Sealing tailgate + Bakflip MX4 tonneau cover
Discussion in 'Tonneau Covers, Caps and Shells' started by BlueBottle, Nov 19, 2016.
  1. Nov 19, 2016 at 9:52 PM
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    Got tired of water getting in from the tail gate whenever I run through car washes.
    I bought 2 different seals
    1. I used this one for the bottomhttp://www.autozone.com/sealants-glues-adhesives-and-tape/weatherstrip/metro-black-super-weatherstrip/191113_0_0/?checkfit=true
    2. I used this one for the sideshttps://www.amazon.com/gp/product/B00IPQWXZQ/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
    Here are the Side Seals
    F36E2106-9B85-402D-9B0D-E6BCB8C650C5_zps_28acebc784d7f14d780f0af437d4356c9faa4892.jpg
    80C9B900-0F08-42CF-B925-40299769EA74_zps_7f10d63213410093595caefc0a76e5c8d4d93e99.jpg
    96A902A1-4BF8-4414-A473-29A73F32660C_zps_414144cd575dc10ce4f8df0d2b35e373f8b493ec.jpg
    On the TailGate
    4D981332-9208-40D4-8AFF-881CDD2C4B63_zps_3dd8ea4c4568712f51243c38d9737a2bfd4b597a.jpg
    9C8D3C51-5268-4499-9BBB-9E279DB57D22_zps_7e35c36ddae74c1c86cd37e2ec2d014f739a2e82.jpg
    With the flashlight test, I do not get any light going through the side seals so I suspect that will eliminate the water coming in from there.
    I will update this thread once I get to do a car wash test.
  2. Nov 19, 2016 at 9:57 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Here's what the side seals look from the inside.
    B146B37E-CAEE-4B99-95E6-67C6F2FA32DE_zps_62fd9f4d8b2aebb70e518910c14cd7e4262b2c32.jpg
    ChucklesToy and buckeyes1975 like this.
  3. Nov 20, 2016 at 9:38 AM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    equin, BlueBottle[OP] and Law323 like this.
  4. Dec 4, 2016 at 8:25 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    *update*
    Ran the truck through a touch less high pressure washer. It kept a 95% of the water out except for a few drops. Prior to this a lot of water came in. Overall happy with this mod.
    AZTundra, equin and MotoTundra like this.
  5. Dec 4, 2016 at 9:58 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Nice! Glad it worked out, thanks for sharing the info.
    BlueBottle[OP] likes this.
  6. Sep 28, 2019 at 9:37 AM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    Will be trying this over the weekend. Haven't had any rain since I've installed my MX4 but I can tell that there are gaps that are going to leak without having to even test it.
  7. Sep 30, 2019 at 3:48 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Damn I did this almost 3 years ago. Well it’s good to say it still seals pretty good to this day. Doesn’t rain much here but when it does I’m good.
  8. Sep 30, 2019 at 3:54 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    I appreciate the tip. Amazon just delivered the one you recommended today for sides. After paying almost $1k for the MX4, I don't want it leaking on a trip. I noticed people doing the reviews complained about leaks. Ya gotta go the extra mile like you did. Thanks bro
  9. Sep 30, 2019 at 7:24 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    anytime!
    keep in mind it will still leak at the hinges a little. Mine did anyway. I would keep anything important in a watertight box if possible. Or at least closer to the center of the bed.
    I have since upgraded to an undercover overlander. And that one doesn’t leak! But it’s not a tri fold so it’s a hassle to remove.
  10. Oct 1, 2019 at 5:13 AM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    Man I'm hoping it doesn't leak at the hinges. I think I'll test it this weekend. We are in a drought here with no significant rain in sight. All the rain is a pop up here and there. Nice cover, but I really want to have full bed access when need it without a significant chore.
  11. Oct 13, 2019 at 3:31 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    Got the ESI seals installed today. Yeah, they are sticky and very confident of the performance. You can go to their site and they have better pics of each model. You better be lined up when you start pulling the tape from the sticky side
    I'm done with the dirty bed. Be was never covered before
  12. Oct 13, 2019 at 3:38 PM
    biebs96
    PA
    Here is how I did mine.
  13. Oct 13, 2019 at 3:40 PM
    Blueknights75
    Ron
    Clayton, NC
    Reason I went with the Rugged Cover 2. Doesn’t leak a drop.
  14. Oct 13, 2019 at 4:43 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Tag, i might just have to do this.
  15. Oct 13, 2019 at 4:51 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    I was impressed buy the sticky stuff. It's about $25 for enough to do the tailgate section. Not much daylight coming through. Thinking about getting some for the front seal instead of the cheap foam that came with the bakflip
  16. Oct 13, 2019 at 5:42 PM
    Ely010606
    SPARKS, NV
    Not a bad idea, do you mean the ESI from Amazon, i have the revolver x2. Mine hasn’t leaked in the front, mostly in the tailgate section
  17. Oct 13, 2019 at 5:47 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    This one. Pretty decent instructions at tailgateseal.com I make some adjustment but you get an idea
    https://www.amazon.com/Ultimate-Tailgate-Seal-Taper-10ft/dp/B00IPQWXZQ/ref=sr_1_1?crid=BG67TOQSHDVS&keywords=esi+ultimate+tailgate+seal&qid=1571014014&sprefix=esi+ul%2Caps%2C802&sr=8-1
  18. Oct 13, 2019 at 5:49 PM
    Ely010606
    SPARKS, NV
