Seat Adjustment message on start up
Discussion in '3rd Gen Tundras (2022+)' started by TundraJax, Mar 7, 2023.
  1. Jun 29, 2023 at 1:37 PM
    in_the_mud
    in_the_mud GSD
    Raph
    Calgary, AB
    2023 Limited L TRD OR MBM
    Just wanted to make sure you understand what my issue is. My key fob is linked, memory seat is working just fine, moves me forward and backward. I did the whole procedure couple weeks ago when I noticed the message on my screen - that's when I set up a memory seat. And even though I went through it the message is still popping up. Hope it's clear.
  2. Jun 29, 2023 at 1:43 PM
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    Does the seat go to a stored position when you hit the 1 or 2 button?
  3. Jun 29, 2023 at 1:46 PM
    in_the_mud
    in_the_mud GSD
    Raph
    Calgary, AB
    Yes.
  4. Jun 29, 2023 at 2:16 PM
    BoulderGT3
    Glen
    I don't know what to tell you. When mine accepted the memory button programming the prompts went away. Exasperating but what I would do is reset the identity and program it again.
  5. Jun 29, 2023 at 2:19 PM
    in_the_mud
    in_the_mud GSD
    Raph
    Calgary, AB
    I will try that, thanks.
    BoulderGT3[QUOTED] likes this.
  6. Jun 29, 2023 at 10:14 PM
    23tundra75002
    23tundra75002 New Member
    Dallas
    2023 Tundra Platinum in celestial silver
    My 23 platinum is doing the same thing as yours. Everything works, everything and no beeps. But seems like every other day I get two or three continuous prompts asking if I want to adjust my seat.
    in_the_mud[QUOTED] likes this.
  7. Jun 29, 2023 at 10:45 PM
    in_the_mud
    in_the_mud GSD
    Raph
    Calgary, AB
    Exactly. Everything works and it’s just annoying to have that message popping up all the time.
  8. Jun 30, 2023 at 5:41 AM
    23tundra75002
    Dallas
    I’m going to follow that YT video about linking my key fob to a profile and see what happens. It’s not linking key fob to truck, but to a specific driver profile.
  9. Jun 30, 2023 at 11:53 AM
    BoulderGT3
    Glen
    My Tundra brought up the seat adjust prompt today and I thought of something else that may be happening. Initializing the seat by moving forward and backward basically establishes limit or reference points. There is a device that counts how many times the shafts turn to get to your memory position and a modules that keeps track of all of it. If you move your seat from your memory position the module may be asking you if you'd like to adjust your seat because it's not on your personalized memory setting. That happens with mine when the seat is adjusted to anything but the memory setting. FWIW.
  10. Jul 1, 2023 at 2:12 PM
    BoulderGT3
    Glen
    Not to beat it to death but I did verify that the position module under the seat is what give the "seat adjust" prompt. Once you have the seats initialized, it should not put that prompt up if the seat is in one of the two memory settings. The reason it puts up two prompts, one after the other is for position 1 and then position 2.if you've moved the seat the prompt will show up on the display. An odd bit of SW programming but it is what it is.
    in_the_mud likes this.
  11. Jul 1, 2023 at 2:53 PM
    Soupbean77
    Soupbean77 New Member
    2023 Mag Grey Tundra Limited Crewmax 4x4
    Here’s just my two cents…. Mine was asking if I wanted to adjust seats constantly, even after my fob was linked and my profile was linked. It still constantly asks for my pin. As far as the seat thing goes… I think it’s completely stupid for my screen to ask if I want to adjust my seat. If I wanted to adjust my seat, I would just go ahead and do that. They should have a message pop up after starting your truck that says… WOULD YOU LIKE TO DRIVE YOUR TRUCK ? And not let you put it in drive until you enter yes or a PIN code.
  12. Jul 1, 2023 at 6:00 PM
    in_the_mud
    in_the_mud GSD
    Raph
    Calgary, AB
    @BoulderGT3
    Very good points. I will check that out for sure.
  13. Jul 4, 2023 at 5:11 PM
    cruiserhead
    cruiserhead New Member
    As FYI @in_the_mud - I am having the exact same issue as you. Everything works as programmed. I've done all the stuff suggested and still get the question probably once a week or so. Sometimes more, sometimes less...seems very random.
    So with all of that, I have nothing to offer to help. But know at least one other bloke has the same issue :)
  14. Jul 5, 2023 at 4:07 PM
    BoulderGT3
    Glen
    FWIW, which probably isn't much but it's working for me, here are the settings I've got configured- Do the seat initialization process. Program both buttons. I didn't pair to a key. I don't really see the need to as there is only one fob. I don't use the access function that slides the seat back and forth on entry. Who knows but it works for me.
