Setrab Tranmission Cooler Installed on 2022 Tundra Hybrid
Discussion in '3rd Gen Tundras (2022+)' started by KFRC46, Mar 22, 2023.
  1. Jul 20, 2023 at 12:31 PM
    Nomoredomestics
    Nomoredomestics New Member
    GA
    2023 TRD Sport 4x4
    Well. . Dont I feel stupid. I thought the 3rd gens HAVE a dedicated Trans cooler??
  2. Jul 21, 2023 at 10:32 AM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    For the Mustang they have the aux cooler near the radiator. Moshimoto sells kits for the Mustang A10. I’ve had no need for it since I installed the shift kit, which also upgrades the oil passages in the shift body.
    Moshimoto has a kit for the F-150 as well. I’m addition they have a thermostat mod that is very cool for certain models.
    https://www.mishimoto.com/ford-rapt...b6dgsaG57Fg1oB9t683SufssRAlbPCzoaAtL8EALw_wcB
  3. Jul 21, 2023 at 11:11 AM
    mass-hole
    mass-hole New Member
    Thats only for the Raptor and 2017 F150 3.5. They had the traditional radiator cooler + air cooler.
    All normal 10 speed F150's went to a oil/water cooler only in 2018 and I have yet to see any kind of cooler upgrade for those. Its literally just a block that sits under the truck between the trans pan and oil pan.
  4. Jul 21, 2023 at 12:50 PM
    Coasty
    Coasty New Member
    Pat
    Oregon
    2022 SRS Crew Max 6.5 4x4
    Do you use the Tow/Haul feature when towing? I'm curious if this would make a difference as the tranny shifts less and I believe only goes up to 7th gear.
  5. Jul 21, 2023 at 1:19 PM
    Coasty
    Coasty New Member
    Pat
    Oregon
    The Tundra towing video Chuy! posted a link for is pretty informative. It said the 3rd gen has the tranny cooler that Ryan posted above and that the 2nd gen had no tranny cooler and in their towing the 2nd gen tranny temp hit 247 degrees while the 3rd gen hit 231 degrees. They were towing in 44 degree temps so I'm sure that helps keep temps down but it was also up I70 on a 7% grade towing 8100 lbs which is a tough climb.
  6. Jul 21, 2023 at 1:44 PM
    mass-hole
    The problem with these liquid/oil coolers like this seems to be that if the engine is not under a particularly high load then coolant flow through the radiator core is too low because the thermostat is closed, and you dont get much heat transfer through the transmission exchanger. I had this issue with my Lexus GX after pulling a pretty steep pass, I wasnt going fast and the engine coolant temp stayed pretty low. I dont even think I heard the mechanical fan engage. But by the top I had hit 248F trans temps and they refused to come down when I let the engine idle. There was virtually no coolant flow through the radiator due to the low load on the engine and the trans just stayed at a really high temperature for like 10-15 minutes.
    I think this is why we have seen so many complaints about people just driving up a forest service road in 4x4 where the engine isnt really stressed and probably only making 40 hp(if that), but the trans is putting in some effort.
    22whatwedo and ryanwgregg like this.
  7. Jul 21, 2023 at 1:48 PM
    mass-hole
    They are all doing it now. Even the Superduty's with the 10 speed dont run air coolers anymore. I think the 7.3L Superduty TFL Tested on the ike got up close to 240F trans temps.
    ryanwgregg likes this.
  8. Jul 21, 2023 at 2:02 PM
    Nomoredomestics
    GA
    2023 TRD Sport 4x4
    Well damn. . I sure thought it was external. . .guess it's still better than my 19 and 21. .
    And you're a wealth of info. Thanks for all the contributions!
  9. Jul 21, 2023 at 3:39 PM
    Durtywrench
    Durtywrench New Member
    Lou
    23 Tundra platinum
    None
    I’d hate to add this and have them end the warranty due to some unforeseen circumstance .
  10. Jul 21, 2023 at 8:37 PM
    2WD
    2WD New Member
    21 Army Green CM SR5 TRD Off Road
    Pretty sure 2018 models was when the AC Freon switch happened. Just need an owner of a 2018 to check if its 134a or 1234yf (newer Freon)
    EDIT: Yep 2018s had the OEM radiator ATF cooler and the newer Freon.
    https://www.tundras.com/threads/it-costs-what-to-recharge-your-a-c.90670/
  11. Aug 13, 2024 at 9:01 AM
    KFRC46
    KFRC46 [OP] New Member
    The cooler has been running fine, if I had to do over I may have gone larger but this one manages temps well. I have towed up to 10K and max trans temps was around 220 in 85F heat, the lowest operating temp you are going to see is around 170F. In summary pinned the thermostat lowers operating temps from around 200-210 down to 180-190, this cooler increases thermal capacity for towing to an acceptable degree. Runing in Tow+ lowers trans temps around another 10F but oil temps go up by 10F due to the increased revs. If you are regularly towing up to 75% of the trucks rated capacity this cooler is a solid choice, if you are going over that I would consider larger one. If you only tow occasionally, 5K LB or less just pin the thermostat.
  12. Aug 13, 2024 at 9:54 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Meh. I liked Mr. Egg well enough but I wouldn't say they were a veritable font of ToyCorp knowledge.
    @sudobash makes Mr. Egg look like the puke that changes oil at any dealership when it comes to turd 3rd gen knowledge.
    :thumbsup:
  13. Aug 13, 2024 at 10:16 AM
    Woocawachie
    Woocawachie New Member
    Dickens
    Philadelphia
    2023 Tundra Limited CM 6.5. WindChillPearl
    Stock “thermostats” can’t be pin on 3rd gen tundras correct?
  14. Aug 13, 2024 at 10:47 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    sudobash likes this.
  15. Aug 13, 2024 at 10:49 AM
    Woocawachie
    Dickens
    Philadelphia
    Where? I looked everywhere around that little “cooler” thing they call cooler and I don’t see anywhere where you can pull anything out or pin it
  16. Aug 13, 2024 at 10:52 AM
    sudobash
    sudobash New Member
    hagrid[QUOTED] likes this.
  17. Aug 13, 2024 at 10:56 AM
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    It is on the side of the transmission
    There is no stand-alone "cooler" it is actually a warmer.
  18. Aug 13, 2024 at 10:57 AM
    eddiefromcali
    Eddie
    100% Stock
