Shake at 60 MPH plus
Discussion in 'Wheels & Tires' started by j.phelps, Feb 8, 2020.
  1. Feb 8, 2020 at 5:45 AM
    j.phelps
    j.phelps [OP] New Member
    Jarrod
    17 crew max 4X4
    Leveling kit, tires, brush guard
    Hey guys. First post but have looked through this forum for years.
    I have a 17 tundra that has had a shake at 60 MPH for the last few months. Took it to the local shop and replaced all four tires and rebalanced. Very smooth under 60 but has a noticeable shake at 60 and up.
    Second set of larger tires. 275/70/18
    Any thoughts as to what I can do to fix it?
  2. Feb 8, 2020 at 7:08 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Did they do static or dynamic balance?
    Did they check road force?
    Have you done a visual inspection of the suspension? Have you done the 3/9 and 12/6 wheel shake to see if the steering or hub is worn?
  3. Feb 8, 2020 at 7:31 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    You have a tire that is not balanced correctly. Have the fronts re-balanced.
