Sec gen, 2012 toggle switch size?
Discussion in '2nd Gen Tundras (2007-2013)' started by Max2012trd, May 3, 2023.
  1. May 3, 2023 at 4:33 PM
    Max2012trd
    Max2012trd [OP] New Member
    Anybody know the size or where I can buy a toggle switch for these blank locations? I want to put a loud ass horn on my panel but can't find the right switch!! Every one I order is the wrong size! Thanks,
    2012 tundra
  2. May 3, 2023 at 4:52 PM
    Aironboard.com. You want the "Toyota small" series.
    07 Tundie and PhotoNerd like this.
  3. May 3, 2023 at 4:58 PM
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
    Depending on how you use the horn (short busrt or f-off mode), scroll through the pictures on this switch which fits our dash perfectly.
    https://www.ebay.com/itm/331762454130
    It shows 32.5mm x 22mm but it's a latching switch w/ light, so not ideal for a horn. It says it fits Toyota and it does.
    GL finding momentary contact in that foot print.
    PS - I've been debating on making a timer that resets the instant you let off the horn but if held on for (pick a number) 7 seconds, it enables output to another relay for as you requested a louder horn and when you let off main horn, both quit.
    Would you be interested? I'm sure amazoo has some 12v device to do this if you go looking.
  4. May 3, 2023 at 5:20 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    2008 Salsa Red Tundra DC SR5 4x4
    Chrome delete, Sequioa grill, bed lights, LED + head, fog & tail lights, Dynamat throughout, front & rear cameras, Pheonix PX6 13" head unit, 8" subwoofer, JBL speaker upgrades, tonneau cover, custom shifter, steering wheel cover
    Ch4x4 has custom momentary switches that fit.
    Ohannon7 likes this.
  5. May 3, 2023 at 5:23 PM
    chrisf111
    chrisf111 New Member
  6. May 3, 2023 at 5:24 PM
    chrisf111
    Wow this is a cool idea. I think the delay would have to be closer to 1 or 2 seconds though. Basically a short toot-toot would use the regular horns but a sustained press would turn on the loud horn.
  7. May 3, 2023 at 6:03 PM
    KeepOnTruckin
    Randy
    I took a quick peak at amazoo, there may be simple circuit to be bought if not, we can make one if someone can define a time before it mega horn comes on.
    Because I don't want to build a pcba to mount a programmable chip, some dip switches and resistors could set the time.
    Initial 2, second delay then for each dip switch flipped, adds another second....
    I made a switchback circuit for my street bike on a small foot print. It's been working for 5 years... I can make this if you all can solder and cut stuff.
    Started with a timing diagram, designed a circuit and then built two for left and right DRL/turn indicators...
    Ohannon7 and PhotoNerd like this.
  8. May 5, 2023 at 1:04 PM
    KeepOnTruckin
    Randy
    @chrisf111
    Read the details on this... I'd say 99% chance it would do what you want when coupled to current horn output, and a suitable power relay to drive your new louder horn(s).
    Programmable Delay Amazoo
    Read the long text description of its capabilities and maybe watch the video. PS it programs through your web browser. No app needed which makes me feel a lot better. PS - I'm guessing it has a PIC18F microcontroller in it, hence having to buy the programming hardware to go with it.
    I'm tempted. Find us a good Horn!
    Both truck and car need this as well my bike! That said, I have 100% faith that if I build a circuit it will never let me down.
  9. May 5, 2023 at 1:10 PM
    chrisf111
    Looks promising. Almost looks like a similar product to the PAC TR7 module I used to do my tailgate latch auto open. That module was able to look for a certain number of input pulses and trigger an output pulse when it saw it. In my case when it sees 3 unlock pulses it sends a pulse to the tailgate actuator.
    I've been thinking about doing a simple upgrade of my horns to something like this for a while https://www.amazon.com/HELLA-Protective-3AG-003-399-801/dp/B000CRZXPI
