Shell 91 V-power!!
Discussion in '2.5 Gen Tundras (2014-2021)' started by tundraxp, Dec 10, 2016.
  1. Dec 15, 2016 at 6:44 AM
    Ericsopa
    Ericsopa Old man and the sea
    Toyota does indicate that 87 octane should be used, as do all automakers. But that's for sea level up to roughly 3000' elevation. Above that 86 octane is the standard for regular gas, and is okay to use due to the thinner air. I don't know why the station near me is selling 86 octane E0, or where they are sourcing it from.
  2. Dec 15, 2016 at 6:47 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    There are some engines, notably supercharged or turbocharged, that can compensate for higher octane and produce more horsepower. Take for example the new Mazda CX-9 that has a turbo 4. On 87 octane it makes about 228 hp. At 93 octane it makes 250 hp. It makes spending more for higher octane gas worthwhile.
    The engines in our Tundras do not have the ability to take advantage of the higher octane. So no improvement in hp or fuel mileage.
    Top tier gas is really about the detergents that are blended in and how well they keep the fuel system and engines clean.
    Ethanol is hydroscopic like brake fluid. It wants to absorb water, so if you have ethanol gas that sits around (like my seldom used boat) it absorbs water from the atmosphere and can damage the fuel system and engine.
    CM-LENNY and T-Rex266 like this.
  3. Dec 15, 2016 at 6:50 AM
    Ericsopa
    Exactly! But I know you meant to say ethanol absorbs water from the atmosphere, not gas! :D
  4. Dec 15, 2016 at 6:54 AM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    :duel:
    GNTundra likes this.
  5. Dec 15, 2016 at 6:57 AM
    Ericsopa
    No duel here......people are free to waste their money if they wish.
    FumundaTundra likes this.
  6. Dec 15, 2016 at 7:02 AM
    gdiep
    Syracuse, New York
    Agree. I would spend my money on 87 octane that has better detergents. Or I would spend my money on higher octane if my engine were designed to take advantage of it (my past Audi and BMW did). Or I would spend money on non-ethanol gas if I knew it would sit around a while like my boat. But I would not spend money on higher octane for the tundra.
  7. Dec 15, 2016 at 7:02 AM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    :crapstorm::help:
  8. Dec 15, 2016 at 7:04 AM
    gdiep
    Syracuse, New York
    Fixed. Thanks.
  9. Dec 15, 2016 at 7:07 AM
    I use Shell a lot. Corn should be for human food/cattle feed only. Period.
    FumundaTundra, T-Rex266 and Ericsopa like this.
  10. Dec 15, 2016 at 10:10 AM
    VA10
    VA10 New Member
    2020 Tundra Limited TRD Off-Road
    To my understanding the only possible benefit of running higher octane gas in engine rated for regular is the below.
    Typically w/ quality brand names like exxon,mobil,shell, or cheveron is that the higher octane gas usually contains more cleaning agents/detergents than their regular gas........so i can only see running a tank of 93+ every couple or weeks or months. Otherwise i will use fuel system cleaning additive.
  11. Dec 15, 2016 at 10:45 AM
    Ericsopa
  12. Dec 15, 2016 at 10:52 AM
    VA10
    VA10 New Member
    correct....top tier basically means they put more additive/cleanings agents in their mixtures than the gov. requires.Right?
    From my understanding the higher octanes can contain more concentrated levels of detergents and other additives than the brands regular gas...it is still considered top tier if the brand is top tier.
  13. Dec 15, 2016 at 10:59 AM
    gdiep
    Syracuse, New York
    I'm not an engineer, but my brother is a research scientist with a PHD in Chemical Engineering. He said that gas companies general put the same "additive package" into their gas regardless of what octane level gas they are producing. They may modify the "additive package" based on time of year (winter vs summer formulation), region and climate it is being shipped to, or specific regulations of each state. Therefore, top tier gas is top tier regardless of the octane level.
    Maybe there is a member on this forum that is an engineer from the Oil & Gas industry that can verify.
    GoHuskers likes this.
  14. Dec 15, 2016 at 11:00 AM
    VA10
    VA10 New Member
    Get all the info out of your brother possible and post it here!!! haha sadly i have to go off the internet and this one gas station owner i spoke with.
  15. Dec 15, 2016 at 11:02 AM
    Ericsopa
    Sort of, but you should read the info in the website for the answer to your question. And from what I read there, they probably could use a little more additives in the higher grade if they wanted to, but based on what is indicated on the website, I don't know why any company would want to use any more additives in the higher octane. The standard for all grades is very high, according to them.
