Shifter boot mod
Discussion in '2.5 Gen Tundras (2014-2021)' started by Andrew19, Jul 12, 2019.
  1. Jul 24, 2019 at 3:49 PM
    #61
    hypa
    hypa New Member
    #61
  2. Jul 24, 2019 at 3:53 PM
    #62
    hypa
    hypa New Member
    Here's what my interior looks like now with the AJT shift and temp control knobs.
    Mountun Goat and Jim LE 1301 like this.
  3. Jul 24, 2019 at 6:35 PM
    #63
    Like the steering wheel. Do you have a better picture?
  4. Jul 24, 2019 at 6:50 PM
    #64
    Fiestee23
    Fiestee23 A CHICK'S TRUCK
    SOCAL
    White sr5 4wd
    It was a group buy... So not what it is now. Phoenix Android... Here is the FB page... I think they are still doing discounts on the 3Rd Gen.
  5. Jul 27, 2019 at 11:30 AM
    #65
    Rustedfenders
    Rustedfenders If it ain't broke, don't fix it.
    Wally
    Rosedale Md.
    2016 Blazing Blue Pearl TRD Tundra Crew Max
    Aries 4" Bull Bar, 3-2 Level Lift Havoc Stainless hoop steps.
    How hard was it to pop the chrome trim off?
  6. Jul 29, 2019 at 6:43 AM
    #66
    voz
    voz New Member
    2016 Tundra
    Whats the thread pitch for knob?
    trying to get one custom made...
  7. Jul 29, 2019 at 8:45 AM
    #67
    Rustedfenders
    Wally
    Rosedale Md.
  8. Jul 29, 2019 at 9:42 AM
    #68
    voz
    voz New Member
    2016 Tundra
    Got it THANKS A BUNCH!!
    Shift knob on order, I have a carbon look boot, with no accent color which is just what I needed...
  9. Jul 29, 2019 at 8:15 PM
    #69
    greggm
    greggm New Member
    Gregg
    Los Gatos, CA
    2019 CM TRD 4x4
    So I completed my install, but think it looks kind of crunched up, did you guys trim the boot to eliminate some of the excess? I'm considering a trim... What do you think?
    Mountun Goat likes this.
  10. Jul 29, 2019 at 8:24 PM
    #70
    Pull it down more and tuck it in.:thumbsup:
    greggm[QUOTED] likes this.
  11. Jul 29, 2019 at 8:26 PM
    #71
    Pinay and greggm[QUOTED] like this.
  12. Jul 29, 2019 at 8:32 PM
    #72
    easleycrawler
    Travis
    Easley, South Carolina
    19 TRD SPORT CM MGM 4WD
    Yep, what Jim said.
    Pinay and greggm like this.
  13. Jul 29, 2019 at 9:18 PM
    #73
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Jim, to pull the silver trim off, do i just use a plastic pry tool and work my way around. Or is there another way.
    Thanks
    #73
    Pinay and easleycrawler like this.
  14. Jul 29, 2019 at 9:21 PM
    #74
    easleycrawler
    Travis
    That's exactly it. :thumbsup:
    Ely010606[QUOTED] likes this.
  15. Jul 29, 2019 at 9:25 PM
    #75
    Ely010606
    SPARKS, NV
    Thanks, Travis.
    easleycrawler[QUOTED] likes this.
  16. Jul 30, 2019 at 2:31 AM
    #76
    That's the way.:thumbsup:
  17. Jul 30, 2019 at 5:43 AM
    #77
    Ely010606
    SPARKS, NV
    Thanks, Jim.
  18. Jul 30, 2019 at 10:12 AM
    #78
    :hattip:
  19. Jul 30, 2019 at 1:59 PM
    #79
    hypa
    hypa New Member
    Sorry for the delay Jim, I was out of town for a bit. I got the wheel from Vivid Racing. Their link has much better pics than I could ever take.
    https://www.vividracing.com/toyota-...-oem-upgraded-steering-wheel-p-152408188.html
    It wasn't cheap, but I put about a thousand miles on my truck in the last week and the wheel felt great.
    Jim LE 1301[QUOTED] and voz like this.
  20. Jul 31, 2019 at 5:58 AM
    #80
    voz
    voz New Member
    2016 Tundra
  21. Jul 31, 2019 at 11:57 AM
    #81
    hypa
    hypa New Member
    I was familiar with the changeover, so it took about a half hour to swap the wheel over.
    I did have to take it to my friend's alignment shop though, as the wheel wasn't centered. It needed some adjustments in the steering components which isn't uncommon.
    Just be careful with the clock spring. They're $400 to replace and very fragile.
    voz likes this.
  22. Jul 31, 2019 at 3:38 PM
    #82
    RBDTx
    RBDTx New Member
    2019 Tundra TRD Pro White
    Were you able to get it unscruntched. Mine is sort of scrunched too.
  23. Aug 1, 2019 at 3:24 AM
    #83
    Wow, that is expensive. That is one good looking steering wheel. It's out of reach for me right now, maybe sometime in the future. Thanks for the link.
    hypa[QUOTED] and voz like this.
  24. Aug 1, 2019 at 11:05 AM
    #84
    greggm
    greggm New Member
    Gregg
    Los Gatos, CA
    2019 CM TRD 4x4
    I made another attempt and it's a bit better, I am going to try again this weekend...
  25. Aug 1, 2019 at 2:31 PM
    #85
    RBDTx
    RBDTx New Member
    Same here, will try again this weekend. I also plan to trim the bottom before it meets any threads as well. There is plenty of material under the trim panel.
  26. Aug 1, 2019 at 4:06 PM
    #86
    Rustedfenders
    Wally
    Rosedale Md.
    20190801_184448.jpg My changeover went pretty good. Took a little longer due to extending the shaft.
  27. Aug 1, 2019 at 4:58 PM
    #87
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I did mine about 3 years ago....
    Mountun Goat and RitcheyRch like this.
  28. Aug 3, 2019 at 3:56 PM
    #88
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    Do I need to cut the white plastic at the bottom of the shifter? How do you get the boot and the bottom of the knob to stay together?
  29. Aug 3, 2019 at 5:15 PM
    #89
    Yes, if it's the Tacoma TRD shifter. Doing that allows the boot to sit closer to the shifter handle. Just shave it enough for the chrome ring on the boot to fit snugly on the bottom of the new handle.
    Ely010606 likes this.
  30. Aug 3, 2019 at 5:32 PM
    #90
    RBDTx
    RBDTx New Member
    I did not cut the white pieces on the Tacoma knob. I cut the zip tie holding the ring on the new boot to remove the chrome ring, and then used a new small zip tie to secure the boot directly to the white plastic pieces(they seem to have a ridge intended for that). Had to screw the knob on first and then tuck in the boot through the trim, then secure the trim, but it seemed to work.
    jclem65, voz and Ely010606 like this.
