Shake in front end
Discussion in '2.5 Gen Tundras (2014-2021)' started by socaljerry82, Mar 29, 2023.
  1. Mar 29, 2023 at 7:20 AM
    socaljerry82
    socaljerry82 [OP] New Member
    Gerald Brancato
    Black 2019 Toyota tundra limited crew cab
    fiberglass bed cover
    I have a 2019 tundra 4 door limited with 50,000 miles on it, it has a very bad shake in the front end, toyota said it was brakes but it does it when your crusing down the road without using the brakes, the shake has been going on for 25,000 miles, I have $400 brakes on the front end it is not the brakes, any ideas of other trucks shaking or maybe bad parts???
  2. Mar 29, 2023 at 7:31 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Rotate the tires to eliminate that variable.
    When braking from speed does the shake change and get worse? Messed up toe can to that.
    id rotate, test, then get an alignment. Maybe you have a stuck brake piston?
  3. Mar 29, 2023 at 7:32 AM
    A warped rotor can cause a shake without touching the pedal.
  4. Mar 29, 2023 at 7:51 AM
    PermaFrostTRD
    Northern NY
    All of these good suggestions. Shoot a temp gun at both front wheels after a trip down the highway to compare vs both rear wheels. If there's a significant difference, could be a stuck piston, caliper, warped rotor etc.
  5. Mar 29, 2023 at 8:11 AM
    Retired...finally
    If you have 4wd, see if it shakes in 4hi.
  6. Apr 1, 2023 at 5:10 AM
    SoTexTundra
    SoTexTundra New Member
    19 DC TRD OFF-ROAD
    I have a 19 dbl cab trd-off road with a steering wheel shake as well and I changed my tire pressure back to what is recommend on the door jam sticker and my shake went away.
    norma30a likes this.
  7. Apr 1, 2023 at 5:17 AM
    Retired...finally
    Are you seeing any cupping or feathering on your front tires?
  8. Apr 1, 2023 at 5:21 AM
    SoTexTundra
    19 DC TRD OFF-ROAD
    So my shaking started when the dealership did my 35K service and since then I did the ecgs bushing, powerstop z36 brakes and had Michelin defenders tires installed and still had a shake so I put the psi back to the stock numbers and the shake went away.
    Joe333x likes this.
  9. Apr 2, 2023 at 1:58 PM
    SoTexTundra
    19 DC TRD OFF-ROAD
    Well the shake is back in the front end and not sure what else to do at the moment other than get rid of the truck lol
  10. Apr 2, 2023 at 2:03 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    So you changed the psi and the shake went away but now it’s back? I’m gonna say go check the tires and rebalance
    Sierradevil likes this.
  11. Apr 2, 2023 at 2:05 PM
    SoTexTundra
    19 DC TRD OFF-ROAD
    They been balanced and rebalanced twice now and it’s going back to discount on Tuesday and gonna have them really look into the wheel and balancing as best they can this time.
    reywcms[QUOTED] likes this.
  12. Apr 2, 2023 at 2:12 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Fwiw, I had a 15 silverado that I put new tires on, one would not balance they (discount) tried 3 times. Ended up lemon lawing that truck for other reasons so never figured out the balance. But it was just one tire, they probably would’ve replaced it if I’d have brought it in again.
  13. Apr 2, 2023 at 2:14 PM
    SoTexTundra
    19 DC TRD OFF-ROAD
    I have never dealt with a vibration issue such as this with any of my other trucks. I’ve also read that tundras are very susceptible to vibrations as well which is killing my ocd lol
  14. Apr 2, 2023 at 4:46 PM
    Retired...finally
    No shakes of shimmys here but I do have a few questions. Are any of the tires showing signs of feathering? Has anyone tried adjusting the toe to either side of the allowed limits?
    I had an Element that with the blessing of the alignment shop adjusted the fronts toe out very slightly to decrease tire wear and fuel burn. It worked well but had one slightly negative effect. Under hard acceleration it would exhibit a slight vibration.
  15. Apr 4, 2023 at 9:12 AM
    SoTexTundra
    19 DC TRD OFF-ROAD
    Taking my truck to an actual alignment shop soon and get it checked out since the only place that’s touched my truck has been the dealership.
    1UP likes this.
  16. Apr 4, 2023 at 2:51 PM
    Firefly412
    Firefly412 New Member
    Robert
    2018 SR5 Double Cab
    2018 SR5. Mine shook just like yours did for a long time. Eventually Noticed the outside of the tires wearing badly. Got new tires, balanced, aligned, and it went away. I still have a very minor vibration in the steering wheel, but I can tolerate that.
  17. Apr 4, 2023 at 3:30 PM
    bgdv1
    bgdv1 New Member
    Dave
    Butler,Pa
    2019 Limited CMSB
    our '19 CM has a shimmy with the Michelin Agilis tires. Had them balanced twice(2 diff shops). It didnt do it with the Coopers so it has to be the Michelins.
