SGU - The Speed Glampers Uberfahrt
Discussion in 'General Tundra Discussion' started by KevinK, Mar 6, 2018.
  1. Apr 20, 2018 at 1:18 PM
    #511
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Alex seems to get stuck somehow everytime he goes out. I fucking love it. :yes:
    831Tun, osidepunker and dcsleeper408 like this.
  2. Apr 20, 2018 at 1:29 PM
    #512
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Really it just looks worse than it was. @Spolar pulled me a little and I was able to turn and go downhill
    831Tun, dcsleeper408 and joonbug like this.
  3. Apr 20, 2018 at 1:31 PM
    #513
    KevinK
    KevinK [OP] SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    oh man, where's the drama? LoL
    831Tun and dcsleeper408 like this.
  4. Apr 20, 2018 at 1:46 PM
    #514
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Anticlimactic. Like all my stucks
  5. Apr 22, 2018 at 7:43 AM
    #515
    n2deep
    n2deep Pavement Princess
    New hardware going in ADS bumps to match the extended travel Triple Bypasses and SOA Deaver Springs from @M C M
    Check them out in Sedona
    I will have a write-up on how they do after I get some dirt time and before I go SUA and 3.0 bypasses all under the bed without any cutting.
  6. Apr 22, 2018 at 8:42 PM
    #516
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    Believe it when I see it
  7. Apr 22, 2018 at 9:09 PM
    #517
    n2deep
    Have to do something as of right now I don't care for the u748 pack.
  8. Apr 22, 2018 at 10:33 PM
    #518
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    Yea it kinda sucks. When I have the funds I definitely need to do something different
  9. Apr 22, 2018 at 10:34 PM
    #519
    Sunnier
    Sunny
    San Diego, CA
    Hey guys, following along at home, I put that u748 on my list. When you get some time, please report out on why you don't like it. Thanks!
    831Tun likes this.
  10. Apr 23, 2018 at 12:27 AM
    #520
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    Pretty simple... it supposed to handle 400-700lbs and it doesn't. Mine flattened out after 2 trips. If you don't carry a lot of weight you'll probably be fine with them. But running a bed rack, rtt, fuel, spares, tools, water, food, wood etc etc etc it didn't perform as advertised.
    Sunnier[QUOTED] likes this.
  11. Apr 23, 2018 at 3:18 AM
    #521
    Sunnier
    Sunny
    San Diego, CA
    Well that sucks. Crossed off my list. I guess I'll keep looking. Thank you!
  12. Apr 23, 2018 at 4:36 AM
    #522
    osidepunker
    Alex
    2013 Tundra DC 4x4
    You also haven't called Jeff at Deaver and told him about it so he could have a chance to make it right.
  13. Apr 23, 2018 at 4:39 AM
    #523
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Don't listen to @Spolar , there is something wrong with his pack and Jeff would be happy to fix it if he knew about it.
    @n2deep doesn't like the pack because he wants an actual progressive pack. The U packs are designed for carrying various loads, not for bombing the desert. Thats what the K37 packs are for. Different goals for different products.
  14. Apr 23, 2018 at 5:03 AM
    #524
    Sunnier
    Sunny
    San Diego, CA
    Okay. But I thought K37 can't handle heavy weight? :notsure:
  15. Apr 23, 2018 at 5:23 AM
    #525
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Regular K37 is a progressive spring pack. It will ride cadillac smooth but it's designed for no wight in the bed. However, if you call deaver, they can make you a K37 pack that will be designed for higher axle weights and it will still be a soft progressive pack. But the key is to understand the limitations. For example, if your axle weight is 3000 lbs and you have a custom K37 packs designed for that weight, it will be soft and maintain proper ride height at that weight. If you load another 500 lbs in the bed, it will sag so much it will be useless. If you take 500 lbs out of the bed, it will get bouncy. The comfortable weight range for K37 is plus or minus 200-300 lbs.
    The U packs are designed to maintain ride height with a broader weight range. But in order to do that, you sacrifice the soft progressive ride characteristics.
  16. Apr 23, 2018 at 5:53 AM
    #526
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    Yea but the U pack didn't keep my ride height either. But you're right I'm sure Deaver will do something about it. I have Tuesday off and will be swinging by and update what he says.
