Shocks in....anyone run 285/70r17 on a 1.5" level front?
Discussion in '1st Gen Tundras (2000-2006)' started by tdn, Aug 18, 2020.
  1. Aug 21, 2020 at 7:17 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    You're right, that's weird. I bought the toytec ultimate coilovers and in the details it says
    "700 lb/in (Silver) - Recommended for Double Cab V8's or with additional weight"
    If you want, you could also use OME coils and get the 2887. I have a whole spreadsheet with OME coils and the size, I can share it if you need it.
    My new to me 06 DC has spacers and they are really rough, so based on my experience I'd avoid spacers and get either longer or heavier coils, or go higher up on the eibach settings..
  2. Aug 26, 2020 at 1:45 PM
    tdn
    tdn [OP] New Member
    Michigan
    2021 CM 4x4
    Well, I’m committed now!Hopefully we’ll get the front raised up tomorrow and be all set. C36F6E78-0131-496F-9891-675DFB8F15F9.jpg
    jsvwx, revtune, Lil Steve and 3 others like this.
  3. Aug 26, 2020 at 2:13 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    I've been watching this as I plan on eventually running a blistein 5100 level/lift and 33x10.5R17's.
  4. Aug 27, 2020 at 3:32 PM
    tdn
    tdn [OP] New Member
    Michigan
    2021 CM 4x4
    Haven’t measured anything yet. But things look great. No rubbing and nice ride! Went to second clip on 5100s and used Wheelers 3/8” poly top plate. Will have some measurements and road report tomorrow.
  5. Aug 27, 2020 at 3:36 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    Looking good!
  6. Aug 27, 2020 at 3:43 PM
    rock climber
    Looks so good!
    Did you do anything to the rear suspension or is it stock?
  7. Aug 27, 2020 at 4:27 PM
    tdn
    tdn [OP] New Member
    Michigan
    2021 CM 4x4
    Stock rear. Well, 5100 shock in the rear but no lift. I had nearly 3” of rake stock.
    abcinv, revtune and bmf4069 like this.
  8. Aug 28, 2020 at 4:45 PM
    Localsnap88
    Localsnap88 New Member
    NJ
    2005 SR5 Doublecab
    SPC UCAs/bushings, Bilstein 6112 Coilovers @ 1.8”, 265/75 Cooper AT3 LT on Method Grid 16x8/ 0 offset, EBC Rotors/Perf Brake Pads, Energy Poly sway bushings, Moog greasable Endlinks, Airaid Synthamax Dry filter, Magnaflow 18” SI/SO muffler , Toyota SS rolled exhaust tip, Spider black housing headlights, Phillips Racing Vision halogens, Eagle Eyes LED smoked tails, Eagle Eyes LED Third Brake, Aftermarket OEM style fogs, full interior LEDs, reverse LEDs, Tinted sides and rear, bug deflector, window visors, AMI Stub Antenna 5” Aluminum/SS/rubber steps, TPMS delete, SAIP blockoff/delete, M1 Synthetic Engine and Diff oils,
    Looks awesome brother , enjoy. I’ve got the exact same 05’ silver metallic DC. Can you take your final center hub to fender edge measurements front and rear when you get a minute ? I did Bilstein 6112s and SPCs bout 6 months ago but never really took great “before “ measurements so still curious about how much lift I’m at . ✌
    tdn[QUOTED][OP] likes this.
  9. Aug 29, 2020 at 4:57 PM
    tdn
    tdn [OP] New Member
    Michigan
    2021 CM 4x4
    I’ll have to get a few minutes to get more exact (it’s tougher w deeper dished rims and wide tires) but a quick glance looks like 22” up front and 22 1/8” rear
    revtune likes this.
  10. Jan 2, 2021 at 4:56 PM
    JODOOR
    JODOOR New Member
    Joshua
    2004 Limited DC 4x4
    Hey, sorry to revive this thread, but I am running into the same problem with my leveling set up. When you added the spacers, did you also opt to get the longer studs or stayed with the stock ones? I have the 5100s with OME 885s on the bottom perch and got 1.5" at best.
    Also, how are you liking Toyo Open Country AT3s? I just snagged a set of SCS F5s and plan to stick the same exact tires you have on them as soon as they come in.
  11. Jan 2, 2021 at 7:23 PM
    tdn
    tdn [OP] New Member
    Michigan
    2021 CM 4x4
    I was able to retain the stock top hat studs and just get full thread engagement. All looks well after 4 months of use.
    I have really been liking the AT3s! There is a bit of humming over 40mph but not as bad as the worn K02s that they replaced. Great in the rain and so far fine in the snow. Have 7k miles on them so far and I'm very happy. Definitely get the C rated ones. No need for the weight of a E rating on our trucks.
    JODOOR likes this.
  12. Jan 5, 2021 at 1:43 PM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    What is your hub to fender measurement?
  13. Jan 6, 2021 at 11:15 AM
    JODOOR
    JODOOR New Member
    Joshua
    2004 Limited DC 4x4
    Hub to fender is right about 20 3/4 on both sides up front and 23 in the rear. Previous owner added blocks to the rear, which I don't mind, will hopefully level the truck when I eventually get a shell.
  14. Jan 6, 2021 at 11:24 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Thanks. You should add that here since you have a unique setup
    https://www.tundras.com/threads/how-big-is-yours-measure-up.46186/
  15. Jan 6, 2021 at 4:25 PM
    Localsnap88
    NJ
    2005 SR5 Doublecab
    You ever get a good hub-fender measurement or could you do an updated now that it’s been a bit brother? Still around /almost 22”?
