Serpantine Belt Replacement ??
Discussion in 'General Tundra Discussion' started by Rex Kramer, Jan 14, 2021.
  1. Jan 14, 2021 at 7:40 AM
    Rex Kramer
    Rex Kramer [OP] Vinyl Spinner
    Georgia
    If you are going to replace the belt, pulley and tensioner on a high mileage 5.7L, is it also a good idea to replace the water pump while you are there even if it's not leaking? Is there any other preventative maintenance one should consider while doing this?
    In my case, I have no idea if it's the original H2O pump or not, but I do know that it's not leaking.
  2. Jan 14, 2021 at 8:07 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Well, I think Toyota sees water pump replacement as maintenance. I have a 06 4Runner and recall it being recommended to replace the water pump when those other items were replaced, as a maintenance item. So, while you are in there it may be cost and time effective to handle that at the same time.
    Rex Kramer[OP] likes this.
  3. Jan 14, 2021 at 8:34 AM
    AZBoatHauler
    So.Arizona
    If it were a GM, I’d replace it. Since it is a Toyota, if it looks good and works good I wouldn’t touch it.
  4. Jan 14, 2021 at 8:38 AM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    Belt takes 5 min to replace. I believe the pump is a lot more in depth(radiator, fan etc needs to be removed).
    I’d leave it until it needs it.
    blackdemon_tt and Rex Kramer[OP] like this.
  5. Jan 14, 2021 at 9:33 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Rex Kramer[OP] and chugs like this.
  6. Jan 14, 2021 at 10:28 AM
    Rex Kramer
    Georgia
  7. Jan 14, 2021 at 1:54 PM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    Rex, what year is Tundra you are referring to (your profile shows two: 2002 & 2007) and how many miles is "high mileage"?
  8. Jan 14, 2021 at 1:59 PM
    Rex Kramer
    Georgia
    I thought the "5.7L" would give it away... 2007 with 296,000.
  9. Jan 14, 2021 at 2:40 PM
    preacher35
    Oh, good point, Rex. I am a victim of public schools, so there's that. Anyway, with 300k miles, and assuming that it is the original water pump, YES, I would indeed swap out the water pump while you are balls deep in there.
    AZBoatHauler likes this.
  10. Jan 14, 2021 at 3:57 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    My 07 tensioner got tweaked when changing belt. Had to replace it to. It is a good idea.
    As mentioned if temps are good and no leaks, I would leave it alone.
  11. Jan 14, 2021 at 5:24 PM
    Rex Kramer
    Georgia
