Shock shopping
Discussion in 'Suspension' started by ColoradoTJ, May 6, 2016.
  1. May 16, 2016 at 9:48 AM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    You tune a shock's ride characteristic based on the valve shims inside the shocks. I'm guessing this is a foreign to you, but it's a series of thin washers that progressively change in size. Different thickness shims results in a different shock dampening profile. Revalving (changing the shim count, configuration, and thicknesses) is what us big boys do. Change it the wrong way...the truck rides like shit. I could throw in a double stack of .020" shims on your comp and rebound and plug the free bleeds and you would hate your shocks.
    276FBC87-F323-4924-8982-1D81F70A1B70-257_5f534a0d0f356c0ee1f3b2f32e0b625fab867992.jpg
  2. May 16, 2016 at 10:16 AM
    ColoradoTJ [OP] Certified tow LEO Staff Member
    They are pretty easy to tune. Most of us in rock racing do flutter stacks, where as a tundra may not want that at all.
    I like seeing people valving their own shit. Almost brings a tear to my eye.
  3. May 16, 2016 at 10:34 AM
    jberry813
    Lake Tahoe
    I did comp flutters on my tundra, but I put the flutter between the second and third shims. Cushy ride around town, and stiffened up the high speed shims for doing stupid stuff. Works really well.
    Front:
    170-.010
    160-.010
    100-.010
    160-.012
    145-.012
    130-.012
    100-.012
    over .012 rebound
    Rear:
    175-.010
    160-.010
    100-.008
    145-.012
    130-.012
    115-.012
    100-.012
    over .010 rebound
  4. May 16, 2016 at 12:20 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Honestly i didnt know how valving was accomplished mechanically. Now i do.
    Question @jberry813. If you took an Icon, King and Fox shock of same diameter and added the same exact valving to each would they all ride the same or is there characteristics of each that would make them ride any different?
  5. May 16, 2016 at 1:00 PM
    Pretty cool setup. I bet that does work pretty good from the looks of it. Ever consider running a bypass shock along with your CO setup?
    I have a friend in CA that runs Fox CO's up front, Deaver spring pack out back with a ADS triple bypass on all four corners. Hold shit he can hit some big shit at 90 mph in the desert.
  6. May 16, 2016 at 1:57 PM
    jberry813
    Lake Tahoe
    They would all ride different. There are SOOOOO many variables. King uses a different material for their shims than Icon and Fox. Icon uses a two piece dished piston that preloads the shims making a digressive dampening profile. King's piston has 6 compression flow ports and 3 rebound flow ports while fox uses 4 and 4 but oval ports. The piston sizes are all different masses. The valving is just one piece of the puzzle.
    I've got bypasses on all 4 corners of my Tacoma and literally hundreds of hours in tuning/revalving. Figured it would be completely overkill for the grocery getter/tow pig.
    http://www.fourwheeler.com/features/this-2004-toyota-tacoma-owner-has-his-cake-and-eats-it-too/
    MotoTundra, bandit, omaguz and 2 others like this.
  7. May 16, 2016 at 2:20 PM
    Yep, total waste of money and time on a DD.
    bandit and Black Wolf like this.
  8. May 16, 2016 at 2:21 PM
    csuviper
    Broomfield, CO
    That is what i figured. Just saw this comment from you "Good ride and bad ride has nothing to do with the shock brand (Fox vs King vs Icon vs xxxx), it's all about the valving." and thought i would ask.
    jberry813[QUOTED] likes this.
  9. May 16, 2016 at 2:23 PM
    Thread cleaned
    jberry813 likes this.
  10. May 16, 2016 at 2:31 PM
    jberry813
    Lake Tahoe
    Now I'm making thread dirty...with a King and Fox combination :cookiemonster:
    MotoTundra, bandit, trayday and 6 others like this.
  11. May 16, 2016 at 6:15 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    @jberry813 can I send you my foxes to be set up!? :hattip:
  12. May 16, 2016 at 7:16 PM
    jberry813
    Lake Tahoe
    Kinda hard to do with truck not here and getting some butt time in the seat. I kinda have an OCD problem and need to see it and feel it. It's also subjective. What feels tits to me may not be the same perception of others. Spring rate, preload, and truck config all play a role as well.
    But...if you tell me what you got in there now, what it's doing (video helps), and what you want it to do and I'll certainly send you recommendations. Lot cheaper to get someone local to valve it than shipping to me.
    2cID and T-Rex266 like this.
  13. Jul 16, 2016 at 3:28 PM
    To update this thread a little:
    -I was waiting a bit to see if we were going to keep the Tundra or not. We....let me rephrase, I am keeping my 12' Tundra. The research I did on 3/4 ton diesels would put me in the same boat that had me running to a Tundra. F that. This truck needs to stay for 2 more years or 150-175K miles on the clock.
