Sequoia rear swap?
Discussion in '1st Gen Tundras (2000-2006)' started by evilrb, Sep 16, 2020.
  1. Sep 16, 2020 at 12:29 AM
    evilrb
    evilrb [OP] New Member
    Jeremy
    Opps! I did it again...
    but hey $40 and I have new calipers, rotors, drums, ss lines and all...
    Backing plates are bent but fixable and has a third member to rebuild on the side with my Kazuma LSD install.
    So anyone ever do the first-gen Sequoia rear disk swap on their FGT?
    Could you post links?
    Just want to confirm what I'm doing.
    My parts list I have so far:
    New Calipers
    Rotors and pads
    Drums, shoes, and hardware
    SS brake lines extended
    T100 dual diaphragm brake booster and bigger master
    From what I remember all I have to do is pull the axles, put new axle seals, and install them with the backing plate and brake stuff in my Tundra's housing.
    I'm also going to be doing the install on my TRD Kazuma LSD at the same time so those seals and bearings are going to be done as well.
    Do I need the parking brake cable from the Sequoia or can I modify the Tundra's?
    Am I correct?
    Thanks guys!
    119556408_10158976160839236_7107657407968852625_n.jpg 119714713_10158976160759236_6584581142403423365_n.jpg
    Hooptytrix, tvpierce and Luckydog like this.
  2. Sep 16, 2020 at 2:43 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Subscribed. Interesting project!
  3. Sep 16, 2020 at 2:59 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Best time to do a long travel with coil springs or retrofit a airbags from a Mercedes Benz GL. As for the the parking brakes, there's a chance you need to mod the Tundra's cable ends. Sequoia might be too short due to wheelbase.
  4. Sep 16, 2020 at 3:57 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Give this a look.
    Hooptytrix, evilrb[OP] and Tundra2 like this.
  5. Sep 17, 2020 at 2:05 AM
    evilrb
    Jeremy
    Thanks that's the link I was looking for!
    For some reason, that forum has been glitchy for me that last few months.
    Can't message people and not all threads are showing...
  6. Sep 17, 2020 at 2:14 AM
    evilrb
    Jeremy
    UPDATE: So my I confirmed that my Tundra does not have ABS, had it checked twice by others just to be sure...
    So parking cable ends are all that I need to figure out it looks like.
    I'll do a full write up when I actually do the install, I'm thinking about regearing right now since it'll all be out anyway and I'm doing high-angle boots on my front axles too...
    It's just a domino effect now...:bananadance::bananadance::bananadance::bananadance::bananadance::bananadance::bananadance::bananadance::bananadance:
    It's only money...:bananadead:
    Some pictures for reference to my brake lines and yes I will address the surface when everything is out.
  7. Sep 17, 2020 at 6:40 AM
    Professional Hand Model
    Hand Protectors
    Dominoe$$$:rofl:
    Thats a nice over the axle rear sway bar you have there. What brand is that?
    ktundra and DaWhiteTundra like this.
  8. Sep 17, 2020 at 6:40 AM
    You fabbing a rear coil setup now for the Tundy? or converting the axle to leaf spring mounts?
  9. Sep 17, 2020 at 6:46 AM
    Hand Protectors
    Your guys are correct in No ABS. If you had it, it would be as the picture.
    evilrb[OP] and bmf4069 like this.
  10. Sep 17, 2020 at 11:14 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Did you just draw a penis?
  11. Sep 17, 2020 at 11:17 AM
    tvpierce
    Maine
    Thanks for saying that... 'cause I thought the same thing.
  12. Sep 17, 2020 at 11:26 AM
    Hand Protectors
    Both you guys must be similarly hung?
    jpink, Hooptytrix, robabeatle and 5 others like this.
  13. Sep 17, 2020 at 11:28 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Damn. My pride.:oops:
  14. Sep 17, 2020 at 12:14 PM
    evilrb
    Jeremy
    ADDCO 2181 1’ rear sway bar kit
    Nope, just gonna clean up and paint my stock housing and swap axles over just to get the brakes to work.
  15. Sep 17, 2020 at 2:22 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    He isn't swapping the housing, just the guts. This will be cool to see.
    Hooptytrix and Tundra2 like this.
  16. Sep 17, 2020 at 2:59 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    Did you have to drill the frame to install this kit? I've found conflicting info about whether or not drilling is required. I'd appreciate a picture or two on where the links mount to the frame.
