SHACKLE QUESTION ??
Discussion in 'Suspension' started by 2010bigdog, Jan 3, 2019.
  1. Jan 3, 2019 at 3:10 PM
    2010bigdog
    2010bigdog [OP] New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    I installed the TOYTEC 1-1.5" shackles about 6 months ago and had them at the 1.5" setting and just last week changed them to the 1" setting and now notice a little bit of squeaking when I get in/out of the truck or when im backing into the garage and hit the brakes so I went to the back of the truck and pushed down on the bumper and it squeaks. Could it be the shackle is over tightened ?
  2. Jan 3, 2019 at 3:15 PM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    JoshuaA, 4Runner and Black Wolf like this.
  3. Jan 3, 2019 at 3:16 PM
    Did you re use OEM bushings or replace with recommended poly bushings? Could be the issue. Maybe...
    JoshuaA and sr5shark like this.
  4. Jan 3, 2019 at 3:17 PM
    sr5shark[QUOTED] likes this.
  5. Jan 3, 2019 at 3:21 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    I used the OEM bushings
  6. Jan 3, 2019 at 3:25 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    Has anyone had any issues like this with the COACHBUILDER shackles? I will have to drop the spare again tomorrow after work and see if thats the problem. Anyone happen to have a photo of what I should be looking at? Does the spare have to be dropped to see it or only if it has to be grinded down ?
  7. Jan 3, 2019 at 3:25 PM
    Looks like the problem is the bed bolts. Swapping out the oem leaf bushings help eliminate bed bounce which is a good thing. My Toytec Shackles are at 1.5" position. Going to lower them to 1" to regain more leaf spring arch. May have to do some grinding apparently...
  8. Jan 3, 2019 at 3:43 PM
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    My old Toytec shackles did the same thing at the 1” setting. I just clearances the shackle a bit with a carbide cutter
    JoshuaA, Black Wolf and sr5shark like this.
  9. Jan 3, 2019 at 3:47 PM
    Good Idea! Might be a good idea for ToyTec to modify the shackles. Easy Peasy...
    sr5shark likes this.
  10. Jan 3, 2019 at 3:58 PM
    pdiddy
    pdiddy New Member
    2017 platinum
    Icon 17 rebounds, total chaos UCA's, general grapplers 35's, corsa exhaust chopped, fox 2.5 DSC coilovers, DAP, white knuckle sliders, voodoo bed rack, baja lights everywhere, VLEDS, bedslide, C4 front bumper, warn winch, victory high hitch with dual swing out rear bumper
    Like others have mentioned it's a bed bolt making contact when you have it on the lowest setting. I just grinded the bolt down problem solved.
    sr5shark and 4Runner like this.
  11. Jan 3, 2019 at 4:15 PM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
  12. Jan 3, 2019 at 4:18 PM
    Yep.....
  13. Jan 3, 2019 at 4:32 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    Thanks for the info and pictures! I called them before I lowered it from the 1.5” setting and asked them is the center hole 1.25” and the bottom hole 1” and they told me no the center hole would be the 1” setting and NOT to use the bottom hole as it would hit the leaf springs. I moved it to the middle hole so I will look at the bed bolts tomorrow and hopefully that is what it is !
    Black Wolf likes this.
  14. Jan 3, 2019 at 4:35 PM
    Yep...the lowest setting is not used on the Tundra.
  15. Jan 3, 2019 at 4:41 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    I thought that this note referred to the lowest hole - not the middle one used for the 1” setting. You can’t use the lowest hole because the truck frame hits the crossbar in the shackle. If this note is for the middle hole on Tundras then they should make that more clear.
    That said, it’s a truck and off-road there are all sorts of creaks and rattles. ;)
  16. Jan 3, 2019 at 4:48 PM
    The shackles are settable at 1.5" or 1", ie...the top and middle holes.
    "Note: Lowest hole setting is not used on Tundras"
    **For vehicles with the TRD Exhaust, the exhaust will need to be modified to work with shackles.
    >>>>>>** We have seen a few models which may require minor grinding on the bolts which interfere with the shackle at the 1" setting.
  17. Jan 3, 2019 at 4:56 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    I obviously can't read - I totally missed the note in bold about grinding the bolts. They should probably make the text red and flashing - maybe add a few popup windows too. :D
  18. Jan 3, 2019 at 4:59 PM
    Or make a minor change on the shackles so you may not have to trim the bed bolts at the 1" setting. :thumbsup: Sometimes those bed bolts have to come off and trimming may make the bed bolt a bitch to remove.
    sr5shark[QUOTED] and pdiddy like this.
  19. Jan 3, 2019 at 5:06 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    I like the idea of grinding a little off the shackle. Agree that grinding the bed bolts may make them harder to remove if needed.
    I think that I will just go higher in the front and back to make room for bigger tires.
  20. Jan 3, 2019 at 5:08 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    So I guess trim the bed bolts or the shackles like in the pic
  21. Jan 3, 2019 at 5:10 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    I’d like to go a little higher in the front but that involves a different kit than what I have now which is 3” front right now. Might do the 4” READYLIFT in the spring
    sr5shark and Black Wolf like this.
  22. Jan 3, 2019 at 5:10 PM
    Yep. Problem solved.
  23. Jan 3, 2019 at 5:11 PM
    Cfincke
    San Antonio
    Interesting, now I need to look at my shackles as they are at the 1" setting. Been thinking of going to the 1.5" setting
  24. Jan 3, 2019 at 5:11 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    What do you recommend trimming them with ?
  25. Jan 3, 2019 at 5:12 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    Did you have to trim ?
  26. Jan 3, 2019 at 5:12 PM
    I'm going to use our bench wheel grinder at work.
  27. Jan 3, 2019 at 5:15 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    So you are taking them off ? I want to avoid that if possible
  28. Jan 3, 2019 at 5:21 PM
    Yep...taking them off. Not fun but not a big deal.
  29. Jan 3, 2019 at 5:23 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    A dremel with a grinding wheel may let you just grind away some space between the bed bolt and shackle without needed to remove the shackle.
  30. Jan 3, 2019 at 5:25 PM
    Maybe....remove the bed bolts and then trim them..I may just do that myself the more I think about it..