  17. Apr 23, 2018 at 5:58 AM
    #527
    n2deep
    The u748 pack holds the weight and gives the ride height while putting the shock piston in a good spot but with 600 lbs it was still too stiff and feels bouncy. My k37 pack with 400lbs of preload added did really well. But they started sagging bad and weren't doing the job so decided to go SUA. Only to find out I had broken a main leaf. They are getting rebuilt with a new main leaf. My problem is my bed weight varies by 500-600lbs so I am in the process of figuring out ways to cut my weight to make it more static and not swing as much when loaded and unloaded.
    dcsleeper408, Sunnier and UTTundra like this.
  18. Apr 23, 2018 at 12:04 PM
    #528
    roypark
    roypark Semi-pro High Fiver
    Roy
    Orange County
    2016 Tundra
    A little of this and a little of that. Its pretty run of the mill.
    I have a Deaver pack that handles weight pretty well. You can buy it when you buy my ADS. Hahaha.
  19. May 7, 2018 at 8:03 AM
    #529
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Anybody interested in wheeling Big Bear June 14-17th??? Send me a PM
    You'll need 4wd, good tires (and spares), and dispersed camping gear. Your truck might get scratched too depending on your driving. We'll be doing rattlesnake canyon, easy part of john bull, gold mountain, white mountain, and a few in-betweens.
    KevinK[OP], Sunnier and dcsleeper408 like this.
  20. May 7, 2018 at 10:33 AM
    #530
    n2deep
    That is also Fathers Day weekend - Just FYI
    Good Father/Son activity :D
  21. May 9, 2018 at 11:30 AM
    #531
    ryanjboutin
    ryanjboutin Weapons grade dickhead.
    Las Vegas, NV
    2013 Tacoma 4x4 with mid travel and 6 speeds.
    Hey, I'm in here now. :wave:
    :taco:
  22. May 9, 2018 at 2:07 PM
    #532
    ryanjboutin
    Las Vegas, NV
    3E9977EC-9AC5-4BAC-8B19-F8974D1F6537.jpg 64D26F2E-DC26-457F-964D-9EE735FB89A3.jpg
    Remember when Spenny got stuck at Cinders?
  23. May 9, 2018 at 3:57 PM
    #533
    KevinK
    Tundras to Sedona
    I wish I hadn't broken the truck before @n2deep got to sedona. I wanted to take him for a ride. Only @osidepunker and @papasmurf got to ride in the Stock Spring Express.
    Smooth and fast over the small to medium stuff, but I didn't even get to try the bigger hits in the Cinders. I imagine that's where we'd start to fall off the pace. The mid sized whoops would be no problem, but the 2 foot plus high ones would probably suck.
  24. May 9, 2018 at 4:07 PM
    #534
    osidepunker
    Alex
    2013 Tundra DC 4x4
    No way Kevin, you would drop to 5 mph on the 3' whoops. It was either 5 mph or 65 mph for me
    But I was definitely surprised at how well it works.
    KevinK[QUOTED][OP] and papasmurf like this.
  25. May 9, 2018 at 4:09 PM
    #535
    n2deep
    I got a ride in the truck - Hell i even drove it- What a POS, that thing handled like shit. Couldn't make a turn to save my life.
  26. May 9, 2018 at 4:10 PM
    #536
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Hahaha!
  27. May 9, 2018 at 6:03 PM
    #537
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    Yup exactly this!
  28. May 10, 2018 at 7:35 AM
    #538
    osidepunker
    Alex
    2013 Tundra DC 4x4
  29. May 10, 2018 at 8:00 AM
    #539
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Man, your truck makes those whoops look easy. Bummed I didn't get to try it.
    osidepunker likes this.
  30. May 10, 2018 at 11:52 AM
    #540
    KevinK
    Tundras to Sedona
    Yeah, we definitely would have been in the 5 mph team.
    and thanks! :D
    Bahahaha!! I totally forgot you did drive it with the busted steering rack.
    @osidepunker 's media dumps are the best dumps. Staring down that slow driver in the sombrero was on point. If I hadn't been so hung over, I probably would have laughed hard enough to pee in your passenger seat.
    osidepunker[QUOTED] and 831Tun like this.
