Setup questions please help...
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ant131313, Feb 23, 2020.
  1. Feb 23, 2020 at 3:04 PM
    Ant131313
    Ant131313 [OP] New Member
    2019 Toyota Tundra TRD- Midnight black metallic
    Tundra all weather mats Tundra bed mat APS iBoard 5" matte black running boards
    Hi, questions about the Nitto LT285/70/18 Ridge Grapplers. I was wondering how they worked out on these setups? I have a 2019 Tundra Crewmax TRD off road 2wd that were about to add the
    Bilstein 5100 kit and set it at 2.5" front and 0" rear and add these exact Nitto tires on the factory TRD off-road 18" wheels but were wondering how they fit and any rubbing or issues? how they drive and ride? How is traction/handling in the rain and also snow and off-road?
    Thank you to all and pics please if you have this setup or close to it and if anyone has another BETTER all around tire to suggestion!?
  2. Feb 23, 2020 at 3:07 PM
    Stig
    Stig New Member
    That's not a very popular tire. Hopefully someone here is running those and will chime in. Otherwise try the search function as a last resort
    Medic343 likes this.
  3. Feb 23, 2020 at 3:24 PM
    Ant131313
    Thanks @Stig ....I'm for sure open to tire suggestions? We want an overall great tire that can do everything and look a little aggressive.
  4. Feb 23, 2020 at 4:37 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    There are a number of us that run the Ridge Grapplers. I really like them. Had the BFG KO/2 before and like the RG better than the BFG's.
    Bakelite and NewImprovedRon like this.
  5. Feb 23, 2020 at 5:17 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I have the Falken Wildpeak atw/3 and I love them. They seem to have great reviews and are reasonably priced.
  6. Feb 23, 2020 at 5:57 PM
    Ant131313
    Thanks @Sas. What about the ridge grapplers in the ice/snow? I saw on some other reviews people complaining that they are useless for these conditions?
  7. Feb 23, 2020 at 5:58 PM
    Ant131313
    Thanks @Sumo91. I saw these reviewed wonderful and were our 2nd choice to go with only bc the pics online show them not looking as aggressive as the nitto ridge grapplers.....what's your take since owning them and in person?
    Sumo91[QUOTED] likes this.
  8. Feb 23, 2020 at 6:12 PM
    Sumo91
    TN
    I feel like they look more aggressive in person, and have an aggressive sidewall. They're quiet on the road too ( to me at least)Snapchat-344711708.jpg
    Just noticed you can see my dog in the backseat lolol
  9. Feb 24, 2020 at 4:53 AM
    Sas
    OKC, OK
    In a 2wd truck, it doesn't really make much difference what tire you use in snow, it's going to be slick. I'm always in 4wd at that point and these handle the snow very well. In the rain these handle well in 2wd. The only time I may break out in normal driving is if it hasn't rained in a while, so there are a lot of chemicals being brought up from the road, and I happen to drive over a painted road section (like a pedestrian walkway) while accelerating.
  10. Feb 24, 2020 at 4:54 AM
    Sas
    OKC, OK
    I'd agree with this as well.
    NewImprovedRon likes this.
  11. Feb 24, 2020 at 7:29 AM
    Ant131313
    I feel this statement is not correct to say as some 2wd trucks/tundras do awesome in snow conditions and inclement weather IF the driver knows what their doing and they have proper tires on the truck and the truck has LSD rear end and has proper weight over the rear axle and especially if the truck has been locked with rear ARB locker. Sometimes certain 2wd trucks can perform just as well as "4wd" if not better with all these factors into the equation.
  12. Feb 24, 2020 at 7:39 AM
    Sas
    OKC, OK
    You can inject all kinds of variables to make pretty much any statement contrary to what was generally stated. :rolleyes:
    BTBAKER and jordan0317 like this.
  13. Feb 24, 2020 at 8:22 AM
    ak49
    ak49 New Member
    Alaska
    2020 White Tundra TRD Pro CrewMax
    I ordered a set of Nitto Ridge Grapplers 285/70R18 about a month ago and haven't gotten around to installing them yet. I settled on them after spending hours researching different sizes and brands. No one had rubbing issues and I found a few posts of some running 1.25" wheel spacers without issue as well (if that's something you're into). I'll be putting them on a stock TRD Pro which I believe has a similar zero-rake to your leveled front end. I have no firsthand experience with them yet, but I did collect a few direct links to posts with pictures that you may find useful.
    https://www.tundras.com/threads/2019-tundra-trd-pro-tire-size.33951/#post-848110
    https://www.tundras.com/threads/2019-tundra-trd-pro-tire-size.33951/#post-848401
    https://www.tundras.com/threads/let’s-see-your-trd-pro.1470/page-37#post-1458864
    https://www.tundras.com/threads/let’s-see-your-trd-pro.1470/page-39#post-1490536
    https://www.tundras.com/threads/nitto-tires.57828/#post-1550219
    https://www.tundras.com/threads/nitto-tires.57828/#post-1512912
    Another tire I was considering in the same size was the BFG KM3, but it was heavier and some people have complained about excessive noise and uneven wear.
    https://www.tundras.com/threads/sagging-truck-bed.48899/#post-1364338
    https://www.tundras.com/threads/let...-pro-with-295-70r18.31428/page-4#post-1334403
    A lot of people on here run 295/70R18. They also look good and most have no rubbing issues (depending on brand), but I personally think they would look stuffed into the wheel wells at my suspension's height.
    LogCabins likes this.
  14. Feb 24, 2020 at 8:40 AM
    LogCabins
    LogCabins Professional Procrastinator
    'Merica
    2017 TRD Pro
    Were you able to find them anywhere cheaper than $330 a tire?
