Sharkfin Height after Leveling Kit
Discussion in '2.5 Gen Tundras (2014-2021)' started by davidbii, Aug 20, 2020.
  1. Aug 20, 2020 at 10:11 AM
    davidbii
    davidbii [OP] New Member
    David
    Hey Folks - I've got a new 2020 1794 and was planning on doing a leveling kit to get rid of the Tundra Rake...but I also park it in my garage, so height is a potential issue...does anybody have the overall height difference on the 2020's after adding the leveling kit? I know it raises about 2.5" on the front, but since the back doesn't get lifted, and you're basically using the rear as the fulcrum for the lift, I don't think the Shark-Fin antenna raises the full 2.5", but I'm curious if anybody has that actual height difference of the Fin over the stock height...THANKS!
  2. Aug 20, 2020 at 10:44 AM
    Hurricane
    Hurricane Default: Aggressive
    NC
    2017 White 1794
    None
    I wouldn’t imagine it would raise it more than an inch or so at most. If you are close to touching now you should maybe be concerned but if you have 5-6” or more, I wouldn’t worry much about it.
  3. Aug 20, 2020 at 10:55 AM
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    I did a 3/2 leveling kit and 35" tires. I can still get inside the garage and it's just a standard 7ft door.
    Derf77, Ely010606 and TheBeast like this.
  4. Aug 20, 2020 at 11:33 AM
    ohreary
    ohreary Party!
    2020 Platinum
    thanks for this. i was a little concerned about being able to get in my garage as well after leveling and bigger tires.
    Dragracer_Art likes this.
  5. Aug 20, 2020 at 3:58 PM
    Johnnyquad
    Johnnyquad New Member
    21 Pro double cab MGM
    Tint, clear bra, OEM stereo upgrade, tonneau cover, line x, 285/65/18 Toyo AT3
  6. Aug 20, 2020 at 4:15 PM
    JcGc
    JcGc New Member
    2020 Crewmax 4x4
    4/2 Ready lift Kenda Klever 35 x 12.50 x 20 XF Off road wheels
    I have a 4/2 with 35" and still park in my garage, the shark fin is close, but you should be fine.
  7. Aug 20, 2020 at 4:23 PM
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
  8. Aug 20, 2020 at 10:39 PM
    davidbii
    David
    Sweet! Thanks for the info.
  9. Aug 21, 2020 at 9:35 AM
    java230
    java230 New Member
    3/2 on 34" tires and I am under 7'
  10. Sep 11, 2020 at 2:22 PM
    davidbii
    David
    Thanks for the information, now I just have to figure out which direction to go for the leveling kit...
    Black Wolf likes this.
  11. Sep 11, 2020 at 2:29 PM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    @Toytec Lifts
  12. Sep 11, 2020 at 2:30 PM
    davidbii
    David
    Anybody install Eibachs? A guy at the dealership had a set that looked pretty nice
