Share your tow experiences to a possible Tundra owner
Discussion in 'Towing & Hauling' started by northstar, Jan 15, 2019.
  1. Jan 16, 2019 at 11:45 AM
    Steve89gt
    Steve89gt New Member
    2018 Limited CM
    De-badged, De-chromed, TRD CAI, TRD Exhaust, Bilstein 5100s, Fuel 18 x 9 wheels, BFG KO2s 275/70/18, ESP Underseat Storage
    For something that size, I'd suggest keeping an eye on your payload; I think the Tundra is rated at around 1500 pounds of payload, so it could become an issue. Not saying the truck won't do it, but "it's rated for it" does not equal "it's a good idea". I tow a 5000 pound trailer quite regularly and it works fine, minus the typical bitching about poor gas mileage <shrugs>. Just my .02
    northstar[OP] likes this.
  2. Jan 16, 2019 at 11:48 AM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    I tow this big gurl... towed over 500 miles in one direction.. no issues. Ok minus the blow trailer tire... that was my fault the tires were sun rotted, and i ended up blowing three in 50 miles.. now i have all new tires
  3. Jan 16, 2019 at 1:01 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Which 2016 OP? Here’s the exact page from my link re payload, look at that sweet cap on the 4x2 reg cab >500lb more than the 4x4 crew!
  4. Jan 16, 2019 at 1:04 PM
    northstar
    northstar [OP] New Member
    I've seen that doc, it's where I got the 1000lb TW. I am considering a 4x4 double cab.
    Yes interesting about the 4x2 reg. I've heard that the crewcabs sometimes haul less but didn't think about the smaller truck hauling more.
  5. Jan 16, 2019 at 1:32 PM
    lawfarm
    lawfarm New Member
    2018 Tundra SR5 Premium TRD Crewmax
    I've pulled that same load (7500 horse trailer) all over the midwest with no issues. I did install airbags to decrease squat a bit, but she pulls without issue regardless of weather and temp. In hot weather, I do pin the thermostat on the transmission.
    northstar[QUOTED][OP] likes this.
  6. Jan 16, 2019 at 1:33 PM
    lawfarm
    lawfarm New Member
    I should've noted--search pinning the thermostat if you're towing in hot weather! Otherwise, trans temps will get up to uncomfortable levels.
  7. Jan 16, 2019 at 1:36 PM
    northstar
    Thank you! Do you mind sharing how long your trailer is? I assume bumper pull?
  8. Jan 16, 2019 at 4:05 PM
    Steve89gt
    2018 Limited CM
    How does one go about doing that?
  9. Jan 16, 2019 at 4:11 PM
    Professional Hand Model
    Hand Protectors
    One time, after sleeping at Holiday Inn, I woke up and felt like I could tow a Space Shuttle.
    Hondoman likes this.
  10. Jan 21, 2019 at 3:40 PM
    Heeler13
    Heeler13 21MGM
    Eastern NC
    2021 Sr5 XP
    Bilstein 5100 Front @ middle setting Bilstein 5100 Rear @ stock height Oem older Pro wheels 285/75/18 Maxxis Razr a/t
  11. Jan 23, 2019 at 5:23 PM
    northstar
    Late update: I went with a 2019 CrewMax SR5 upgrade and TRD package! Very fun to drive and I CANNOT WAIT to hitch up a trailer!!!
    ColoradoTJ likes this.
  12. Jan 30, 2019 at 10:24 AM
    pvsprme
    pvsprme New Member
    2017 DC TRD
    ARE shell
    You’re going to be very happy with your choice. I towed a 22’ Arctic Fox trailer, 6500 lbs.+ and about 500 lbs in the bed under a shell from Central California to Jasper and Banff. The Canadian Rockies were a great test and the Tundra exceeded expectations. I will add some air bags to the rear, otherwise it’s great. Braking and power so much better than the 2004 GMC Z71 it replaced. I got 8.9 mpg over 4000 miles towing, mostly at 65 or less in some Canadian roads due to speed limit. It’ll pass anything but a gas station, glad I got the 38 gallon tank.
  13. Jan 30, 2019 at 2:29 PM
    Red Dragon
    Red Dragon New Member
    Pocatello, Idaho
    2015 Barcelona Red Limited TRD
    I tow a 30’ Jayco trailer which fully loaded weighs 7,000. I use tow-haul and go 65 mph. Took a trip with it to Island Park, Idaho up the Ashton hill and back down and averaged 8.8 mpg. It was my first time towing with this truck, and I had plenty of power and was very pleased with how well my truck towed.
  14. Jan 30, 2019 at 2:37 PM
    What in the hell did you run over with the skid plate?
    I wanna drive your truck...like bad.
  15. Jan 30, 2019 at 2:38 PM
    Congratulations!!!
    Same rule applies to the ladies on this site.....pics of your new ride!!
  16. Jan 30, 2019 at 2:46 PM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    hahahaha
    wellll i was in parker AZ on a trail and forgot about this little wash and instead of slowing to 10-15 mph i hit this thing at 35... and it was a 2-3ft drop off about 6-8 ft wide then another 2ft back up.. so went off the edge and smashed into the other side came to a complete stop.. got out checked for damage, realized it was just the skid got back in and kept driving..
  17. Apr 23, 2021 at 10:20 AM
    Joybell
    Joybell New Member
    It depends where the axles are placed. In a 2 horse slant load they are placed as far back as possible. In a two horse straight load they are about a foot ahead of that placing. That can make a difference of 200 or more lbs on the tongue. If you install a weight distribution hitch (necessary) it will distribute the weight over the truck axles and send some back to the trailer axles as well. A trailer salesman will always say that your half ton can tow the trailers you are interested in. I towed a Mortiz steel 13' slant load 3200 lbs empty 725 lbs tongue weight with a distribution hitch. That is about the max tongue load I would go with and it is good to not load up the tack room with stuff you don't really need.