  16. Dec 15, 2016 at 11:03 AM
    gdiep
    Syracuse, New York
    He gave me an education on gas and oil one day. I made it about 45 mins before things started flying way over my head.
    VA10[QUOTED] likes this.
  17. Dec 15, 2016 at 11:36 AM
    gdiep
    Syracuse, New York
    I guess it is theoretically possible that you can put such an increased load on your engine to increase temps enough to cause knock. However, if your cooling system is functioning properly, I think the increase in temps in the range of 10- 20 degrees would not be enough to significantly affect knock. However, you're right, people should put whatever octane level they think is best for them as long as it is minimum of 87. My point is this...if I had to choose between spending 10 cents more for top tier 87 or 10 cents more for run of the mill 89, I would go for the top tier fuel. At least you would know that the fuel has a better additive package. Of course you can always go for higher octane top tier fuel and eliminate the doubt.
  18. Dec 15, 2016 at 11:43 AM
    GoHuskers
    GoHuskers New Member
    Nebraska
    '24 iForceMax, '17 RX350, '15 GX460
    I agreed with this statement. I also read and watched the videos from Top Tier website to confirm this statement is true.
    One time I spoke to the gas delivery tanker driver at the Shell station and he said that he got the tank filled with gas from THE SAME supplier but he delivers it to different gas stations of different brands. The only different is the additive packages.
    scurdyness likes this.
  19. Dec 15, 2016 at 6:48 PM
    #49
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I think that I recall an article or news report saying that the corn used for Ethanol production is so crap that it isn't even fed to cattle/hogs. Goats maybe, they'll eat anything, just about literally.
    I thought that we had a member here that was in the petroleum industry, I just can't remember his handle. His avatar was b/w and kind of cartoony.
  20. Dec 15, 2016 at 6:56 PM
    #50
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yeah, Pedro but he's a chemist. @Cubanchem
    Wynnded[QUOTED] likes this.
  21. Dec 15, 2016 at 7:09 PM
    #51
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    YES, that's him. I'll bet that he still has a light he can shine on the debate though.
    joonbug[QUOTED] likes this.
  22. Dec 16, 2016 at 8:16 AM
    #52
  23. Dec 16, 2016 at 8:42 AM
    #53
    tundraxp
    tundraxp [OP] New Member
    Michael
    Tundra xp 4x4
    Rims and tires
    Hallelujah!!!! Idgaf how everybody else drives and the EXACT miles I get per gallon. I'll drive the way I want. Sometimes I feel like driving like fast n furious, sometimes I feel like driving miss daisy and if the gas that I put in my truck makes me feel the way I do, so be it...take my money. It's like putting on cosmetic mods, wtf for? Doesn't give u better mpg. Who the fu.k cares? It's not ur truck, let them do the fu.k they want.
    AnonVet[QUOTED] likes this.
  24. Dec 16, 2016 at 11:35 AM
    #54
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    PREACH!! but I will say this, taking off the chrome and debadging my truck gave me atleast 10mpg more then I had before :DDD
    831Tun and scurdyness like this.
  25. Dec 16, 2016 at 11:54 AM
    #55
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    You got a 10 MPG increase ? I still have my chrome grill and cup holder surround so should i expect something around 9 MPG increase ?
  26. Dec 16, 2016 at 12:00 PM
    #56
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    Ya that's about right haha. once I get rid of the chrome rings around my air vents I'll be sitting at a solid 15mpg gain.
  27. Dec 26, 2016 at 5:14 AM
    #57
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    +1, made no difference on my Tacoma
  28. Dec 26, 2016 at 5:20 AM
    #58
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Nope, ethanol free is preferred because most boat owners leave gas in tanks for a while. My Merc runs fine on gas with ethanol as long as it is fresh or treated. Fuel lines can be a problem unless you have replaced with ethanol resistant. I lost 200 rpms at WOT when they changed the formulas around here years ago but other than that no problems.
  29. Dec 26, 2016 at 10:00 AM
    #59
    MatthewPTguy
    MatthewPTguy Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    HAHAHAHAHAHA!!! That's funny... I was born in NJ... now live in Oregon... I miss Wawa and Tastycake pies!
  30. Dec 26, 2016 at 10:03 AM
    #60
    MatthewPTguy
    Eugene, Oregon
    I had a 1993 F150 with a 5.0 V8 back in the day... the thing would knock all day on 87... no knocking on 91... but that was before the days of knock sensors and VVT... I run 87 all the time..