  15. Sep 11, 2023 at 9:55 AM
    iforceAZ
    iforceAZ New Member
    Mine all worked fine....Then I go my second key fob installed. Now no beeps, memory seats work. Just every couple of days I get the adjust seat prompt. Say no twice and it's gone.
    No idea. I have linked both keys.
  16. Sep 12, 2023 at 10:11 AM
    Adventurer
    Adventurer New Member
    2023 1794 TRD 6.5 Celestial Siver
    Mine is linked and still get the 2 messages randomly. Going to do the seat calibration, that makes more sense for my particular issue.
  17. Sep 12, 2023 at 10:12 AM
    iforceAZ
    iforceAZ New Member
    I've noticed that if my profile loads then I don't get the warning. If my profile fails to load then I get the seat prompt.
  18. Sep 12, 2023 at 10:32 AM
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    My prompt went away after linking the key to my profile in the center screen setup options.. I think it's under general > profile but I don't remember exactly.
    ETA - didn't realize people were still getting the prompt after linking profiles. That might be the dealer failing to correctly setup the vehicle for delivery..
  19. Sep 12, 2023 at 11:58 AM
    #49
    Adventurer
    So far so good. Never even messed with seat memory, but it didn't work until I did calibration. Without a second fob yet I suppose it may still prompt.
  20. Sep 13, 2023 at 6:44 PM
    #50
    Adventurer
    I get the seat msg even more now, after doing calibration and setting memory #1 LOL
  21. Sep 14, 2023 at 4:25 AM
    #51
    Prohit
    Prohit New Member
    2024 Sequoia Platinum
    Sounds like you’re bitter about YT. Did they ban one of your videos or something? But hey, enjoy that beep haha.
  22. Sep 14, 2023 at 8:13 PM
    #52
    MrKABC
    MrKABC Not so new Member
    Art
    Corona, CA
    2023 Mesquite 1794 TRD OR Hybrid
    Miller Cat Shield, Sumo Springs Blue, Diode Dynamics Stage Series hidden light bar.
    Lol nope, I can read a lot faster than some clown who burbles nonsense for 20 minutes after suffering through TWO commercials, crappy 70's porno music soundtrack, irrelevant commentary, and the inevitable "smash that like button and subscribe to my channel" message at the end.
    Assuming, of course, that the YT idiot covered everything they were supposed to in ONE video.
    And I found WRITTEN INSTRUCTIONS for the problem and had it fixed in less time it took to suffer through the ads.
    Bonus thought: why do YT clowns put their face in the video "ad" looking like a demented window licker??? SMH.
  23. Mar 26, 2024 at 5:34 AM
    #53
    Talkin_Tundras
    Talkin_Tundras New Member
    ‘22 Tundra Limited
    I seem to be getting this message now after my system updated last week.
  24. Mar 26, 2024 at 8:49 AM
    #54
    Adventurer
    Same here. Hoped this issue would be resolved by now. Since I got my 2nd key fob, I'm going to try calibration first, then creating a memory position for each fob.
  25. Mar 26, 2024 at 10:31 AM
    #55
    Talkin_Tundras
    ‘22 Tundra Limited
    It’s really weird. It just started popping up. It also doesn’t do anything, as far as I can tell. If you select no or yes it basically just exits the screen. No idea what it’s intended for. Maybe I should read the manual lol
  26. Mar 29, 2024 at 3:20 PM
    #56
    TexasCabledawg
    TexasCabledawg New Member
    2024 Land Cruiser (had a ‘22 Tundra)
    I also got it after the update. Everything worked great prior to the update. Nothing has worked to make it go away. Not even a full reset.
  27. May 6, 2024 at 6:10 PM
    #57
    gman54313
    gman54313 New Member
    I also believe my pop up seat adjustment came after an update.
  28. Nov 4, 2024 at 1:00 PM
    #58
    IAmSain
    IAmSain New Member
    2022 Tundra Limited, white
    Bone Stock
    Had same issue with 22 Tundra. Dealer didn't know off the top of their head. Wifey's 24 Highlander is doing the same.
    After some YT kids, boils down to programming both seat buttons and pairing the kay. Seems to work so far. Will try with her Highlander as well.
  29. Nov 6, 2024 at 6:29 AM
    #59
    MikeVpdx503
    MikeVpdx503 New Member
    I’ve tried all the fixes and it still comes and goes. I’m starting to think this has something to do with seatbelt being clicked before or near starting the truck. It doesn’t seem to pop up when belted in but if I start the truck without my seatbelt or start and drive away without seatbelt then it pops up.
    Grasping at straws here, haha
  30. Nov 6, 2024 at 8:00 AM
    #60
    DRP
    DRP Old Member
    Dave
    Mine still has the message occasionally after trying all the "fixes". I just live with it.
