Sensor Errors Won’t Stop and Dealer Can’t Fix It!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Award6691, Mar 6, 2021.
  1. Mar 31, 2021 at 12:00 PM
    #91
    Dwarven1
    Dwarven1 New Member
    Ross
    2018 SR5 w/TRD Off-Road.
    2018 SR5 - Bolo Mark XXb - Unit DNE of the Line. "Denny"
    Oddly enough, I had the windshield replaced yesterday on my 2018DC - the insurance company told me I had to make an appointment to get the camera recalibrated! Yet, I tried out the lane departure feature today and it's working just fine. Since insurance is covering 100%, I'll still have Toyota do that, but near as I can tell, it's a wash.
  2. Mar 31, 2021 at 1:29 PM
    #92
    Award6691
    Award6691 [OP] New Member
    Art
    Yes... brake warning goes off at random times. It doesn’t happen that often. But, I guess I just accept it.
    I think it happens in all their cars. No biggie.
  3. Mar 31, 2021 at 1:31 PM
    #93
    Award6691
    Art
    Sorry to hear they didn’t cover your ABS wore issue. I think mine is a different system than ABS. The ABS is one of the only warning lights that didn’t go off in my case.
  4. Mar 31, 2021 at 1:34 PM
    #94
    Troysbama
    Troysbama New Member
    Troy
    Tampa, FL
    18' White Tundra Plat CM
    6" DirtyDeeds exhaust TRD Front and Rear Swaybars (5.5" front lift and 4" rear lift) Maxtrac Spindle lift 2.5 Fox IFPs up front and 2.0 Fox for the rear +3 Coachbuilder Shackles, bushing, carrier bearing drop kit Dakar leaf springs Coachbuilder steering links FRAC harness Cheap Ebay Rivet fender flares (I really like) 33x12.5x20 Cooper ST Maxx that I'll be updating to 35s when they wear out 20x9" Fuel Boost wheels 1.25" spacers for rear wheels
    Can't tell if you were responding to me but to be clear, mine wasn't a brake warning. I got a warning that said TSS Malfunction Return to Dealer or something like that. There was no indication it was the ABS Sensor.
  5. Mar 31, 2021 at 4:15 PM
    #95
    Award6691
    Art
    Update - Ok! We have a root cause!
    After 6 weeks in the shop... the Toyota Factory Engineering Representative tore the dashboard open and found that the soy-based wire insulation had been chewed by rodents.
    TTTRDPRO was right! He posted that it was rodent damage very early on. Apparently, this happens with the soy-based wire insulation which toyota and many other manufacturers now use in their cars. It is NOT covered by the Toyota warranty.
    I’m waiting for the estimate to replace the wiring harness. Maybe $6000?
    IndianaGeologist likes this.
  6. Mar 31, 2021 at 4:41 PM
    #96
    irishpride114
    irishpride114 New Member
    Travis
    2015 SR5 TRD Double Cab
    Someone on Facebook last week had to have their entire trucks harness replaced. I think they said it cost their insurance $12k
  7. Mar 31, 2021 at 4:49 PM
    #97
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    I had a very similar issue to that described here after driving on the highway in torrential rain for about an hour; Toyota went through everything and found no rodent damage, and the issue resolved once everything dried out. I made them note it in case it ever happens again, I have proof that the issue started while still under warranty.
  8. Mar 31, 2021 at 5:12 PM
    #98
    Quattroa4m
    Quattroa4m New Member
    So Toyota makes the wiring harness irresistible to rodents and it’s your fault?
    That’s a sizable Engineering fubar if true.
  9. Mar 31, 2021 at 5:15 PM
    #99
    Kywildman
    Kywildman New Member
    Joshua
    21 Tundra Silver SR 4x4
    I just sat and read through this entire thread. I am a used car technician. I’ve worked on at least one of each of them all the way back to a Plymouth Grand voyager lol
    I also work at a Toyota dealership, and I feared this was the direction this was headed. Can I make a recommendation to keep rodents out of the cab once this is resolved?
  10. Mar 31, 2021 at 5:33 PM
    #100
    The Californian
    Eric
    I'd like to hear your recommendation.
  11. Mar 31, 2021 at 5:33 PM
    #101
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    damn.... how can it not be covered. that is crazy.
  12. Mar 31, 2021 at 5:50 PM
    #102
    BMET
    BMET New Member
    2018 Tundra Limited
    Soy based insulation stinks. Now I have to worry about rodents eating my truck.
    OP - so was the rat literally in your cab? Wonder how it got in there?
    Kywildman likes this.