    - I will be ordering a set of Bilstein 6112 and 5160 rears (may have to go with the 5100's due to length). I have wanted a smooth ride on/off road. All the research I have done so far has lead me to this setup and is the next best thing to a King/Fox CO. The pricing has come way down (found them for 599.00 shipped) so this is more tempting than ever.
    -On the rear, the ToyTech shackle will most likely be utilized for my needs. They make great products with very good pricing.
    Since the truck is staying, I'm going to enjoy it. Been looking at 17" wheels and want to make them flush with the fenders, or maybe get flairs and make those flush.
    MotoTundra and bandit like this.
  14. Jul 16, 2016 at 4:22 PM
    Vizsla
    Vizsla 2 = 2.5
    You will love 6112/5160 combo(compromise on rear 5100s if a must, have patience with 6112s), our trucks love a 2.5" shock, no 2" 5100, Toytec, Procomp, Fox, definitely not OME, etc., can be compared(there is a big difference). That being said, if I wanted a best bang for buck ride improvement/lift on a 2nd gen and up without paying for UCAs, I would do Fox 2.0 front and rear. 17" rims on our trucks are way cool!
    2cID and ColoradoTJ[QUOTED][OP] like this.
  15. Jul 16, 2016 at 9:37 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Yep. You've got C/Os. Kings with dual rate springs? I've got the 4600's from my 2016 TRD with very few miles that I'd let go really cheap if you're interested.
  16. Jul 16, 2016 at 9:48 PM
    Yes, those are 14" 2.5 Kings. 150/200 front and 125/150 rear.
    Thank you for the generous offer for your next to new shocks. I appreciate that but I am looking for some added performance since I have 4600's now.
    These roads (pavement) in Colorado suck. Starting to think a trophy truck might be needed or the daily commute.
    2cID, Wvmoonshiner and zcarpenter92 like this.
  17. Jul 18, 2016 at 12:38 PM
    Dropped the coin today. Bilstein 6112 and 5160's on the way.
    My shocks must be really shit...my truck has never been smooth good anyway, so this should be a major improvement.
    So, I purchased my shocks from two different places:
    Shock warehouse was not the cheapest but had them on hand for the 5160. 175.00 each, free shipping.
    Ebay 6112 kit for 599.00 free shipping.
  18. Jul 18, 2016 at 4:05 PM
    Vizsla
    Vizsla 2 = 2.5
    Order a shim for the driver side, you will likely need it. My stock driver side coil on both my 12 and 16 are 1/4" taller than passenger coil. 12 leaned after Fox c/o with no shim, 16 is even with shim. Both were even before lift.
  19. Jul 18, 2016 at 4:20 PM
    #49
    TheBeast The Beach
    ColoradoTJ[OP] likes this.
  20. Jul 18, 2016 at 5:16 PM
    #50
    I will wait for the install to see if a shim is needed, but totally plan on it.
    Thanks for the heads up and looking out for a brother!
  21. Jul 21, 2016 at 5:56 PM
    #51
    MotoTundra and Black Wolf like this.
  22. Jul 21, 2016 at 6:25 PM
    #52
    TheBeast The Beach
    that's what she said...
  23. Jul 21, 2016 at 6:49 PM
    #53
    MotoTundra
    MotoTundra The Ocho
    Don
    They look great, can't wait to hear how they work out for you.
  24. Jul 21, 2016 at 6:54 PM
    #54
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Ya oughta do a review on that setup dude. That's one of the ones I'm thinking about.
    #54
  25. Jul 21, 2016 at 8:01 PM
    #55
    bandit
    bandit New Member
    2011 Supercharged Mazzulla Long Travel Rock Warrior
    Duh Tundra
    If you don't make your own shims, we're not friends anymore. :annoyed:
    Why U no install dem yet!!! :duel:
    ColoradoTJ[QUOTED][OP] and 2cID like this.
  26. Jul 21, 2016 at 9:31 PM
    #56
    jberry813
    Lake Tahoe
  27. Jul 21, 2016 at 9:39 PM
    #57
    I hear it all the time...never gets old though....buahhhahhhhhaa
    zcarpenter92 likes this.
  28. Jul 21, 2016 at 9:40 PM
    #58
    I ordered Coachbuilder shims. I can't machine shims for 18.00.
    bandit[QUOTED] and jberry813 like this.
  29. Jul 21, 2016 at 9:41 PM
    #59
    jberry813
    Lake Tahoe
    It's not even worth it. The design and machining time is beyond what it costs for the CB shims.
  30. Jul 21, 2016 at 9:42 PM
    #60
    bandit
    bandit New Member
    Duh Tundra
    I thought we were friends....bye felicia :burnrubber:
