Seized rear diff breather valve
Discussion in '1st Gen Tundras (2000-2006)' started by Pucks18, Feb 21, 2021.
  1. Feb 22, 2021 at 9:00 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I can tell you that while it should work this way, it doesn't. I went wheeling with a few Taco owners in December and one of the guys didn't have the diff breather extension. We did several creek crossings. When he got home and drained his rear diff it looked like coffee. It was full of water. The best thing for anyone who thinks they might go through water like that is to do the extension.
    Sampson, Pucks18[OP] and des2mtn like this.
  2. Feb 22, 2021 at 10:26 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    That's normal. As the Maharishi of Mitts ( @Professional Hand Model ) stated above, it's pipe thread. The threads intentionally bind with each other to help form the seal.
  3. Feb 22, 2021 at 10:33 AM
    Pucks18
    Pucks18 [OP] Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    So your saying im good to go to just screw It in despite it having resistance? I have never heard of that but I learn something new every day. Just want to make sure before I go ahead and do it
  4. Feb 22, 2021 at 10:46 AM
    Cogx5dad
    Cogx5dad New Member
    2010 SR5-TRD off road
    Debadged, waiting on bielsteins and shackles
    I ran mine up to the tail light when I did my mod. I was just say’n that making it a diff mounted two way is the worst thing you can do.
    Sampson likes this.
  5. Feb 22, 2021 at 10:51 AM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    They are a tapered thread, thats normal. NPT's are 60* with sharp peaks and vallys and BSPT are 55* with rounded peaks and valleys, fwiw.
    These are also a simple option.
    https://www.amazon.com/Trail-Gear-Creeper-Breather-Differential-Kit/dp/B008OLPUJS
  6. Feb 22, 2021 at 10:58 AM
    rockmup
    rockmup New Member
    Todd
    Axles are not water tight either, water gets in from the ends as well.
    FrenchToasty likes this.
  7. Feb 22, 2021 at 11:45 AM
    Pucks18
    rockmup[QUOTED] likes this.
  8. Feb 23, 2021 at 9:35 PM
    aredub
    aredub Supply Chain Guru
    USA
    2001 Tundra SR5 AC 4.7 2WD
    King Coilovers, Pro Comp Wheels, BFG KO2s, Kenwood head unit
    After 20 years of ownership, I finally relocated my breather valve using the parts as described in post #12, but went with OE on the 2-way. I ran it up behind my driver’s side taillight. 9 ft of 3/8 fuel line, 2 hose clamps, and a zip tie. No problems getting the original 1-way off and it was still functioning as intended. I’ve done this mod before on my Tacoma, so it took about 15 minutes ... maybe.
  9. Feb 23, 2021 at 9:43 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    The word chinky is no longer allowed in our society, please be advised that you must keep this crappy part as it was described, and you will like it! ;)
    Sandy01 likes this.