  18. Apr 5, 2023 at 12:09 PM
    Rocko9999
    Rocko9999 New Member
    Mark tires with chalk indicating where it's located-LF, RF, RR, RL. Keep moving the tires around to narrow down which is causing the issue.
  19. Apr 6, 2023 at 6:58 PM
    FO LO
    FO LO New Member
    17 CM w/ 5.7 and 4.30s
    I'd be living at dt until they fixed it or refunded tires and labor
    Hope you kept the takeoffs
  20. May 14, 2023 at 10:28 PM
    Mark73
    Mark73 New Member
    MGM 2020 Tundra TRD PRO
    ReadyLift SST 2” plus 2 Lift Kit, Coach builder +3 shackles & drop kit, Nitto RG 295/70/18
    SoTexTundra did you ever find a solution to your vibration issue. I’m having the same issue. Purchased two new 295/70/18 Ridge Grapplers at Discount Tire and then drove to Toyota dealership for a alignment. I then drove home and got a vibration that felt like there was a restriction? Next morning I went back to re-do alignment. They tweak it and mentioned the alignment was in specs and suggested to try rebalancing front new tires. I returned to Discount Tire and they rebalanced the tires plus I specifically asked for road force balancing. Vibration was better but still present. Dropped air pressure to 38 lbs hot all around but I still get the vibration at acceleration around 30-33 mph. At this point I’m F…… annoyed! Alignment looks in spec and two rebalancing done already. I removed my .75 inch CB carrier bearing spacer and it went away for a day but it’s back! Any suggestions would be appreciated. I was wondering if my toe was to positive on each side and my total toe at 32 combined currently is causing the problem.
  21. May 14, 2023 at 11:05 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Tagging this thread, mine did this, I would shake when applying the brake’s at around 40-50, then it would still vibrate around 20-25.
    1. Went and got it aligned, still shake and vibrate.
    2. Went to get my tires rebalanced at Big-O, still did the same thing.
    3. Went to DTC, and got it Road Force balance, still did the same thing.
    4. Changed my rotor and brakes, all went away. Used the OEM rotors and brakes.
    My tires are 285/70/18 Ridge Grapplers the PSI I have it in is 40 psi
    Just curious if OP got it resolved.
  22. May 14, 2023 at 11:20 PM
    Mark73
    Mark73 New Member
    Ely, was your vibration only when brakes were applied? My issue is at accelerating 30-33 mph with foot on gas pedal and de-acceleration at 30-33 mph. I only have 26k miles on a 2020 Trd Pro Tundra. I wouldn’t think it’s worn parts especially that’s it’s a pavement truck without any towing being done.
  23. May 15, 2023 at 12:48 AM
    SoTexTundra
    19 DC TRD OFF-ROAD
    I’m still having a slight vibration at highway speeds that comes and goes. I haven’t been back to discount to re-balance and rotate tires to see if that helps but that will be my third time if I do that. I changed my tire pressure back to what the door jam sticker says and it helped me since I’m running stock tire size but still get a steering wheel vibration.
  24. May 15, 2023 at 12:53 AM
    SoTexTundra
    19 DC TRD OFF-ROAD
    I have brand new power stop z36 brakes I had installed and the ecgs bushing for the front differential and I still get vibration. At this point I’m lost and am just waiting for something to show up or break just so I know what the issue actually is, but for now its live-able even though it annoys me everyday.
  25. May 15, 2023 at 5:54 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    I had the Michelin shimmy and could not wait to get rid of them. Multiple alignments and balancing, rotations, would cure it for a short time then come back..Have Nokians now and zero issue..
    bgdv1[QUOTED] likes this.
  26. May 15, 2023 at 6:33 AM
    Ely010606
    SPARKS, NV
    yes, when I apply my brakes at around 40-45 and then it would shake at around 20-25 with np brakes applied.
  27. May 15, 2023 at 10:10 AM
    Mark73
    Mark73 New Member
    Dang, no solutions as of yet here either. I saw on tire calculator that the rule of thumb for psi is plus 5 lbs to door jam specs if you’re running over sized tires. I might reinstall my.75 inch carrier bearing spacers after a month or so. In 3k miles I’ll be back at Discount Tire for rotation and balance. So let’s see what happens.
  28. May 15, 2023 at 1:03 PM
    Mark73
    Mark73 New Member
    Now is your vibration at breaking only? My issue is not while breaking currently. It’s at take off and at 30-33 mph. Once I push through 35 mph it stop but returns at deceleration at the 30-33 mph.
  29. May 15, 2023 at 2:04 PM
    Mark73
    Mark73 New Member
    I’ve had them done twice already and all four are in the green/ok with road force balance is what I’m being told. Trying to figure it out because it’s annoying and frustrating for a awesome truck that should be driving smooth! Thinking about returning back to Discount Tire for a rebalance
  30. May 15, 2023 at 5:15 PM
    SoTexTundra
    19 DC TRD OFF-ROAD
    My vibration is more at highway speeds between 65-75 and it’s felt in the steering wheel. But it comes and goes so I don’t know if it’s the crappy roads or what anymore.
    Chucho and Mark73 like this.