  13. Mar 31, 2021 at 5:53 PM
    #103
    Kywildman
    Joshua
    https://www.tundras.com/threads/mouse-rodent-proofing-stage-one.44679/
    Do exactly like this guy, I would however not reccomend drilling any holes, or using any metal fasteners(screws etc) as this panel is spot welded in and you don’t want to deal with rust down the road. Get creative. So far I’ve got mine taped on with multiple layers of tape until I can come up with a safer more permanent solution. It is a very real problem, sadly with most manufacturers, and how they do get in the cab.
    Terndrerrr and BMET like this.
  14. Mar 31, 2021 at 5:59 PM
    #104
    Kywildman
    Joshua
    431D1FDF-BA71-48B6-838B-B891D05BB06B.jpg BBFFB8CC-83FE-442B-B41A-E17799CBE0FC.jpg due to their skeletal structure, they only require a hole literally the size of their heads to fit their whole body through. Period. Unfortunately our trucks came equipped with foot wide holes in our firewalls
    Terndrerrr likes this.
  15. Mar 31, 2021 at 7:06 PM
    #105
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level Lift, DIY SAIS preventer, headers.
    Make sure to check with homeowners or rental insurance. Others have reported that their homeowners insurance have covered rodent damage.
    Dwarven1 likes this.
  16. Mar 31, 2021 at 7:42 PM
    #106
    irishpride114
    Travis
    car insurance as well.
  17. Apr 1, 2021 at 10:16 AM
    #107
    The Californian
    Eric
    Luckily for me, I have owls that live in the palm trees in front of my house - I'm pretty sure they snag up any rodent that comes anywhere near my house. So my suggestion to everyone, is get owls.
    irishpride114, Kywildman and Jaypown like this.
  18. Apr 1, 2021 at 10:45 AM
    #108
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Just read this whole thread. First thought was rodents. Snowstorm? That only encouraged the rodents to seek shelter in your truck while it was parked.
    If only the dealer had looked behind the dash 6 weeks ago...
    Thanks for the link @Kywildman, I’ll be doing that to my truck ASAP!
  19. Apr 1, 2021 at 1:14 PM
    #109
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    so I assume the dealer eats the cost for replacing the wiring harness under the rear bumper? It was misdiagnosed.
    Bakershack and Terndrerrr like this.
  20. Apr 1, 2021 at 2:19 PM
    #110
    Kywildman
    Joshua
  21. Apr 1, 2021 at 4:48 PM
    #111
    Dwarven1
    Dwarven1 New Member
    Ross
    Toyota is setting themselves up for another frame recall type lawsuit with this. THEY put the soy-based wiring in there in the first place; THEY ought to eat the cost of replacements.
    Soon as the weather breaks (again) I see I'm going to have to start closing off openings. I have woods all around and plenty of rodents around, too.
  22. Apr 1, 2021 at 4:49 PM
    #112
    Kywildman
    Joshua
    It’s already been tried many times to no avail. Same with Honda, Kia, Hyundai meh
  23. Apr 1, 2021 at 5:00 PM
    #113
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    This is why I feed the stray cats that hang out around my home, but I don’t feed them too much.
  24. Apr 1, 2021 at 5:24 PM
    #114
    Kywildman
    Joshua
  25. Apr 1, 2021 at 5:32 PM
    #115
    Marshal
    Marshal Newd Member
    Marshal
    Petoskey, MI
    2014 SR5 MGM 5.7 4x4
    If insurance won't cover it I'm sure an independent could splice the wiring back together depending on the severity of it. Had to have melted harnesses repaired before. Much cheaper than replacing if it comes to it, or if it's doable
  26. Apr 1, 2021 at 5:33 PM
    #116
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    my 4 yo has asked to watch this rat episode a few times this week LMAO
    he knows how smart they are
    Kywildman[QUOTED] likes this.
  27. Apr 1, 2021 at 5:34 PM
    #117
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    It is interesting, learned a few things...Little bastards!!!
  28. Apr 1, 2021 at 5:35 PM
    #118
    Kywildman
    Joshua
    I mean in all honesty, maybe THEY are the superior species?!
  29. Apr 1, 2021 at 5:39 PM
    #119
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    @RainMan_PNW ?
  30. Apr 1, 2021 at 6:06 PM
    #120
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    This rodent damage thing is more common than I thought. You would think Toyota and the other mfgrs would at least put out a TSB for the dealerships so they know to look for it if a vehicle comes in with a bunch of unexplained sensor/electrical issues. They obviously know about the problem, at least give the dealerships a heads up so they don't spend time/money chasing the issue. Although, as I type this I think that if they did issue a TSB that would be admitting the problem and they'd be taking ownership of it, which it looks like they're trying to avoid.
    Whatever, I'm gonna do the rodent screen thing on Monday, or maybe take some stuff with me and do it on my camping trip this weekend.
