:45 AM
    #49
    Cosmo10
  20. Nov 26, 2021 at 3:25 PM
    #50
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    This was my understanding as well.
  21. Nov 26, 2021 at 3:28 PM
    #51
    Hightide
    Abalama
    Magic School Bus
  22. Nov 27, 2021 at 9:55 AM
    #52
    Cosmo10
    Hightide[QUOTED] likes this.
  23. Nov 29, 2021 at 12:34 PM
    #53
    Downytide
    GTA
    My gears were cryo'd and REM'd, put together by Ken/Zuk, during break in I used OEM fluid, pretty quiet, then last 8k or so I used Nitro's oil, which I have a case of, whines at 45-50mph, last week I switched back to OEM 75w90, whisper quiet, occasional very quiet whine at deceleration around 50mph.
  24. Nov 29, 2021 at 11:09 PM
    #54
    Cosmo10
    I’m going to switch the oils then… I must give it a try. Everyday I’m hoping it goes away or I get used to it. Both are never going to happen till I switch something lol. I just did the oil swap 180 miles ago after the break-in
  25. Nov 30, 2021 at 7:40 AM
    #55
    Downytide
    GTA
    Might as well, also another crazy thing is, I just swapped to Fox 2.5 DSC, the truck became much quieter in terms of road noise and the whine, then the stock fluid quiet down even further, so good shocks make truck quiet lol.
  26. Mar 26, 2022 at 11:43 AM
    #56
    SoCalRandy
    SoCalRandy New Member
    Randy
    San Diego, California
    2020 MGM Limited Crewmax 4x4
    I just had Sierra Gear 5.29’s installed front and rear with a PowerTrax GripPro LSD in the rear last week. Unfortunately there’s a pretty annoying whine at freeway speeds, 65-70 mph. I’m hoping it will either go away or I’ll get used to it LOL
    Cosmo10[OP] and Saltyhero13 like this.
  27. Mar 29, 2022 at 9:17 PM
    #57
    gabex35
    gabex35 2020 Limited 4x4 with mods coming...
    San Diego
    2020 Cement Limited 4x4
    Where did you get them installed in SD?
  28. Mar 29, 2022 at 10:26 PM
    #58
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I'm 600 miles into 4.88s plenty of rpm and no noise on big 32"s - so I'm happy. But, consider 85-140 weight if you are not in cold temps.
  29. Mar 30, 2022 at 6:34 AM
    #59
    SoCalRandy
    Randy
    Pro Gear in Kearny Mesa.
  30. Apr 13, 2022 at 8:37 PM
    #60
    Cosmo10
    I’m already using Lucas 85-140 and she’s still screaming! I’m like a few thousand miles and and holding on strong!