    At over $200 cheaper than the Hellwig 7700, the Addco kit has my attention. I also like that it's above the axle vs the Hellwig which seems to hang down a bit.
  17. Sep 17, 2020 at 3:10 PM
    evilrb
    Jeremy
    Yes, I had to make a hole but wasn't hard to do at all.
    I'll get pictures in a bit.
    Had them for a few months now and it rides great, but I do alot of freeway driving so it's set up for that.
  18. Sep 17, 2020 at 3:18 PM
    Lil Steve
    Gilbert, AZ
    That's good news, aside from how they mount the other difference is 1" vs 1 1/8" diameter. I'd rather put the $200 saved towards HD leaf springs. That combo should work great for me since nearly all of my driving will be on pavement occasionally hauling a couple of bikes and/or a trailer. Thanks!
  19. Sep 18, 2020 at 12:01 AM
    evilrb
    Jeremy
    Yeah, I looked at options for a bit and almost went with the Hellwig but I found this set on a site on sale for $130 shipped with free returns so I just took a shot.
    I figured I'd return it if not.
    A lot better looking in person than advertised.
    I don't have side by side comparisons they look pretty good as the Hellwig bars that I've seen so this is one great deal I recommend so far, only time will tell on the long haul of them though.
    Oh and the instructions I got sucked so it was more of just line it up when I was installing it.
    Pretty simple to do, I got a second and third opinion but in the end, it was one of those things where you just don't overthink it and send it!:D:D:D:D:D
    As I said, no problems so far and they perform great in the rain at 70+ mph.
    and as you can see in the picture there is no rubbing issues with the leaf springs or any side to side rubbing on anything.
  20. Sep 18, 2020 at 12:07 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    the bolt pattern for the backing plates on a sequoia is different from out 1st gen axles. this is the issue with why its not a bolt on swap. you can cut all the mounts off the sequoia axle and weld on perches and shock mounts though
  21. Sep 18, 2020 at 12:08 AM
    empty_lord
    05 rollover special
    if only it were that simple :(
  22. Sep 18, 2020 at 12:11 AM
    evilrb
    Jeremy
    i'm using the sequoia axles, but I was told they are the same??
    hmmm... I'll have t look into that more... any threads?
  23. Sep 18, 2020 at 12:12 AM
    empty_lord
    05 rollover special
    no threads i know of. the physical axle is the same internally. the backing plate that mounts to the axle to the housing has a different bolt pattern that our backing plates
  24. Sep 18, 2020 at 12:16 AM
    evilrb
    Jeremy
    damn, I'll measure it this weekend and see if I can make it work or something.
    this is the first I'm hearing that info...
    I'll post pictures and an update by next week.
    Thanks for the heads up!
  25. Sep 18, 2020 at 12:17 AM
    empty_lord
    05 rollover special
    any time! i was going to use sequoia backing plates on my taco. but thats when i found out about the axle backing plate difference. tundra and taco are the same for sure, i have the SOS performance tundra rear disc kit on the Tacoma!
    speedtre likes this.
  26. Sep 18, 2020 at 12:45 AM
    evilrb
    Jeremy
    do you know if there is a difference between the backing disc pattern on the ABS sequoia VS a Non-abs tundra?
    Just a shot in the dark question...
  27. Sep 18, 2020 at 12:46 AM
    empty_lord
    05 rollover special
    tundra mounting is basically a square if you look at it from where the studs are. the sequoia top and bottom are offset of each other. i believe the bottom 2 are spaced further apart than the top two.
  28. Sep 18, 2020 at 12:47 AM
    empty_lord
    05 rollover special
    the other issue is if your truck is NON ABS the axle seal on the sequoia axles are are set into the axle deeper because of the ABS tone ring. the non ABS axles the seal is on the edge of the axle basically.
  29. Sep 18, 2020 at 12:48 AM
    evilrb
    Jeremy
    Gotcha, thanks again.
    Love your builds BTW!
    Did you get that Benz running?
  30. Sep 18, 2020 at 12:49 AM
    empty_lord
    05 rollover special
    waiting on a radiator still for my tundra. then i have to tow the car to work to drop the gas tank. its full of crud. gotta have it cleaned out. and im still trying to locate the correct Carb rebuild kits.
    ktundra and evilrb[QUOTED][OP] like this.
