Seized cam bolt on lower control arm!
Discussion in 'General Tundra Discussion' started by robie56, May 13, 2015.
  1. May 13, 2015 at 1:27 PM
    robie56
    robie56 [OP] New Member
    Steven
    New Hampshire
    2011 white cm rock warrior
    mbrp exhaust, afe dropin filter, stubby antenna, Readylift leveling kit, ICI magnum RT sidesteps, weather techs front & rear
    I had my Readylift 3/1 kit installed yesterday, had an appointment to have my frontend aligned today. Truck was on the lift when 1 of the techs came out & asked me to come back and see a problem they were having with my 011 RW with 30,000 miles. He had a 2ft breakerbar and could'nt move the cam bolt on the lower control arm on the drivers side, which is how the camber is adjusted, passenger side no issues. So I came home with a truck still needing an alignment. I live in NH so there is salt a plenty on the roads here during the winter. Has anyone else had this problem with their Tundra?
  2. May 13, 2015 at 1:40 PM
    Mike Tread lightly.
    south carolina
    my 03 was in ohio for 3 years before it moved down here south carolina. Last year i had to replace BOTH LCA do to salt getting in the cams and freezing them up. We tried to push the cams out with a press only to mushroom the LCA. All you can do man is replace the LCA unless you can press out the cams but not likely.
  3. May 13, 2015 at 1:41 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Did with my Tacoma; I had to use a die grinder to carve them out. I bought new ones and replaced them myself, then had it aligned. I hope you don't have to do that, not one of my favorite memories.
  4. May 14, 2015 at 12:18 PM
    robie56
    Steven
    New Hampshire
    Thanks guys for your input. I just got home from the dealership where I purchased my Tundra. And the service manager said the cambolt on the LCA should not have seized since the truck only had 30,000 miles on it and was getting its FIRST alignment. Said he would order parts including a new LCA, replace them and align my truck all under warranty, no charge, I wanted to kiss the guy, but I settled for a handshake. Now I hope there is no problem when they discover I have a 3/1 Readylift on it.
    Wynnded and Black Wolf like this.
  5. May 14, 2015 at 12:26 PM
    I was wondering about Dealer + truck having lift kit. Tell them it was found seized during lift install. Pre-existing condition. Of course some dealers don't give rat's behind. Sound's like you have a good dealer.
  6. May 14, 2015 at 8:57 PM
    That's a great Toyota dealer!
    Black Wolf likes this.
