Sequoia Lift Gate Malfunctioning
Discussion in 'Sequoia Builds' started by War Machine, Jun 2, 2020.
  1. Jun 2, 2020 at 5:01 AM
    War Machine
    War Machine [OP] SSEM # 5 3MW
    My father in law has our old Sequoia (2012). The lift gate isn’t opening and closing with the fob or dash button most of the time. It does work occasionally. The latch disengages, but it won’t go up or down. Has anyone run into this before?
    I’m guessing it’s the motor wearing out, but just wanted to see if anyone has experienced this before with a Sequoia, 4Runner, Highlander, etc. and had a solution.
  2. Jun 2, 2020 at 5:49 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Sometimes the gas struts get worn enough not to be able to start the process of opening. Same thing Happened on the 4runner we bought for my daughter. I wold replace them and see if that fixes your problem. They’re relatively inexpensive
    War Machine[OP] likes this.
  3. Jun 2, 2020 at 6:02 AM
    War Machine
    Would that keep them from going down though?
    EmergencyMaximum likes this.
  4. Jun 2, 2020 at 6:03 AM
    shawn474
    MoCo, Maryland
    Ahhhh.... probably not. Sorry man
  5. Jun 2, 2020 at 6:08 AM
    War Machine
    No sweat. I believe there’s a reset procedure. I’ll try that and see if it makes a difference.
  6. Jun 2, 2020 at 6:20 AM
    Beau
    Beau De gustibus non est disputandum
    Beau
    2008 Sequoia with a 2022 style
    I would start with new struts (or swap with your wife's to rule it out) bc the gate does all sorts of funny things when it doesn't complete it's motion when you hit the key or button. New struts and reset procedure should get it working correctly.....hopefully. Good luck man!
  7. Jun 3, 2020 at 3:52 PM
    Rock15t
    Rock15t New Member
    2011 Sequoia SR5 5.7 4x4
    is it making any noise when it does it?
  8. Jun 5, 2020 at 4:24 AM
    War Machine
    Just the sound of the latch disengaging.
  9. Jun 5, 2020 at 4:24 AM
    War Machine
    That’s a great idea. I’ll try that also!
  10. Jun 5, 2020 at 5:09 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I think mine does something similar. Once in a while when I try to open it with the remote, the liftgate would open but doesn't go up. I'd have to press the remote a second time for it to actually open up. Never really thought it would be an issue with a strut or the motor since it seems to close fine. Would be interesting to see what you find.
  11. Jun 5, 2020 at 5:14 AM
    War Machine
    May be a while before I get around to it. They’re taking it to Tennessee for a week. I’ll let everyone know.
    omgboost[QUOTED] likes this.
  12. Jun 5, 2020 at 6:44 AM
    BassBlaster
    BassBlaster New Member
    Jay
    2016 silver 1794
    Bilsteins front and rear
    Had an '08. The back hatch was the most problematic part of the vehicle. Sometimes it would work electronically, sometimes not. I think eventually we just used it manual, and yes the struts lost their juice a bit. Also, the window at one point went down but would not go up -- found out the mechanisms back there are known to rust out. I had the dealer pull the window back up and bolt it in rather than paying for the fix. Bottom line: Expect such issues! They are reported all over....
  13. Jun 5, 2020 at 7:19 AM
    SouthWestGA
    SouthWestGA New Member
    I’m sorry you’re experiencing issues
    Our 2008 Sequoia Limited has 227,000 trouble free miles
    i do regularly lube the lift gate motor gears and silicone the tracks a few times a year though
  14. Jun 5, 2020 at 7:35 AM
    War Machine
    This Sequoia has well over 200,000 miles on it and this is literally the first malfunction of any kind. It’s not even a major issue. Great vehicles.
  15. Jul 2, 2023 at 3:22 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    I haven't had any issues with mine other than it needed cleaning after it got mud in the tracks. I don't have an electric open/close on mine though. Gotta go old school. :)
    I'm wondering if anyone has figured out a way to open a 2nd gen rear hatch from the inside?
  16. Sep 17, 2023 at 10:19 AM
    Wade Bennett
    Wade Bennett New Member
    2023 TRD pro toyota sequoia
    Factory
    I have a 2023 sequoia with 4500 miles, has not even had a oil change yet. The lift gate will open automatically however it will not close unless you close if physically. When you push the button to close it will give two beeps and that's is all it does. It seem to be an issue the happens either after a rain or after the vehicle has been washed. Is anyone else having this issue.
  17. Sep 17, 2023 at 11:37 AM
    Beau
    Beau
    Sounds like you accidentally pushed the button on the dash. On mine, it’s to the left of the steering wheel.
  18. Sep 25, 2023 at 2:27 PM
    davinpin
    davinpin New Member
    Davin
    2014 Toyota Sequoia Platinum
    2014 Sequoia Platinum rear trunk not open with two beeps when pressed on remote control or bottom. Did someone find its solution?
  19. Feb 11, 2024 at 10:11 AM
    HRAYMOND
    HRAYMOND New Member
    2012 Sequoia Platinum 4x4
    Same problem here w my 2012 SEQUOIA. Anyone find a solution?
