Shims and affect on suspension
Discussion in 'Suspension' started by 94slowbra, Nov 10, 2020.
  1. Nov 10, 2020 at 3:25 PM
    94slowbra
    94slowbra [OP] New Member
    john
    new orleans
    2016 TRD pro
    2016 pro, currently has 1 shim up front on each side. Thinking of adding another and want to know how it affects the suspension: ride quality, travel ect... Essentially is a top spacer, which we knows makes trucks ride like shit, so what's the difference? Is it just not tall enough to have a negative effect? Any downside to adding another? Truck rides fine for my liking currently so I don't want to alter it to much, just want that little extra.
    Thanks
  2. Nov 10, 2020 at 3:33 PM
    cook2kill
    cook2kill PNW
    Portland OR
    2018 CM
    I'm Running CB Shims up front with no issue. Ride is fine and rake looks stock with the rest of my suspension components. I have 2 on the driver side and 1 on the passenger.
  3. Nov 18, 2020 at 9:04 PM
    Tundra_power
    Tundra_power New Member
    Nick
    Do you have stock bump stops
  4. Nov 19, 2020 at 1:07 PM
    cook2kill
    cook2kill PNW
    Portland OR
    2018 CM
    No, I also have a suspension lift.
  5. Nov 19, 2020 at 2:07 PM
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    El Cajon, CA
    Essentially a top spacer, or it is a top spacer? Does it go above the coilover shock?
    Spacers are not recommended, and stacking them is also not a good idea.
    Adding spacers increases the extended length of the shock far beyond what the suspension is designed to do. You will risk the UCA hitting the spring, steering & cv binding and potentially blowing out the shock. Have you seen this thread?
    https://www.tundras.com/threads/recently-broke-my-front-shocks-need-help-on-choosing-new-ones.23986/
    DeesCrewMax likes this.
  6. Nov 20, 2020 at 7:52 AM
    cook2kill
    cook2kill PNW
    Portland OR
    2018 CM
