SGU - The Speed Glampers Uberfahrt
Discussion in 'General Tundra Discussion' started by KevinK, Mar 6, 2018.
  1. Apr 3, 2018 at 10:45 PM
    #481
    zackbremer
    zackbremer New Member
    Da Z
    ^^same thing
  2. Apr 4, 2018 at 5:11 AM
    #482
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    haha! Those days are over. It corners so good now! I just hope its not too stiff in the dirt. I'll find out in t-minus 5 hours...
    The lean isn't bad once you get used to it. You can still take corners fast. But if you weigh less than me like you think, then you won't lean as much as I did. I mean, lets not forget that I weigh 8000LBS!!!
  3. Apr 4, 2018 at 9:59 AM
    #483
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    LOL yeah true! and im like 5-600 lighter
  4. Apr 10, 2018 at 7:44 AM
    #484
    osidepunker
    Alex
    2013 Tundra DC 4x4
  5. Apr 10, 2018 at 7:59 AM
    #485
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    nice!
    Is that @roypark LC? with an Alucab?!
    osidepunker and TRD15559 like this.
  6. Apr 10, 2018 at 8:13 AM
    #486
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Boy Alex, you really squeezed it into that parking spot.;) No damage to the bumpers I hope. Great pics.
  7. Apr 10, 2018 at 8:38 AM
    #487
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    Bill
    San Marcos, CA
    Looks like a blast!
    What's the story behind this?
    osidepunker and dcsleeper408 like this.
  8. Apr 10, 2018 at 8:54 AM
    #488
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    I'm wondering that also.
    dcsleeper408 likes this.
  9. Apr 10, 2018 at 9:15 AM
    #489
    n2deep
    n2deep Pavement Princess
    So I had a temp set of Deaver U748 leafs with about 600-700lbs and the springs held the weight good but don't think they are soft enough to cycle all the travel. I never once rubbed my rear fenders as I did with my custom K37 pack- so that tells me I still have some unused uptravel. They rode fine and handled everything well but I still need to reduce weight to be able to run softer springs and use all the travel. My problem is that my bed weight fluctuates from 200lbs to 700lbs - so i need to get more static weight to be able to dial the rear in. Hopefully I can do that with my new setup if/when it gets finished.
  10. Apr 10, 2018 at 9:32 AM
    #490
    osidepunker
    Alex
    2013 Tundra DC 4x4
    So if you look at the photo of me head on, you can see than the trail dips down to my passenger side. The safe route is to turn right and go down hill, make a U, and climb back up to the original trail. I decided I would try to just continue straight and deal with the off camber slope. I almost made it, but I didn't quite have enough flex and I don't have lockers yet so I cross axled and couldn't make the climb. When I tried to reverse, my nose slipped down slope and then the rear slipped and I got wedged in. I had to stare at it a while before I made a decision on the best way to extract, but a simple pull on the drivers side rear bumper turned it enough to free me so I could head downhill.
    Zero damage, just looked scary
  11. Apr 10, 2018 at 10:40 AM
    #491
    roypark
    roypark Semi-pro High Fiver
    Roy
    Orange County
    2016 Tundra
    A little of this and a little of that. Its pretty run of the mill.
    Always a good time getting on dirt with you guys. Unfortunately, I never take very many pictures. I'm a terrible asian. And @dcsleeper408 its a Stealth by Eeziawn. Heavy AF but easy to use.
  12. Apr 10, 2018 at 10:44 AM
    #492
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Very nice! Did you get new suspension for the LC already??
    Me and the wife looked at a used one this last weekend.
  13. Apr 10, 2018 at 11:32 AM
    #493
    roypark
    Roy
    Orange County
    2016 Tundra
    Yup. Tundra swap in the front with Icon 3.0's and Icon 2.5's with resis in the rear. I need heavier springs for the rear but I'm waiting for bumpers and drawers before I mess with ride height and weight.
  14. Apr 10, 2018 at 11:34 AM
    #494
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    very nice! :thumbsup:
    was there anything you had to do to get the tundra fronts in? Or was it a simple bolt on?
  15. Apr 10, 2018 at 11:44 AM
    #495
    roypark
    Roy
    Orange County
    2016 Tundra
    The UCA and LCA bolt in. You need to get the Tundra axles and tie rods which also are plug and play. And I've been told that the Tundra sway bar link for the passenger side helps. I have the part but haven't installed it yet. Waiting to see how my stock LC bushing holds up. But it's pretty straight forward. Just basically replace all LC front suspension parts with Tundra parts except the knuckle.
    831Tun and dcsleeper408[QUOTED] like this.
  16. Apr 10, 2018 at 11:46 AM
    #496
    n2deep
    If ya need axles let us know - I have my old set sitting in the garage -just pay shipping.
  17. Apr 12, 2018 at 5:14 AM
    #497
    zackbremer
    Da Z
    :rofl::rofl::rofl::rofl:
    thank you
    831Tun, KevinK[OP] and osidepunker like this.
  18. Apr 12, 2018 at 5:20 AM
    #498
    osidepunker
    Alex
    2013 Tundra DC 4x4
  19. Apr 20, 2018 at 11:13 AM
    #499
    KevinK
    KevinK [OP] SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    Hey BASTRDS - send me a PM or something with your real name so I can get the T2S SGU/BASTRDS trail team put together.
    Bring the shenanigans!
    joonbug and dcsleeper408 like this.
  20. Apr 20, 2018 at 11:16 AM
    #500
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    But I’m not going to t2s :(...
  21. Apr 20, 2018 at 11:18 AM
    #501
    KevinK
    Tundras to Sedona
    Don't make us come kidnap your ass.
  22. Apr 20, 2018 at 11:18 AM
    #502
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    So far none of us are going except Warren. @831Tun I gotta do that stupid job thing. :(
    froggy78 and dcsleeper408 like this.
  23. Apr 20, 2018 at 11:19 AM
    #503
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    sooo... your saying I dont need to throw in on your gas if this happens..
    Sunnier likes this.
  24. Apr 20, 2018 at 11:22 AM
    #504
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Didn't know Zac is a Plumber....:anonymous:
    osidepunker likes this.
  25. Apr 20, 2018 at 11:29 AM
    #505
    KevinK
    Tundras to Sedona
    Curse that place.
    If we kidnap you, we're stealing your wallet too. :spy:
    I think he's been practicing that move.
  26. Apr 20, 2018 at 11:34 AM
    #506
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    :eek:
    jokes on you! nothing in the wallet!
    KevinK[OP] and Sunnier like this.
  27. Apr 20, 2018 at 12:23 PM
    #507
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    osidepunker[QUOTED] likes this.
  28. Apr 20, 2018 at 12:33 PM
    #508
    DividedSky
    Jeff
    Btw, I should be able to roll w/ you guys soon!
    Will probably pick my new '18 this weekend. :yes::bananadance::dancingbacon::broccoli:
    • Got an ADS (2.5" and rear Bypass)/Deaver (U748) setup from Matt on the group buy.
    • Have some +25 Vision wheels w K02's in the garage.
    • 1 water and 2 scepter fuel jugs.
    • And more camping sheet than I know what to do with
    I'd go out to Sedona with you but i just used up all my vacation going to Ecuador/Galapagos earlier this month.
    Just need to head down to SD at some point to have Papa weld up a bed rack for me!
    :benchpress:
  29. Apr 20, 2018 at 1:08 PM
    #509
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  30. Apr 20, 2018 at 1:14 PM
    #510
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    lmao thats funny.