  15. Feb 24, 2020 at 8:51 AM
    ak49
    ak49 New Member
    Alaska
    Not much. They were $322.00 when I ordered them off of Amazon. This was a great deal in my case since I live in Alaska and shipping is normally ridiculously high if it's offered at all. Gotta love Prime's free shipping!
  16. Feb 24, 2020 at 8:53 AM
    LogCabins
    'Merica
    2017 TRD Pro
    Id say that's a great deal...and i feel you...I lived in Hawaii for 18 years (shipping struggle is real)
    Actually lived (stationed) in Fairbanks from 95-98
  17. Feb 25, 2020 at 9:50 AM
    Ant131313
    Thank you @ak49 . This helps a ton. Would love to hear from others on here that are running the LT285/70/18 Nitto Ridge Grapplers in all conditions?
  18. Feb 25, 2020 at 7:14 PM
    Ant131313
  19. Feb 27, 2020 at 7:43 AM
    Ant131313
    https://www.ebay.com/itm/4-New-Gene...e=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
    Actually after more research, these General Grabber ATX's seem to be one of the best overall options and by users too but would like to hear from anyone on here that's ran these or is running these now? Please help, thanks!
    Leaning towards LT275/70/18 on stock TRD 18" wheels with the Bilstein 5100 kit and front middle setting for 2" height. Would be awesome to see this exact setup with pics from anybody on here?! Would help our decision so much, thanks to all!
  20. Feb 27, 2020 at 7:57 AM
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    I have a set of the ATX's on my work truck. To tell you the truth I'm pretty disappointed in them. They are wearing very fast, after about 2500 miles they have increasingly became louder and louder. Very slick in the the rain and snow they r ok. Generals normally have a very hard compound which is why I chose them. They r on a 19 Chevy 2500 6.0 that normally has a gooseneck 4 horse trailer on it. Just fyi for comparison. They have a little over 25,000 miles on them now and in the spring they will need to be replaced. Probably try the Toyo RT's next.
  21. Feb 27, 2020 at 8:11 AM
    Bakelite
    Bakelite New Member
    Sam
    2018 Toyota Tundra TSS 4x4
    I absolutely love my Ridge Grapplers. To me they are bounds quieter than my KO2s as well.
  22. Feb 27, 2020 at 8:14 AM
    Ant131313
    Thanks @Bakelite. What size are you running and what setup do you have? Have you noticed a huge difference in gas mpg and strain on the truck drive components and power loss?
    Bakelite likes this.
  23. Feb 27, 2020 at 8:17 AM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    Aaaaaaand, that's where you lost me. I've done a lot of offroading in my years - and for most of it have done it with 2WD, but I would never in a million years say that any of my 2WD vehicles could perform better than a 4WD counterpart in the same conditions, with the same driver.
  24. Feb 27, 2020 at 8:24 AM
    field8909
    field8909 New Member
    Austin Texas
    2020 Voodoo Blue TRD Sport
    I have ran Nitto Grapplers on my 2015 and love them. I do alot of road miles and was able to get close to 50k on the 35's I had.
    Ted4311 likes this.
  25. Feb 27, 2020 at 8:39 AM
    ctdomain
    ctdomain Expeditioner
    Clint
    2019 Limited Quicksand Tundra
    Suspension: ADS Front C/O's w/adjusters, ADS Piggyback rears, Toytec Shackles, Icon Rebound 17in wheels +25 offset, 35x12.50xr17 Nitto Ridge Grapplers. Miscellaneous: Tech 12 volts remote start, Tyger side steps, Color matched pro grille & bulge, Black handles off of SR5 Tundra
    OP, in regards to rubbing issues, it is going to pretty much entirely depend on the offset of your rims. You can fit a much bigger tire than those if your offset is right, the sweet spot is around +18 to +30 offset. Factory is like +60 offset I believe, so you'll get a little fatter stance as well.
    With regards to the Ridge Grapplers, I just put a new set of 35's on my tundra, but have had a set of 35's on the ranch F-250 for a long time and they're great! Highly recommend them :thumbsup:
    Here's some pics on the Tundra -- These are 35x12.5xR17's on 17 inch Icon Rebound Rims with +25 offset, no CMC required, just some liner trimming.
    Bakelite and saybng like this.
  26. Feb 27, 2020 at 8:54 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    That's looks great!! @ctdomain
    ctdomain[QUOTED] likes this.
  27. Feb 27, 2020 at 8:57 AM
    saybng
    Gary
    Ventura CA
    I have the falken atm..and they are great in snow and rain..went up to the mountains last month and didnt even use 4wd.. gripped fine and wears evenly.
  28. Feb 27, 2020 at 9:50 AM
    Johnders2586
    Johnders2586 New Member
    2017 Tundra SR5 W/TRD pkg
    Toytec Performance Aluma 3" Lift- Toytec rear shackle, Fuel Vector Wheels, Toyo Open Country C/T 295/70/18 Tires
    I'll offer a different suggestion. ToyoOpen country C/T.. Not as popular on the market but a little cheaper then Ridge Grapplers. Im in NH so we see plenty of snow..These have the 3 peak snow rating. So far I don't have any complaints. I'd say they are similar to the wildpeaks . Worth considering.. I have 295/70 on a 3 inch lift. Wheels are +20 offset.
    saybng likes this.
  29. Feb 27, 2020 at 10:31 AM
    saybng
    Gary
    Ventura CA
    Called around here and they dont offer the ct, only at..what's the difference?
  30. Feb 27, 2020 at 10:33 AM
    Johnders2586
    I got them through Town Fair Tire. It's considered their "commercial" grade tire . Probably have to special order only becuase they are not as well known/ popular.
